Question about Heavy Machinery
I have a 1992 Tecumseh 5 hp motor that will not start. What is the function of the magneto and how does it work
  • 3,740 Answers
Hi and welcome to FixYa I am Kelly. The magneto works like this:
1. Inside the flywheel there is a magnetic portion in one segment. As that magnetic segment passes over the coil or electronic ignition module it generates a field in the primary coil winding that via inductance is transferred to the secondary winding. I.e. it is essentially a "step up" transformer. The breaker points take open and close to control the output of the coil / ignition unit so that the timing is exactly at the Top Dead Center (TDC) point when the piston is all the way to the top of the cylinder head. At which point the spark plug transmits the Spark into the cylinder for combustion.
There are a few safety devices that control the output of the ignition coil by grounding the breaker point wire or electronic ignition module wire.
1. The engine kill switch
2. The low oil sensor
3. On most models the handle control switch i.e the bar you press down on at the handle. That switch is there so that if the user lets go of the handle the engine will shut off.
Any one of the 3 can cause the engine not to have spark.
Other things that can cause it are
1. a failed ignition module.
2. a grounded high tension lead (Plug wire)
3. any chassis ground on any leg of the safety circuits.
4. the actual spark plug having a cracked ceramic dielectric or internally grounded.
5. on a newer chipper / shredder there is a chute safety switch that must be made when the chute is installed.
Most all of the above are "ONE wire circuits and each of them are there for user safety. Any ground any where will cause it not to start.
If you get to the point you think the oil safety switch is the problem disconnect ONE of the output leads and check for spark.
Most often the problem for these engines is they have sat idle off season and when the use tries to start it for the next seasons use they are fussy.
What happens is when unit was stored if the piston was not at TDC one of the valves stays open and then corrosion attacks the valve stem and it sticks open with an end reault of little or no compression.
Also what happens is the last seasons fuel can dry out and turn into an almost varnish like substance blocking carb fuel or air passages.
If you need help with "how to" clean the carb passages correctly just respond here and I will pass that along also.
Thanks for using FixYa,
Kelly
Posted on Apr 26, 2010
  • Kelly
    Kelly Apr 28, 2010
    Hi again, I am just doing a follow up. Were you able to get your engine started? If not is there anything I can help you with? I will be watchng for any response and will gladly assist you iff you need it.
    Thanks,
    Kelly
Is it hard to change a magneto on a 5.5 hp Tecumseh engine?
How old is the gas in the tank? If it is older than 2 months drain it out and put in fresh gas and try again. Have you seen spark jump across the spark plug gap? To check for spark I use a spark checker. One end goes to the plug and the other to the spark plug lead. If you have spark you see a light flash which is more easy to see.
Sep 16, 2014 | Tecumseh Engine 5.5hp Horizontal OHV MTD...
Tecumseh troubleshooting
Three things, the magneto is faulty, the circuit is grounded, the plug wire or boot is faulty. A quick test is to remove the small ground wire from the magneto (usually black), if you then get spark the circuit is grounded by a safety switch or a bad wire segment. If not remove the spark plug rubber boot and remake the connection, if you get spark you've fixed it and if not you need a new magneto.
Jul 29, 2014 | Tecumseh Garden
Have a 7 horse Tecumseh motor has spark that comes and goes cleaned magneto and the key still the same
Your positive that its spark? I'm not sure how you proved that. How bout gets up to temp the magneto may overheat and stop working, its a 50 dollar or more gamble. Check an automotive store and pick up an "INLINE" neon spark tester. 20 bucks and it works on everything. "Prove your guess" I guess :)
Apr 13, 2014 | Garden
Tecumseh coil flywheel gap
Use a business card to gap the magneto to flywheel. That dimension will work for 99.99%, and I can't tell you which one does NOT work...
Surface rust will not affect the coil function.
Oct 16, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Tecumseh small engine troubleshooting
Check point gap---gap to magneto/ fly wheel ---condenser--HT lead. switch wire is not shorted out.
Apr 22, 2013 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Magnet location on flywheel of a tecumseh 4 hp on a Ariens snow b
what is going on with the magnets on flywheel or are you talking about the magneto ( coil)
Jan 13, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have what I think is a tecumseh 9 h.p.gas engine with electric 110volt starter,how do I identify this motor,the only numbers I see on the motor are on the crank case#19-0-201 on the electric starter#2244...
To identify the engine, look on the blower housing (the half round - half rectangular piece covering the flywheel), the numbers should be stamped into the metal somewhere.
As for the magnets inside the flywheel, if you are talking about the ones that go against the inner circumference, you cannot replace them. They have to be in an EXACT location to retain the balance of the flywheel and if they are for the magneto they have to be located so that they trigger your spark at the exact right timing of the engine. Best solution is to purchase a new flywheel.
Sep 15, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh 8 hp tvm220
it is a standard magneto fired engine --- go on line and google up magneto
Jun 22, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
My tecumseh 5 hp engine will start but then after
Hello:
Operate the Engine Unitl it Quits and then Check for Fire to the Plug.
If No Fire, then the Ign Coil/Module Requires Replacing.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Spark plug gap
All these engines have a magneto ignition. The faster the mag spins the higher (better) the sparkplug voltage. So the gap is only set for the ease of starting and is not a huge part of tunning as it is on a car. Try .020 inches.
Mar 21, 2009 | Garden
Heavy Machinery Logo
801 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
