Back to:
Tags:
Toshiba DP2570 Printer
FAULT WITH MY DP2570 PHOTOCOPY MACHINE
posted by Wekesa on Mar 24, 2008
My copy had been scanned to produce about 1000 copies.After it had finished,I wanted to photocopy another single copy;to my suprise it produced a very black copy and there after displayed'CHECK MAIN CHARGER'.Wherever I switch it on,it displays the same message.What should I do to have it right.Thanks
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 13, 2008
Not Rated (0)
disastertech
Rank:Wiz Wiz
Rating: 84%, 30 votes
This means the corona wire is broken and only be repiared by the service tech
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on FAULT WITH MY DP2570 PHOTOCOPY MACHINE:
I don't want to Accept this solution
Can you Help with these Printers problems?
put new toner in copier - copies r still light &...
What is an Error C55 Message and what should i do? Thanks.
we put an empty container on but still get the same error
Where is the ethernet plug on the SC-1. I've looked...
Hello, We have installed a new workstation. The printer...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
