posted by UTERUS on Mar 24, 2008
I have a sansui RZ-2200AV amp which has just stopped outputting sound, the only way i can get sound out of it is to turn it to full volume and i can just hear some sound. I cannot change the input, it won't respond to the buttons on the front and constantly has what looks to be V D on the display. The backlight for the lcd has also stopped working.
Best Solution
posted on Mar 24, 2008
This sounds like you lost the 5V supply. If you can solder, look for bad solder connections around the voltage regulator ICs. These look like transistors (3 legs) and may be attached to a heatsink. They will be marked 7805 +/or 7905.
Dan
Dan
Rating Locked! (?) UTERUS has rated this solution as Helpful
This Problem Also Relates To:
Kenwood 104AR Receiver
Motorola DCP-501 5.1 Channels Receiver
NAD C740 2 Channels Receiver
Sony STR-DE197 2 Channels Receiver
Sony STR-DE345 5.1 Channels Receiver
Sony STR-DE445 Receiver
Philips FR975 5.1 Channels Receiver
Can you Help with these Receivers problems?
Repair Service
Find Receiver Repairman Near You:
