Question about Brother IntelliFax 1860C Plain Paper Inkjet Fax
Paper face up or down
Do you put the paper face up or face down.
Which way do you put the paper in fax machine
it stands to reason face down or the scanner would see blank paper
Feb 18, 2015 | HP Photo Smart 7525 e All-In-One Ink Jet...
Do I insert the paper I want to fax face up or face down?
Having no Operating Guide, I'd type a one line sample, make a note on the paper like "face-up" and put it in with the paper facing up and hit "print".
If it prints on that side you have your answer. If it prints on the backside, then put your papers in facing down.
Jun 20, 2011 | Lexmark F4270 Plain Paper Inkjet Fax
When faxing does paper go face up or face down
If you are using the the Automatic Document Feeder (ADF) the paper goes face up. Face down if you put the paper on the platen.
Jun 25, 2010 | Brother MFC 420CN All-In-One InkJet...
How do u put the print paper in facing up or facing down printer photosmart c4750
If ordinary paper it does not matter.If photo paper then put it in the feeder tray glossy side down and one sheet at a time as glossy paper tends to stick and causes paper jams.
May 04, 2010 | HP Office Equipment & Supplies
How do u load paper? front or back side up?
Hi, It dosen`t matter how you load paper, Copy paper are blank on both side, now if you are reusing paper with prints on one side then you do it by trial and error.
Now if you meant how to load document on top, then that`s a different story, most fax machines require that you put the document face down. I would suggest that you make a copy from a document face down and if it comes out ok, fine, if the copy comes out blank then you need to put the document face up instead.
Hope this helps.
Mar 13, 2010 | HP 1040 Plain Paper Inkjet Fax
How do i fax what button to put
feed paper at the top of the fax machine which you want to send through fax. remember that face of your documents is down ( mean the clean side face is up word and writing side is down word.)
Nov 18, 2009 | HP Office Equipment & Supplies
Do I load the original for faxing right side up or upside down? HP officejet v40
Look at the input tray it shows a symbol of an original.
If the lines on the symbol face you , then put the paper in face UP.
If the lines are on the folded corner of the symbol, then place the paper in face DOWN.
If you are still not sure, place the paper in face UP and press "COPY"
If it copies the page, then that is the correct orientation.
If thre copy is blank, repeat the copy test with the document face DOWN.
Sep 28, 2009 | HP Office Equipment & Supplies
I have the stupidest question. i have a brother fax 560 plain paper fax. Do i load paper face up or down to send a fax? THank you!
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face down.one time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Brother IntelliFax 1860C Plain Paper Inkjet Fax Logo
54 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
