Question about KitchenAid Dishwashers
Model KDSS-21A has an error message that reads r5.
Kitchenaid dishwasher model KDSS-21A has an error message that reads r5. The dishwasher will not run other than to cancel. What does this mean?
Kitcheneer
  • 11 Answers
SOURCE: Error Message coming up
Hi, i work on these machines on a regular basis and until very recently i was a Meiko service engineer- the code ERR203 means that there was no change detected at the boiler level switch during emptying- be it on the fill or rinse cycle. This fault is mostly caused by the booster pump failing to pull water but could also be caused by blocked rinse jets or a faulty boiler level switch. Hope this info is of use to you , Kitcheneer
Posted on Feb 05, 2007
voodoomox
  • 1689 Answers
SOURCE: KITCHENAID KDC-21A - Julie Ohio problem
hi Julie, the fuses of the washer is right on the control board, you may refer to the picture and the link i osted in your previous thread to exactly locate it.
Posted on Aug 10, 2008
IrishDruid
  • 2712 Answers
SOURCE: ////////////////////my kitchenaid dishwasher lights are flashing
Can you explain the issue in detail - is your dishwasher not working at all, or the buttons continue to be lit up, etc?
First and foremost, check the dooe switch to see if it is functioning properly.
Posted on Nov 26, 2008
s_4u_11
  • 535 Answers
chk the switch of ckt bord or chak the pannel of ur dishwasher
Posted on Nov 27, 2008
  • 3 Answers
SOURCE: My normal cycle and cancel button lights are
Probably a keypad gone bad. Try replacing the keypad.
There is a troubleshooting guide behind the foot kick panel. It gives a sequence to test for a bad keypad. You can try that sequence to be sure.
Posted on Apr 27, 2009
Cancel Light Flashing on Kitchen Aid Dishwasher
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Sep 21, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
I have a Kitchenaid dishwasher model KUDC10IXWH0 that has a problem. It will not complete the wash cycle. It runs for about 15 minute and then goes to cancel/drain cycle. The code on it is 6-1. Any...
Hello Carol;
My name is Peter. I am a retired field service appliance technician.
I am going to ask you to do a diagnostics and then get back to me.
Search:
4317364_kad-9_kitchenaid_drawer_dishwasher.pdf
Dec 23, 2014 | KitchenAid Dishwashers
I have a kitchen-aid dishwasher model # KUDio1ibl6 and it will not come on and the clean light flashes 7 times then pauses and blinks 7 time again. Do you have any Idea what this code stands for I do not...
Hello Asa,
The light blinking seven times is a error code specifically it's error #7 .The E-7 error indicates the part called the flow meter is bad. To clear that error code and get the dishwasher to start push within 3 seconds
HIGH TEMP WASH -HEATED DRY-HIGH TEMP WASH- HEATED DRY
then push CANCEL sereval times to dishwasher shuts off..it should start and run then
If the blinks 7 times again the flowmeter will need to be replaced
ON some models the "HIGH TEMP WASH" button is labled power scrub instead of high temp wash
so in that case push POWER SCRUB-HEATED DRY-POWER SCRUB-HEATED DRY then cancel as described above
In case the E-7 error returns and the flowmeter needs to be replaced the part number for it is W10195536
Gene
Aug 24, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Clean light keeps blinking and washer will not function. Cancel runs the pump for 2 minute, but the blinking light keeps going with no functions working.
if the clean light is blinking that mean you dishwasher is having a heater issue. it is an error code. either your control board is bad or the heater or the ntc therm. if you take the bottom panel off you will see or should see a tech sheet that will tell you how to clear the error code or this website will help you. just enter your model number http://servicematters.com/docs/wiring/wiring_main.htm
Jul 03, 2010 | KitchenAid Dishwashers
My normal cycle and cancel button lights are blinking on my kitchenaid dishwasher. Model # KUDP02CR8S2 Any suggestions?
Apr 20, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid kudso1dlss3 clean light flashing cannot do a new cycle
I do not have the same model as you, my model is KUD01ILBS6 but I have the same problem. A service tech told me it was a error code and here is how to fix it.
1 open the dishwasher door
2 hit high temp scrub button
3 then hit energy saver dry button
4 do step 2 & 3 again
5 close the door
6 hit the cancel button
7 you can hit cancel button again then try to start your dishwasher
This works for me, you may have to do this every few months because there is a glitch in kitchenaid where if the water temp is not sensed right it will keep the dishwasher from working. It took me 3 service calls to find this out.
Jan 17, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Aug 10, 2008 | Dishwashers
Clean Light Flashes
Oct 07, 2006 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
