Question about Leupold 55176 VX-III Riflescope
I believe I have damaged the ability of the reticule to adjust for elevation by accidently dropping the rifle. Is there any fix for this? Local technician? Return to factory?
  • 243 Answers
Leupold has excellent customer service. I'd send it back to them for eval and/or repair.
Posted on May 31, 2010
The reticle on my konus pro 4 x 32 does not move when i adjust it
Are you trying to see the reticule move? Or are you shooting after moving the adj screws??? You won't see the reticule move, It only moves maybe 1/4 inch max both ways, If you have a bolt gun, mount the rifle in a vice or a cardboard box with v's cut in it to hold the rifle, aim at a given target app 100 yards away, then sight down the bore, you should be able to see the target, if not, line up the bore, then adj the scope to it, you will be on paper at 100 yards, Try it.,,,,, also, the cross hairs are mounted in a tube that is adjustable, the wires themselves are fixed.
Apr 17, 2012 | KONUSPRO 4X32 MBLK KON7262
I dont understand what the extra dial on my new 6-18x44 scope is for or how to use it.Or what range evry line and dot in the reticule should be ranged in at.
The third turret is for parallax and approximate range
And the lines on the reticule are round and velocity specific plus magnification comes into the distances between substension
On my scope 100 yard zero the next substension down is 176 yards at 10 magnification
The best way to use the reticule for ranging is to get a ballistics program and enter rifle round and scope stats and get a chart for that round and reticule
And the drop chart will change for different velocities and ballistic coefficients of rounds and temperatures a summer chart will be different to a winter chart due to denser air in the cold
Apr 14, 2011 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
Is there anyway i can restraighten my riflescope reticle?
You'll need to contact Nikon. The reticule is fixed inside the tube and should not be moving. If your reticule has shifted then it's a defect.
You can contact Nikon's repair service at 1-800-Nikon US (1-800-645-6687) or check our their website here.
Mar 17, 2011 | Nikon 6456 Buckmaster Rifle Scope...
My Bushnell Banner rifle scope 3x9x40 ia at max elevation and shoots low The scope is used on a marlin 1894c underlever rifle and attached to a weaver rail how can i fix this problem
you might be able to buy a weaver rail adapter that can change your elevation aswell as lift up your scope a bit just to make it a bit easier to see out of. try something like this maybe http://ant-supplies.co.uk/DovetailtoWeaverAdapters.aspx
Feb 27, 2011 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
How do i use a tasco 28A
1. Insert the Bore Stud into the Stanchion while aligning the arrows as shows. Insert the assembled scope guide into the muzzle of your rifle with the grid pattern upright. 2. Select the Aperture Cap that fits your objective rim. Place it over the objective end of your rifle scope and press until it fits flatly against the rim. 3. Using the Adjustable Scale measure the top of your rifle scope tube to the center of the rifle bore as follows: Open the rifle breach. Rest the upper arm of the scale on the scope tube before or behind the windage and elevation turrets. The scale markings should be facing towards you reading vertically and ascending from bottom to top. Slide the lower end of the scale up or down until it is touching the center point of the bore. On center fire rifles the center point will be the firing pin. On rimfire models the center will be the shell extractor. Read the number that corresponds to the indicator marked "CF". Make a note of the reading. 4. Aim the rifle toward a light, flatly lit area such as a wall or open sky. Caution: Do Not Look At The Sun As Permanent Eye Injury Could Result. 5. While keeping the riflescope at the right distance to see the full field of view, sight through it on the grid pattern. Move the stanchion right or left until the bold centerline is parallel to the vertical reticule wire. Turn the windage dial right or left until the vertical reticule is aligned with the grid centerline. 6. Use the reading from the scale to align the horizontal reticule wire. Find the numbered horizontal grid line that corresponds to the number on the scale. Turn the elevation dial right or left until the horizontal reticule wire aligns with this corresponding grid line. 7. To make your final zeroing adjustments remove the scope guide from the bore of your rifle. WARNING: FIREING YOUR RIFLE WITHOUT REMOVING THE SCOPE GUIDE MAY CAUSE DAMAGE TO YOUR RIFLE AND OR CAUSE YOU INJURY At a range or other safe area test fire a group of three rounds of the same type ammunition at a target at least 50 yards away. Refine your scope alignment by adjusting the windage and elevation dials. Move to your desired distance from the target and test fire another group and make your final windage and elevation adjustments. 8. Restore the stud tension by pressing the end of the spring.
Feb 13, 2011 | Tasco Scope Guide Quickly Zeroing Rifle...
Which knob you adjust for drop? What is the left knob for?
If you have 2 knobs, there should be no left knob. If you have a knob on the left, you have it mounted 90 degrees out of alignment. Loosen the rings and turn it 90 degrees clockwise. Once you do that, the knob on the top is the one you will use for elevation.
If you have 3 knobs, the left one is for parallax adjustment, focuses the scope for specific ranges. the top knob is the elevation adjustment in this case also.
Sep 20, 2010 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
My rifle hits the same spot no matter how i adjust it
there should be two adjustment dials on the scope one on top and one on the side might be covered with a plastic plate, depending on the scope the top dial does elevation, and the side dial does left and right adjustments
Dec 30, 2009 | Beeman Optics
Windage and elevation adjustment all over the place
Sounds like you want to "re-sight" in your rifle. Make sure mounts are okay and tight. Look down barrel and then thru scope and eyeball windage and elevation adjustments so the scope seems to be fairly in line.
Clean barrel if it needs it.
For basic sight in, start at 25 yards with a large(3 to 4 feet) cardboard or wood backdrop around target (bullseye). Fire at target. Once done, look through scope and position rifle such that the shot mark you created is dead zero. Hold rifle very steady and you or buddy move windage and elevation adjustments until scope moves dead zero back toward original target (bullseye). Fine tune from there. Air cool rifle between rounds. Once dead eye, fire another round or two to check grouping. Check your ballistics (sometimes on ammo box) to see how height at 25 yards affects your desired dead on target (100 yards, 150 yards, 250 yards etc.). Adjust accordingly. Example: you may need to sight in at an inch high at 25 yards, depending on your dead on target distance..
Always remove sling from barrel when sighting in.
Try to sight in at similar temperature as you intended shooting temperatures, if possible.
If not black powder, avoid cleaning barrel between sight in and hunt/competition unless you note bad buildup inside.
If you change ammo, understand that that may affect performance. Once a preferred ammo is found, some even try to buy a decent quantity with the same lot number on the boxes if storage allows for such.
May 02, 2009 | Optics
I need a scope guide instruction sheet for the Tasco 28a
Dec 14, 2008 | Tasco Scope Guide Quickly Zeroing Rifle...
Leupold 55176 VX-III Riflescope Logo
91 people viewed this question
Top Leupold Optics Experts
ray gallant
Bill Boyd
Are you a Leupold Optic Expert? Answer questions, earn points and help others
