Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Engine not starting
I have a craftsman 15.5 HP 42" deck lawn tractor and my problem is
it is not trying to start at all. It did try to fire over before it did absolutely
nothing not even a click. I installed a solenoid & starter and I am still
getting nothing. I also tried to jump start this mower with my pickup
truck for 30 mins. I had the seat up but,you should be able to start
this mower as long as the clutch is depressed all the way in and you
have it locked into place which I always do.It acts like it's not getting
any fire to the starter at all. I'm not sure if it might be the kill switch
under the seat or the wiring harness is totally bad but I need a solution
to the problem. The model & serial numbers are listed below for reference.
Model No.917258473
Serial No.o62597C003426
    Sniper:
  • 52 Answers
It sounds like no electricity is making it to the starter. Several things may be wrong. Check to see if the fuse has blown. It should be behind the dash. Your starter switch may be bad. You can unhook it and use a jump wire from the positive side of the battery to the wire connection on the starter to see if it will turn over. The switch under the seat that detects someones sitting on the mower could be bad. You can unhook it and place a piece of wire in the connections to make a complete circuit then try to start it.
Posted on Apr 26, 2010
42 craftsman rider electricity at solenide non at starter.
Check power at solnoid on cable coming from battery. 12-13V. With key turn to start should have 12-13v
May 22, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
17.5 intek engine will not start, engine has fire and gas. craftsman LT2000 42 in deck lown mower
Is the flwheel key ok? Or you may problem like me. Pull
valve cover and see if both pushrods move.
Jul 19, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 917.270514 not starting?
check to see if your getting power to the solenoid on the bottom of the carb a bad safety switch will shut it off they also stick closed from old fuel
Jun 04, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman 42in rider quits after about 30 to 45 minutes. The carb solenoid is good and the gas cap is venting ok. I have to wait about 20 to 30 minutes before it will start again. What should I check...
try the coil,does it get fire to the sparkplug after it quits and what color is the spark? blue spark is good, red is weak fire, and not enough to fire the engine up.
Jun 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman rider wont stay running
Once having the same problem with the B&S engine, I had to replace the ignition coil. When it is in the process of failing, it acted as you describe.
Apr 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
18.5 42 LAWN TRACTOR DOESNOT START.
it probably blew the 30 amp fuse between the solenoid and the starter.
Mar 06, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Nov 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
247 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
