Question about GE 24 in. GSD6660GSS Built-in Dishwasher
DISHWASHER BEEPS,WON'T RUN.
WE RECENTLY LOST ELECTRICTY,DUE TO A STORM.EVERYTHING IS ON AND WORKING,BUT MY DISHWASHER.BEEPS WHEN I CLOSE IT,DOES NOT WANT TO RUN.i HAVE A GE TRITON,GSD5500GO2WW.CAN ANYONE HELP?
SOURCE: GE Nautilus Dishwasher No water when i turn it on
You need to prime the dishwasher by placing two large cups of water into the bottom.
Posted on Jun 18, 2008
SOURCE: I have a ge triton
Open the dishwasher
Remove door panel
Look for a switch with 2 spade lugs attached
Make sure the 2 wires are not broken or corroded
Use a tester to verify switch opens and closes.
replace switch and your problem should be solves
Posted on Dec 21, 2008
SOURCE: GE Triton not working
Jitterbugclu-
I may have the solution. Husband just turned off power to dishwasher via circuit breaker. Waited around 30 minutes.
Restored power and Triton came back with normal lights.
I just ran a cycle and all was well. Hope this helps you.
My fingers are crossed because I don't know what happened but did read on another site that this should be the first thing you try before expen$ive repairman.
Reply back if it works!
TootieC
Posted on Dec 29, 2008
  • 111 Answers
SOURCE: ge triton xl dishwasher
The part you need is a WD13X10008 from GE Parts 800-626-2002 or order online at GE Consumer Service web site here
Posted on Jan 02, 2009
I had same problem....turned off power breaker for 5 minutes and when I turned it back on lights were fine and dishwasher works fine.
Posted on Apr 22, 2009
The machine keeps tripping the electricty
Was this a recent thing? Have you had the dishwasher in that same spot before with no problems? It sounds to me like you have to many amps coming from that room, or your breaker is getting weak and needs to be changed out. Most likely a 20Watt Ge breaker or Square D breaker or Siemens.
Mar 14, 2015 | Dishwashers
Dishwasher beeps but won't run
There could be several reasons for the beeping. The dishwasher checks for sensor to make sure it is in good health before it starts. Most likely the drawer close sensor is detecting fault. This is to ensure the drawer is closed fully to avoid water leaks when dishwasher is on. Sometimes sensor itself has failed and has nothing to do with position of drawer. Open top cover carefully to make sure the drawer is travelling ok on the rails. TAKE MAINS POWER CABLE OUT BEFORE WORKING ON DISHWASHER.
Mar 17, 2013 | Fisher and Paykel DD24DCTB6 Builtin...
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
Elctrolux dishwasher won't start, display won't light and it randomly beeps
Check continuity of the 4 small wires that connect to the control panel to the control board. They seem to break where they flex for the door to open and close.
Jul 25, 2012 | Electrolux EWDW6505GS Fully Integrated...
91 Geo Storm Gsi running just fine, one day I lost power driving 65, check engine light came on and was flickering, mph arm going up and down but didn't die then. Then it was ok.That happened 2 times...
Most engines don't fair well under extreme heat. It's apparent you might have some electrical issue's. Your rpm's or mph arm going up and down could be faulty speed sensor would cause arm problem. I think you may have more than one problem, the car shutting off is due to engine over-heating. Check cooling system-thermostat, water pump, radiator, engine fans and coolant temp sensor and fan relay's. It could be as simple as blown radiator hose.
May 12, 2012 | 1991 Geo Storm
Brand New Whirlpool Dishwasher won't start, can't change program eiether
Make sure the dishwasher door is firmly closed, press and hold the start pause button for about 5 seconds, this will clear the cycle, The try selecting a wash cycle and push start.
See if this helps.
Mar 04, 2012 | Whirlpool Dishwashers
I have a ge profile dishwasher model pdw9280j00ss. After a storm event, house lost power. Since that time, dishwasher constantly beeps; however has no power to it. shut off circuit, beeping stops; but...
http://www.geappliances.com/search/fast/infobase/10000380.htm
According to this link, it should reset after the power is shut off for awhile. Maybe try holding the start/reset button too. Also check the circuit breaker or any fuses
Aug 28, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher was scrolling through some sort of menu and beeping
Looks like the electronic micro controller fault.Due to power surge this could have resulted. It is bad luck!
Apr 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Maytag Dishwasher not working right after storm/power loss
With the unit switched on , switch off power at the wall switch for a few minutes , this should reset the computer , if not you will need a service call.
May 03, 2017 | Maytag MDB7100AWB Dishwasher
GE 24 in. GSD6660GSS Built-in Dishwasher Logo
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
