Question about GE WSXH208A Front Load Washer
How do I drain the port on the front bottom of the washer
  1. Unscrew it anti-clockwise. It can be quite tough to turn. It will pour water all over the floor, so have towels ready. Another one of GE's brilliant ideas.
Posted on Apr 28, 2010
My whirlpool duet front load has been leaking. It leaks only when doing a load of laundry. Leak is coming out the back and on the right side. Took the front bottom off to see if I can see anything and...
First, make sure that the washing machine is not too close to the wall behind it. This could crimp the drain hose & force water out at the connection behind the machine. This could also crack/split the washer machine's port (to which the drain hose attaches). Second, check the hose clamp for a secure hold at the washer machine's port, & check the drain hose for leaks & for insertion in the drain tube at the wall.
Feb 22, 2015 | Whirlpool Washing Machines
My whirlpool duet will not drain or spin
Hi
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Thanks for contacting fixya.com
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer stopped draing the water
The pump may have stopped running, or a hose is pinched or blocked. Check the hose port at the outer tub bottom to see if a stray sock or something is blocking water drain.
Oct 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a top loading kenmore 70 series washer. It
Sep 13, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Front loader washer is not draining Thougnts? Any thoughts?
Your drain pump might me cloged remove the bottom panel and you will see a clean out port for the drain pump make sure you havea shop vac and open it slow all the water in the unit will come out when you remove it good luck
Mar 29, 2009 | Frigidaire Washing Machines
Not draining or spinning
probably not drain hose ..remove screws bottom cover remove clean out port on pump and clean.. after removing as much water as possible from tub
Nov 16, 2008 | Kenmore Elite 45986 Front Load Washer
Washer stuck in Drain mode, flashes same time, can't unlock control or pause/stop
ck to see if any water in drum if so possible pump clogged ..remove bottom panel pump will have clean out port with large knob turn counterclockwise ..expect flood if water inside but can't be helped if washer is on pedistal open drawer and try setting bucket underneath and have towels handy..after cleaning reinstall port cover and try again..if no water in tub try unplugging hold power button down 20-30 secs and reconnect still have problem door can be unlocked by removing bottom panel and pulling small tab just below lock assembly from underneath
Aug 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer doesn't drain or spin
remove bottom panel dip as much water as possible out if possible lean washer backward to keep as much as possible away from pump inlet remove clean out port plug by turning counterclockwise clean debris from pump impeller
Jun 05, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Jun 02, 2008 | Washing Machines
GE front load washer
remove bottom cover ..remove as much water as possible from inside tub remove cleaning port on front of pump by turning counter clockwise..rmove all money lint screws nails be sure to ck into pump itself
May 28, 2008 | GE WBVH6240F Front Load Washer
GE WSXH208A Front Load Washer Logo
119 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
