Question about Sony Handycam CCD-TRV65 Camcorder
Will not turn on, with battery our power cord...
  • nysp1916 Apr 28, 2010
    I have no ideal of where the main board/fuse are located or how to check it for power. please explain...
    Thanks
    Champion:
  • 287 Answers
See if the main board is getting power. Then check the fused on the main circuit board to see if they have unregulated voltage to them , They all say 14 on them for 1.4 amps. Larry's Electronics
Posted on Apr 28, 2010
  • Larry Stiles
    Larry Stiles Apr 28, 2010
    Sure, I'll try and explain. The main circuit board is the largest board in the camcorder . The battery terminal board plugs into the main circuit board. You will need a volt /ohm meter to go in and check for open fuses and to see if voltage is getting to the board. Are you willing to go this far in the efforts to fix your camcorder? It's up to you. Before you going tearing into your camcorder make sure the acaptor is not dead and puts out about 7 volts. Larry's Electronics ledstiles@hotmail.com
Computer charges but doesnt want to start up
Remove battery
unplug power cord from laptop
press and hold power button for a least one minute while power cord and battery are removed
insert power cord only
turn on laptop
laptop should turn on without battery installed
if it does not turn on you probably have some motherboard issues
then install battery if it still does not turn ...and try to turn on
it still may turn on...I have seen stranger things happen with computers
you may also want to try another power cord if you have an extra...the power cord may not be allowing enough power to travel thru cord
Feb 15, 2014 | Toshiba Satellite Computers & Internet
Older Toshiba laptop runs on battery, but not AC cord.
on some older laptops the battery has to be installed for it to turn on.
if the battery don't hold a charge it's no good.. but you need it to get power from plug.
Jan 04, 2013 | Toshiba Computers & Internet
My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
May 15, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
Why is my acer emachine charging blinks in red
That is a signal that your battery is almost dead or drained. If you have the power cord plugged in and the battery is not charging at all, that means the battery is dead and you need to purchase another one.
In windows xp you should be able to click Start/Control Panel/Power Options. When the power options window opens click the Power Meter tab. It will tell you if your battery is charging.
Now to isolate if it's really the battery that's dead or if it's the Power Cord that's bad. You might really be operating on battery power even though you have the power cord plugged in.
1) Turn the laptop off and remove the battery. Turn it back on with only the power cord plugged in. If it comes and and boots up ok, then your power cord is ok.
2) Turn the laptop off and this time put the battery in, but leave the power cord off. Now hit the power button and see if it boots up. If it does that means you might have a little power still left in the battery, but since it was not charging when the power cord was plugged in, the battery is bad because you verified in step one that the power cord is good.
Mar 21, 2012 | Computers & Internet
Power is going to laptop but it will not turn on. Was just using it w/out power cord. Plugged power cord in and it won't turn on. Tried, Alt, ctl, delete but nothing...:(
Try switching the outlets that you're using the power your laptop. You may have a faulty outlet which could be why it isn't giving off any power to the power cord. Next, try unplugging your power cord, then taking out the battery, plugging back in the power cord and turning your laptop back on. If the laptop turns on, the problem may be with your laptop's battery. If the laptop still doesn't turn back on, put the battery back into your laptop, and see if it works. If it still doesn't work, try taking it to a place like Geek Squad in Best Buy.
Hope this helps!
-Anonymity
Feb 25, 2011 | Toshiba Satellite C655S5085 Notebook
My computer won't turn on or charge.
You need to diagnose the problem.
>First try to take the battery out of the computer and just use the charger to make computer run.
>If it turns on it means that the battery is what's causing the problem.
>But, if computer cannot run using the charger/AC Adapter then it means that we have a problem with the charger.
By doing this diagnostics you know which part to replace.
Sep 30, 2010 | Toshiba Satellite A85-S107 Notebook
Ive got a toshiba 2455-s305 laptop that won't turn on. I've tried it using the power cord, with and without the battery, and when I plug it in it start's flashing in the front, but won't turn on.
Remove battery and disconnect power cord. Press power button for about 5-10 seconds (without battery and power cord) Connect power cord only then turn it on.
Dec 01, 2009 | Toshiba Satellite 2455-S305 Notebook
With power cord plugged in and without power cord plugged in the pc will not turn on
remove the battery, plug-in power cord then power on. your battery may be completely drain and your power adapter can't give enough supply to power up your laptop and charge the battery at same time. if doing so power on your laptop, charge your battery for about 12 hours without turning the power of your laptop
Nov 03, 2009 | ASUS EEEPC901-GP010X Netbook
I cant reboot my screen its all white.
Turn off the pc, disconnect the power cord. Remove the battery. Leave it alone for a few minutes. Plug in the power cord (do not replace battery yet) and turn it on. If it works, turn it off, remove power cord and replace battery. Plug power cord back in and turn on pc again.
Aug 21, 2009 | Dell Inspiron 1420 Notebook
Acer AL1916 can't start
If you press the power button and nothing comes on at all then something isn't providing power to the laptop as it should and you may likely need to replace the battery or the power cord.
Find a replacement battery. Change your battery with a new one then plug it up and turn on to see if this works.
If replacing the battery doesn't work then replace the power cord and trying turning it on again. If this doesn't work either, you have a more serious issue going on.
Not too long ago, I was on vacation, my laptop had been working fine until suddenly it wouldn't come on at all. I went into the office to grab a new battery and power cord. (I work on computers so I had spare parts in my office/Tech Room.)
I got home and replaced the battery then tried to turn it on using the old power cord...didn't work. This was a brand new battery so now I knew that I could rule out the battery as the issue...the only two things left to troubleshoot were the power cord and the laptop itself.
I put my old battery back in the laptop then tried to turn it on using a different power cord and it worked. I didn't need to replace my battery or laptop. The power cord had failed.
I hope that your issue is as simple as this solution. Try confirming whether your battery and power cord are still working...you may just need to replace one or the other.
Thanks for using Fixya.
Share your experience by rating this solution.
Mar 29, 2009 | Acer AL1916B 19" LCD Monitor
Sony Handycam CCD-TRV65 Camcorder Logo
126 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
