Question about HP LaserJet 6L Printer
Paper feed feeds more than 1 sheet at a time
HP 6L - paper feed feeds more than 1 sheet at a time - up to 10 sheets
  • HP Master
  • 1,684 Answers
he problem you are having is caused by a worm separation pad assembly. This assembly is what separates the paper into individual sheets. It takes about 30 minutes to disassemble the printer and replace the part. Most printer repair shops will do the repair for you but the cost may be a bit much. If you are interested in doing the repair yourself we do stock the part. We can provide the separation assembly and a service manual on CD that gives directions for replacing the parts plus other information about the printer. The part and guide runs $14.95 plus shipping. Let me know if you need one, tech
Posted on Apr 27, 2010
  • Buddy Mcsparrin Apr 27, 2010
    Our contact info is tech@ccl-la.com or 318-447-9040
    CCL_Tech
    Corporate Computer
    www.ccl-la.com
Have an HP LaserJet 6L. Just got through replacing all the rollers inside. Can get it to grudgingly print one sheet, then no printing after that one sheet, it often just grips the paper, but won't...
You need to make sure that you have the clutch that the solenoid interacts with seated properly. I had a tech once manage to get the clutch on at 180 degrees from correct alignment, not sure how he did it, but the printer would not print. It is possible if you are not paying attention to mount the pickup roller in the wrong position which will lead to feed problems. You need to make sure that the highest point on the roller is touching the paper when at the right time.
Aug 07, 2011 | HP LaserJet 6L Printer
Riso V800
Riso's are famous for this, i will scrub the rubber timing roll with rubber rejuvenator and clean the steel roll with alcohol.The riso paper feed clutches are weak compared to what they were in this series you may have to replace the clutch. Bud, after doing some research you need to clean the oneway bearings on the pickup and feed rolls, adjust feed table hieght and lastly check/adjust timing in drive and feed roller-you will need a manual for this.
Hope this may help;
Regards,
VOTIT
Jul 25, 2008 | Riso RZ220 Duplicator
PAPER WON'T FEED PROPERLY. GRABS SEVERAL SHEETS
You need a seperatin pad, sub pad kit and new feed roller.
May 20, 2010 | HP LaserJet 1100 Printer
The printer is feeding a blank sheet of paper between printed sheets. How do I rectify this?
This causes the printable area on the page to be that much less (10 3/4 or 10 1/2 on an 11 inch page). The software thinks the paper is 11 inches long and keeps track, down to the micro inch, where it is on the paper. When it reaches the 10 1/2 inches, your printer calls the page done and ejects it. However, the software thinks there is still another 1/2 inch to print (usually the footer area). Now when you insert a new sheet of paper, the software finishes printing the rest of the page (normally a blank footer) and form feeds to the next sheet. To correct what the software thinks the paper size is, you need to run the Preferences application and change the default settings. Select the Printer button. In the next window, select the 'Change Defaults....' button. Change both the Document size and the Paper size to a height of 10.875 and click OK. Try a new document to see if the paper size is correct. You may need to go back and change the height a few times until it is correct (the height changes in .125 increments). Usually either 10.875 (for 1/4 inch forced top margin printers) or 10.75 ( for 1/2 inch forced top margin printers) will work.
Oct 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
Will not feed paper of any size. No jams ever.
clean the feed rollers with water and soft cloth.. try a stack of paper not a single loose sheet
Aug 15, 2009 | Epson Stylus 1400 InkJet Photo Printer
HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Brother HL 2070N red paper light blinks but won't print.
Just fixed my printer issue, had the same problem, Would load 1 sheet, then jam, sometimes it won't pull the paper out of the tray, sometimes it would pull the paper to the toner area, but never into the toner, opening and slamming the paper tray while it attempted to load would usually work, but who wants to slam the tray 50 times? I was using Walgreens generic paper, 20lb, took some higher-quality 24lb HP paper and VOILA! It works every time! EVERYONE WHO IS HAVING THIS PROBLEM, CHECK THAT YOU ARE USING 24LB PAPER!!! Brother says 20-24 is acceptible, but sneaking one sheet of 20lb paper about 15 sheets down in a 20 sheet print job and it will stop at it every time, You can feel the difference, less like toilet paper and more like real paper.
24 LB PAPER! USE IT NOW AND THANK ME LATER!
Jun 27, 2008 | Brother HL-2070N Laser Printer
Feeds more than 1 sheet
Yes, I have had the same problem at times. The best solution is to 'fan' the paper well (put air between the sheets) BEFORE putting it in the tray. Also, tap down the front edge of paper (that enters the printer) to align the sheets better. You can also clean the rollers with a damp rag to help traction. Hope this helps!
Apr 17, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP LaserJet 6L Printer Logo
546 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
