Question about Garden
I have a sears 1 hp 4 gal compressor. (Mod) 919.152145 I can hear hissing under the plastic housing, like an air leak. I cannot see how the plastic housing comes off so I can check for a leak.
  • 1 more comment
  • Steve Engberg Apr 27, 2010
    Top slid off just like you indicated. Thanks... But how do you get the two plastic halves of the cover apart to get inside?
  • Steve Engberg Apr 28, 2010
    Thanks... stopping by Sears parts store tomorrow to see what kind of head is on the screws (if I can't tell)
  • 8,197 Answers
There are screws that hold the plastic case together. If you go to the link below on page 22 shows you how it comes apart. Please give it time to load large file.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0503291.pdf
Posted on Apr 27, 2010
  • 8,404 Answers
Turn it over ... you will find two screws that lock the top into the slide that holds it. Remove the screws, slip the top to the side and fix your leak.
Posted on Apr 26, 2010
  • A Miller Apr 28, 2010
    there are 4 or 5 screws that hold the top together ... you will probably need a 6 inch or longer screwdriver to reach ...
    welcome
I have a 6 gal, 150 psi craftsman compressor. There is a leak under the plastic housing. How do I seperate the tank from the compressor?
This product manual will show the exploded view on how it comes apart/goes together:
http://c.shld.net/assets/own/00915216e.pdf
Jan 06, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Wont build pressure past 60 psi
If you have oil-less type of compressor you may be leaking pressure past cylinder/piston ring or just air leak. Easy to check. Spray soapy water on all connections, first with pressure in tank and motor shut off, then once again with motor running/pumping. Repair as needed. If no leaks remove cover to motor and move piston to top of cylinder and examine condition. If you see scratches neer top of cylinder, then pressure is leaking past vinyl ring. If cylinder looks shiny and smooth and piston vinyl seal looks intact, suspect problem with reed valves or head gaskets. Parts are avilable at sears parts on the web. Good holidays expensive.
Dec 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
I have an H1506FWH Husky 6 gal 1.5 hp compressor that won't build air pressure. While running I noticed a change in the sound but it kept running. However, I no longer had much pressure. Now I can't get...
Locate the piston housing and remove the outer plate 4 screws
then tap on the next plate and when you remove it ( its the reed plate) you will most likely see a hole in one or more of the reeds
I am not technical but I have the same peoblem and I am trying to replace the reed plate on mine when I saw this. Good luck
Nov 22, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a 3 gal. air compressor mod. 921.153101, what type of oil does this unit take use?
I am sure that Sears has there own oil they would prefer you use, If not a quality brand of SAE 30 is commonly used in these compressors.
Aug 25, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
A/C will only pump 30-40 lbs, but keeps running.
Maybe your unloader valve is stuck or damaged. This is found in the switch assembly and if it is faulty you should be able to hear a constant hissing noise from the switch .
Jun 05, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Craftsman 1/3 hp compressor leaking oil
most defintly you need a head gasket but you will also need piston rings look up your local sears service center not automotive or the store you want appliance service center
Jun 17, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Pressure regulator gauge wont work on my 3 gal. air compressor how do i fix it or where do i get a new one (craftsman) i also lost my book , how often do i change the oil ?
If the regulator is inline you need de-energize the compressor to remove the regulator.
Sears parts and service:
http://www.sears.com/shc/s/c_10153_12605_Home+Services_Repair+%26+Maintenance?adCell=W4
Compressor Information:
http://www.sears.com/shc/s/c_10153_12605_Tools_Compressors+%26+Air+Tools
Wiki Buying Guide for Craftsman Regulators:
http://www.shopwiki.com/search/Craftsman+Regulator+with+Gauge
Sears / Craftsman Forum & Repair Information:
http://www.sears.com/shc/s/nb_10153_12605_NB_CSHome
3rd Party Regulator Retailer:
http://www.controlair.com/
If you feel that your problem is too serious for you to repairyourself, please contact a licensed/certified technician.
If you wish,you can call Sears HomeCentral at 1-800-4-MY-HOME tomake an appointment for a technician to visit. (There is a charge forthis service.)
Mar 11, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
