Question about Roundup Garden
I have the 2 gallon sprayer the tip of the spray wond snapped off I need to find replacement ends for my wond
  • 3 Answers
Generic parts can be purchased from Home Depot or Lowes. I do it all the time. Might have to modify and "make them fit" but usuallt it isn't too tough. Or, just keep an eye out this time of year for people throwing defective sprayers away. Might be able to use parst from their sprayer to fix yours.
Posted on Apr 27, 2010
I have the Ortho Dial and Spray and am applying the Round-up Weed and Grass Killer. States a 6 oz feed rate per gallon and that this should cover 300 sq.ft. I pour 24 oz into the container which should...
I'm sorry to hear about the problems you had with the Ortho Dial N Spray. This hose end sprayer empties about 2.1 gallons per minute, so you will need to walk fairly quickly to cover area you're wishing to apply product to. Please give Ortho a call at 877-465-5160, and we will be happy to assist you further.
Hilary @Ortho
Sep 03, 2011 | Ortho Dial N Spray Hose End Sprayer
I am confused. Your driveway weed killer says 1 quart per one gallon of water, and the dial n spray has just ounces on the top up to 8 ounces and up to 32 ounces to be filled on the side of container....
Hey, sorry for the confusion. Actually Ortho GroundClear can not be used in the Dial N Spray Hose End Sprayer because this sprayer will only dilute up to 8oz per gallon. This dilution rate is not enough for the product to be effective in keeping the area clear of vegetation. Hope this clears it up.
Hilary @ Ortho
Aug 21, 2011 | Ortho Dial N Spray Hose End Sprayer
What setting do I use on my ortho dial and spray for fertilizing plants and vegetables outdoors? Thanks
If you are using Miracle-Gro Water Soluable All Purpose Plant Food in the Ortho Dial N Spray Hose End Sprayer, follow the directions below :
  • Set the dial to 4 oz
  • The sprayer can make up to 8 gallons of spray. Add the correct amount of product to the jar for number of gallons you wish to make. (Example - The dilution rate is 1 tablespoon per gallon, and you want to make 8 gallons, put 8 tablespoons of Miracle-Gro Plant Food in the jar.)
  • Multipy 4 by the number of gallons you are making and fill to that oz line (Example - If you are making 8 gallons, 4x8=32 so fill to the 32 oz mark with water).
  • Prior to spraying, mix product around in the jar until granules are dissloved.
  • Spray until the jar is empty.When it is empty, you have sprayed 8 gallons of product.
If you any questions or if you are using another product, please give us a call at 800-225-2883, and we will be happy to figure out a setting for you!
Jul 05, 2011 | Garden
How do i get the spray to come out in a fan shape. The model number I have is 1125D.
You need to consider what materials you will be spraying. Wet table powders and sprays with relatively high solids contents will work better with a diaphragm pump than a roller pump. For tanks, plastic should be fine unless you are spraying materials which will react with the plastic. If you are concerned about it getting banged around, consider welding a roll cage or some bumpers around the tank. With 2 acres to spray, the sprayer will not be getting heavy use, so you won't need super heavy duty equipment.
Check out this video:
http://www.youtube.com/watch?v=5_yE8o6vnMg
Please get back to us if you have any further query or else accept the solution.
Oct 31, 2010 | Rl Flowmaster Rl Flo Master Proplus No...
Using Ortho weed and crabgrass concentrate... what setting do i use on my Ortho hose end sprayer
Here is what they say at their site:
How do I use the Ortho Dial 'N Spray Multi-Use Hose-End Sprayer?
Pour product into jar, and set dial to amount indicated on product label and begin spraying. This sprayer siphons product and mixes while spraying; it does not mix inside the sprayer.
http://www.scotts.com/smg/catalog/productTemplate.jsp?bodyCssClass=scotts+blade+scotts+product+faqhelp+en&tabs=help&navAction=push&bodyId=product_faq_help&proId=prod70022&title=p_product_general_help_title&itemId=cat50094&id=cat50008
Which means it is not determined by Scotts, but by the product you want to disperse with the Dial N Spray.
