Question about JVC MX-D8T Shelf System
Re: JVC MX-D8T When the unit is plugged in, the power light comes on. Nothing else happens, except the cover on the transformer buzzes briefly. All the fuses are intact, and there are no visible shorts on any of the wires or boards. Why won't anything on this work? How can i test this myself, to figure out what is wrong? i'd like to use this as an intro to board level diagnostics. thanks.
5 Suggested Answers
  • 8 Answers
SOURCE: JVC MX-KB30
Have it first cleaned by a cd disc cleaner or if you are familiar with cleaning the lens manually im sure that will work...or try inserting an original cd's,if it works with that find the solution to the settings of your device...
Posted on Sep 23, 2007
  • 4234 Answers
SOURCE: Power cuts off
This is not a fuse problem. I would suspect that the output amplifier section is getting too hot and shutting down. Check you speaker cables and make sure that they are not shorting out at all. If they are OK, then there is a problem with the amp itself that will require bench time to resolve.
Keep us posted.
Dan
Posted on May 28, 2008
  • 1525 Answers
SOURCE: no power not even light but power is going to
hello you may have ac power but no dc power take the cover off and have a look for any swollen capacitors or components that might be burn't
regards
shaun
Posted on Feb 14, 2010
fkuk
  • 311 Answers
SOURCE: JVC mx-d761t fuse
are you talking about the internal fuse? or the fuse in the plug
im assuming that you are talking about the internal fuse
get a standard glass tube fuse at the amperage you know about
i belive it does not matter what type of fuse it is as long as the diamentions are the same its good
Posted on May 12, 2010
I have a goodman gup0753a furnace that is making a loud buzzing sound when it kicks on. I'm pretty sure it is the relay that is next to the transformer. Can I replace just the relay or should I replace...
Is the buzzing happening during the COOLING mode? If so that realy is turning on the fan blower.
You should be able to replace the relay itself. They are generally on a socket and there is realy nothing else mechanical in the box except for the wiring of the unit.
try www.graingers.com
Aug 01, 2011 | Goodman Heating & Cooling
No power not even light but power is going to transformer also touch the metal cover with a phase tester and it lights up (only just though)..jvc mx-j30
regards
shaun
Feb 10, 2010 | JVC MX-J30 CD Shelf System
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Sub won't stay powered up
well if your getting sound out of your surround speakers then the sub is busted, if your getting no sound at all then your speaker input's are either bad or out... i would test the speaker inputs...
Aug 09, 2008 | JVC TH-C30 System
Only turns on but does not boot
check for the cmos battery!! see if it still on 3 volts
Feb 28, 2008 | ASUS P4VP-MX Motherboard
No sound whatever
when you switch the unit on make sure that you hear two clicks, this will tell you whether the protection relay is working. Should you hear the two clicks this will indicate that the audio ic`s are working. There are fuses inside the main component box, four on the transformer. Let me know the outcome
craig:)
Jan 20, 2008 | JVC MX-J900 CD Shelf System
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
