Question about Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White
Hi While I try to rotate the tap , the whole base is rotating with it ( delta 470 ss)
  • 623 Answers
A "basin" wrench will be needed to get up under the sink/faucet base to tighten the nuts that hold the faucet in place. It's a simple job but requires the agility of a contortionist to get at.
Posted on Apr 27, 2010
Delta 470 trying to remove metal pull out spray wand but it gets stuck when trying to remove and replace
Are you trying to just replace the sprayer? I replaced the whole unit so cannot help with just the sprayer.
Jun 08, 2014 | Delta Faucet Delta 470-BL-DST Signature...
How to fix a leaking faucet
want to extend my delta tap about 5inches how do i do it?
Sep 03, 2012 | Delta Model 470: Signature Kitchen...
I have the model 470 signature pull-out Delta faucet in my kitchen sink. It was installed about 5 years ago. I can no longer rotate the faucet without applying an extreme amount of pressure. Is there a fix...
Contact Delta at 800-345-3358 and ask for replacement parts. With the lifetime warranty Delta customer service was awesome and sent out parts I needed to fix this same faucet.
Jan 10, 2011 | Delta Model 470: Signature Kitchen...
Very low pressure on delta 470 faucet
To get full pressure you need to pull the wand away from the base. Then remove the wand from the hose becareful not to loose the washer. When the wand is removed look down the wand you will see a plastic part. That plastic part is a flow restrict-er. You need to put a screw in the restrict-er and pull it out. When it is out put wand back on the hose then you will have full water pressure.
Jan 16, 2010 | Delta Faucet Delta 470-BL-DST Signature...
How to fix leak for delta faucet 470 WHRS
To fix the leak in delta faucet is have a repair kit for
Delta 470-WHRS. The repair kit consist of O-rings
replacement. Otherwise, you have to buy a replacement
for your Delta 470-WHRS.
Nov 26, 2009 | Delta 470-WHRS Signature Single Handle...
2-handle faucet handles both rotate "on" counter=clockwise
Here's the solution from Delta:
On a two-handle kitchen or lavatory faucet, if the handles rotate in the wrong direction, simply rotate the right stem stop assembly 180 degrees. This will change the rotation of the handle to the other direction.
Jun 23, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Trouble removing the faucet from a Delta Waterfall 174
I wouldn't worry about messing up the threads as it is an old unit that you wish to discard. Do what is necessary to hold the threads still with the vise-grips and loosen the nut until you reach the damaged threads. Then pull the faucet up from the top until the nut hits the bottom of the sink and cut the threaded nipple from the faucet with a hack-saw blade. Lay down cardboard to protect the finish of the sink and surrounding counter top.
I have had to do this many times and it usually saves you the headache of bloody knuckles.
Apr 26, 2009 | Delta Faucet Delta 174-SSWF Waterfall...
Older Delta 10'' Miter Saw Zero setting is out by 1/2 degree.
Undid the RH fence-bolt in the table behind the fence and tapped the end of the fence forward to make it perpendicular to the blade. Tighten bolt. When you look down on the two fence bolt heads, one is easy to rotate with a socket wrench, the LH bolt head would be very, very difficult to move. Undo the RH bolt to swing the fence angle WRT the blade.
Apr 08, 2009 | Delta Saws
Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White Logo
368 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
bwbconstruct
Level 1 Expert
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
