Question about SanDisk 1GB microSD Memory Card
Smartmedia sandisk how to unlock sandisk i cat format my card with pc
Thank you so much for your information, it worked
Posted on Jan 28, 2009
  • 871 Answers
I like the picture. reminds me of my best friend.
bout your query, you can try unlocking your sandisk by manually checking the card for the write protect enable function. it may ba a little switch on the side.
Posted on Mar 24, 2008
Haw can i buy new card for my fuji finepix4700 camara
This camera uses smartmedia cards.
Check out these on this WEB site.
http://www.amazon.com/SanDisk-SDSM-32-490-32MB-SmartMedia-Card/dp/B0000488VH
Mar 15, 2013 | Cameras
I forget password of sandisk 2gb micro sd memory card
you can unlock your sd card by formatting*.
formatting memory card will delete all datas
formatting method*
use a softtwaer phone for formatting.. (example nokia 6120c, 5800etc )
insert your sd card into the softwaer phone.. select SETTINGS > DATA MGR > MEMORY > OPTIONS > FORMAT MEMORY CARD
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I have forgotten the password of my memory card and i want to unlock it now.
Once locked, its not poosible to unlock it if you forgot your card's password. Connect it to PC via any card reader and recover its content by copying it to the PC.
Then format it twice. 1st using PC and then using your Phone.
Hope this solves your problem.
Mar 01, 2011 | SanDisk 2GB microSD Memory Card
How to unlock sandisk microsd memory card
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format memory card
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Feb 20, 2010 | SanDisk 2GB microSD Memory Card
Format 32mb smartmedia in FAT12
Hi friend,
ok you can try to format on windows xp.
Follow these steps:
1.Open Control panel
2.Open administrative tools
3.open computer management
4.then click disk management
select the drive and try to format as per you requirements . note that you can also delete the partition and create new..
ok
Regards
Uttam
Jan 13, 2010 | SanDisk 2GB microSD Memory Card
Hi! I have an older Olympus C-4000 Camedia Camera and am wondering if it's compatible with a 4 GB SanDisk SDHC memory card.
Unfortunately the only memory card that can be used in this camera is a smartmedia card. The largest smartmedia card available is a 128mb card.
Dec 10, 2008 | Olympus Camedia C-4000 Zoom Digital Camera
D-380 smartmedia card formatting
There is something alled the CIS header on Smartmedia cards. If that is missing or damaged, any compliant Smartmedia device will not let you use the card. Many card readers are not Compliant and thus ignore the CIS block.
It is advisable to not try and "recycle" cards with a damaged CIS block by using them in a non complying card reader because of one of the reasons why the CIS block is there is to ensure something called the bad block table is present on the card as well. The bad block table maps the locations of bad memory cells and prevents writing to them so the card will apear 100% good. All cards have some bad cells from the factory even. Most likely the bad block table will be missing as well and your non complant card reader will end up writing over bad memory cells which will cause future read errors and data loss.
You would need access to a compliant Smartmdia reader that is compatible with the SMPREP (or similar) formatting utility to fix problem smartmedia cards. SMPREP fixes the CIS block and scans the entire card for bad memory cells and updates the bad block table.
Mar 13, 2008 | Olympus Camedia D-380 Digital Camera
For formating card
Try http://lclane2.atspace.com/olformat.html
The Olympus C-830L camera is the same as the D-340R
Jan 15, 2008 | Olympus Camedia C-830L Digital Camera
SmartMedia - how to download images without USB cable
get a new cable. or a new card reader. i prefer card readers as i can take my camera around to various events, and if a friend wants an image, he can attach the reader to his computer (if nearby) and get what he wants.
are you sure your computer can directly read smart media cards?
possible it does, but not that common unless its fairly new.
mark
Nov 01, 2007 | Fuji FinePix 2800 Zoom Digital Camera
How to copy panorama feature?
The panorama feature cannot be copied, it is 'firmware' of sorts that is integrated into the card itself. Olympus does offer several types of 'special' firmware in their branded SmartMedia cards (I believe there was a special one for printing T-Shirts and Mugs and the like....don't recall exactly, but did have a special supplement when I bought my C-1400XL).
Sep 11, 2005 | Olympus Camedia C-2000 Zoom Digital Camera
SanDisk 1GB microSD Memory Card Logo
79 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
