Question about Heritage Pool & Spa
Spa keeps tripping breaker shows pr - Heritage Pool & Spa
    Top Expert:
  • 15,190 Answers
Two main reasons breaker trips is the pump motor jammed [not turning]or the heater shorted out --disconnect power open access panel disconnect the lines to the heater turn on power if breaker trips than motor /pump problem if doesnt trip than heater problem can order heater replacement online or pool spa store--if motor pump check pump for debris and motor for lube if u can turn shaft or impeller oil motor and work it into bearings if still not turning possible need to replace motor unit
Posted on Apr 27, 2010
I have a spa berry 2 person hot tub. Tried resetting it but as soon as I let go of the reset button it trips the breaker. Can't get it to stay on. Tub is 4 yrs old. Where do we start?
Melisa, Breaker/GFI may be going bad. You may have to get an electrician to check for short or faulty motor/heater, etc. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ehottubsandpools.com/?p=320
Troubleshooting tripping hot tub GFCI breaker
Hot tub GFI keeps tripping
Spa Circuit Breaker Mysteriously Tripping Any Clues Portable Hot Tubs amp...
Jun 27, 2016 | Pool & Spa
I have a leisure rite spa and it has been off a while on putting it back on Pr appears on the panel then as the cycle starts it shuts down and trips the house electrics can you help ?
Pr means it is going to ru a 4-6 minute course of non-operation, to "Prime" the system.
Then the spa will start up and run normally.
after a short time, ensuring all air is purged from the system, Heater will then come on.
if your breaker trips immediately after the priming mode is complete, then your pump is suspect of failure.
May 22, 2014 | Miscellaneous
Reset Jandy PS6, still flashing red and green
turn off heater if ok then replace ignitor if not keep removing auxs until stops blowing breaker
Apr 02, 2014 | Jandy Aqualink Pda Ps6 Wireless Handheld...
Caldera olympia highland spa keeps tripping breaker
with power off take heater wires off make sure to mark them so you know which is which if it doesnt blow fuse it is heater element if it still does hook back up then try to disconnect the recirculation pump just keep eliminating things
Mar 02, 2014 | Caldera Spas Highland Series Olympia Model...
Tripping circuit breaker
Hi Kathy
Sometimes when a breaker keeps tripping, it will wear and will be in need of replacement...try replacing the breaker and see if that solves your problem.
If not then check the amps on the pump and make sure the breaker is able to hand the amperage the pump is requiring.
Bud
Oct 09, 2013 | Pool & Spa
Electronics breaker keeps tripping switched
write down all auxs then unplug all then turn on and plug one at a time till it pops probably heater ignitor if ok bad pump motor
Aug 18, 2013 | Pentair Intellitouch Power Center Includes...
Breaker for hot tub keeps tripping
Leaking heat element.
2 GFCI on same circuit.
Rat-chewed wire. Inspect wiring.
Nail through wire.
Melted wire nut in junction box.
Undersized wire and breaker has been overheating breaker, and breaker has gone bad.
Shorted breaker. Move wires to different same-size breaker.
http://waterheatertimer.org/How-to-wire-GFCI.html#2-pole-gfci
http://waterheatertimer.org/Color-codewire.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 21, 2013 | Pool & Spa
Gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Mar 15, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
115 volt 20 amp breaker for hot tub keeps tripping
Is there anything else on the same breaker? Is that the proper amperage for the pump? How long has the pump been in service? It may need to be cleaned as possible obstruction causing too much strain.
Nov 29, 2008 | Waterway 1.5 Hp 115 Volt 2 Speed Side...
Pool & Spa Logo
566 people viewed this question
Top Heritage Pool & Spa Experts
john h
ray gallant
Mike Raino
Level 1 Expert
Are you a Heritage Pool and Spa Expert? Answer questions, earn points and help others
