Question about Gateway T-6330U Notebook
Cd's will not play - Gateway T-6330U Notebook
    Novelist:
  • 142 Answers
  1. Click Start
    , type regedit in the Start Search box, and then click regedit in the Programs list.
    If you are prompted for an administrator password or confirmation, type your password, or click Continue.
  2. Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
  3. In the right pane, right-click UpperFilters, and then click Delete.
  4. Click Yes to confirm the removal of the UpperFilters registry entry.
  5. In the right pane, right-click LowerFilters, and then click Delete.
  6. Click Yes to confirm the removal of the LowerFilters registry entry.
  7. Exit Registry Editor, and then restart the computer.
Posted on Apr 26, 2010
  • octojofo59
    octojofo59 Oct 03, 2012
    Excellent! That actually worked. Thanks!
  • octojofo59
    btw, why DID that work? Seriously, it always worked and then one day, wouldn't...
Why won't bose play some cds
Could it be the CDs you can't play, are burned in a PC?
Not all CD players can or will play CD's burned in a PC. Sometimes the CD player is to old, so not compatible with these CDs. Sometimes the player just does not play these CD's, because of rights protection.
A CD burned in a PC is less reflective than an normal music CD. Normal CD's do have a metal coating and are highly reflective. Burned CD's have a dye, and where the laser burned the dye, it only changed colour. Making it less reflective.
All modern CD playes should be capable of playing CD r's. But the player that is really compatible, is labelled CDr and CDrw compatible.
May 13, 2014 | Bose Wave music system Multi-CD Changer...
I have a Technics CD changer SL-PD867 it will not play re writable disc's any other disc ok
May 11, 2014 | Technics SL-DZ1200 CD Player
Why will my xbox let me play some games but not other on live when i used to be able to play them all?
Check all X Box games for scratches on the surface of each CD Disk.
Keep in mind, each game CD is read by lens Laser from the inner then to the outer edge of CD Disk.
Most people believe CD's are played like a record, from the outer edge to the inner.
If there are scratches, CD may be damaged beyond simply cleaning.
All cleaners and methods of cleaning are not the same.
Contact the manufacture of the CD to find out the best method of cleaning
or possibly repairing so game can be played.
If you CAN play some games and NOT others, this rules out a Laser Lens Player fault condition. Look for a reason of the CD will not play in the Laser Lens Player.
Here is the top 5 reasons CD's will NOT play.
1.) CD in inserted into player wrong way?.
2.) CD surface is dirty or dusty?.
3.) CD is possibly warped or bent?.
4.) CD surface is scratched?.
5.) Wrong CD/ or format for CD player?.
Hope this lists helps!
FASTESTNASCAR
Jan 01, 2012 | Microsoft Xbox 360 Console
Magnavox AZ9855 mini system (7 CD changer), trying to play a cd, the system ejects the CD and message Failed CD is shown. No CD will play.
Hi,when a system eject a CD and with a message "failed CD" It caused by the CD mechanisms that allows the CD to play to damaged that's why the CD keeps on rejecting the CD's being inserted into the CD player.
When you replace the CD mechanism that allow CD to play, problem solved.
Take care.
Oct 06, 2010 | Audio Players & Recorders
When I burn a music cd it will not play in my sterio or cd player, it only plays on the laptop. Can you tell me what to do to fix this.
Make sure the players can play the format you are using to burn. My surround sound system will play most audio but my car system will only play an origional cd format (AU) not mp3 or wav for example. Also some systems will not play cd-rw but will play cd-r and some won't play anything but origional cd's.
Aug 03, 2009 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
CD player can't play recorded audio cd's
That sounds right, some of your cd players will not be able to play recorded cd's . It's lame, but that's the way it is. Sorry.
Jun 17, 2009 | Audio Players & Recorders
Left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
Jun 01, 2009 | Jensen Car Audio & Video
CD palyer will not play all Songs
It sounds like the CD has to be initialized, so the jukebox knows how many songs are on the specific CD.
To initialize a CD, go into service mode, input code 31, then index the cd number (two digits), then hit "popular". return the jukebox to play mode.
The carousel should scan and load the CD you initialized, and then return it to it's slot.
It should now be able to play any song on the CD you select.
Mar 05, 2009 | Wurlitzer Jukebox CD Player
Rowe CD 100 that will not play all Tracks
Are you initalizing the CD's in your jukebox after you install them?
If so it should play all of the tracks.
Regards
Alan Hood
ami-man
UK
Feb 01, 2009 | Wurlitzer Jukebox CD Player
A copied CD why will it not play in a certain make of car
It is probably because the CD player in that car will not play Cd's recorded on a computer or home CD recorder. There are lots of CD players out there like that still. You will need to get a car stereo that plays CD-R and CD-RW. That is the only solution.
Jun 29, 2008 | NAD L40 CD Player
Gateway T-6330U Notebook Logo
47 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