And here is an exact description of the settings:
{ ... There are 14 settings in all and they range from 1 teaspoon per gallon up to 8 ounces per gallon. You will find the dial at the on the top of the sprayer. ... }
http://www0.epinions.com/review/Dial_N_Spray_Hose_End_Sprayer/content_465229876868
Aug 19, 2010 | Ortho Dial N Spray Hose End Sprayer
I need the owners manual for the ortho dial n spray hose end sprayer.
From forums.gardenweb.com
"The instructions on Ortho Garden Disease Control (Daconil) give directions for use in the dial and spray. Set dial at 4 Oz. Add 1 TBS Daconil and 7 TBS water for each gallon you want. I am using the dial and spray and don't see as much residue as when I was using a pump spray.
Jul 03, 2010 | Ortho Dial N Spray Hose End Sprayer
Sprayer valve is clogged
I've had some success by removeing the entire trigger mechanism and soaking it in solvent for a few hours.
Mar 23, 2010 | Rl Flomaster Acid-Resistant Sprayer...
The spray unit bent and broke...
Lowes or Home depot sells replacement sprayers. Hose to tip all included.
Aug 18, 2009 | Stanley Professional Backpack Poly...
Instructions for using ortho tree sprayette
The Ortho Tree and Shrub Sprayette has a fixed mixing jet set to a 24:1 ratio. 5.3 ounces of spray concentrate in the jar will mix to produce 1 gallon of diluted spray. The jar has a capacity of 42.7 ounces, so you can spray up to 8 gallons with 1 filling. If you look at the side of the jar, you will see two filling scales. On the left is the diluted spray capacity, and on the right is the concentrate scale. So you will see 8 gallons opposite 32 ounces, for instance.
You must dilute concentrates to the 24:1 mixing concentration. So if your concentrate says 1 ounce/gallon, and you want to spray 6 gallons, put in 6 ounces and add water to the jar to the 32 ounce level.
Mar 16, 2009 | Garden
Sprayer Question
Hose end sprayers are the simplest and least expensive of the category. A sprayer jar is attached to a regular garden sprayer. Concentrated material is added to the sprayer jar. An adjustment on the jar determines the amount delivered. The force of the water through the hose pulls the material up from the jar and mixes and dilutes it with the water. A built-in anti-siphon device prevents unused material from being pulled back into your water supply. Compression or tank sprayers are the most common type of spray equipment. Concentrated material is added to the tank. Water is then added to a marked fill line. The remaining air is pressurized by pumping the handle a designated number of times. A control lever on the wand controls the spray pattern and amount. Compression sprayers provide a precise, on target, non-drift spray good for soil and lawn pests. Adjust the sprayer for a coarse, drenching spray, a concentrated stream or a fine mist. Tank capacities range from 1 quart to over 3 gallon for handheld models. Homeowner type backpack sprayers hold up 4 gallons. The tanks may be made from polyethylene plastic, galvanized steel or stainless steel. In addition to treatments for pests and diseases, compression sprayers are designed for applying cleaning solutions for decks and siding. Backpack sprayers are operated in the same manner as the handheld compression sprayer. The over-the-shoulder configuration makes it easier to carry the heavier load of material. Some backpack models also use a lever-style pump to maintain pressure without removing the unit form your back. Powered sprayers rely on a gasoline engine for spray power. Great for larger yards or gardens due to portability and capacity (12 gallons). Dusters are a slightly different breed. Dry powders (mostly for blooming plants such as roses) are added to a canister and applied by manually pumping. NOTE: Compression sprayers deliver liquid under pressure. Compression sprayers are powerful and efficient tools. This fact also makes them potentially dangerous. Always read the manufacturer's instructions and safety precautions carefully.
Aug 27, 2008 | Sp Systems 02sv320065 Farm & Home 2 -...
Garden Logo
365 people viewed this question
Top Roundup Garden Experts
Nick Olsen
Mike
Are you a Roundup Garden Expert? Answer questions, earn points and help others
