Question about Maytag MSD2432G Side by Side Refrigerator
The tap door from the ice maker will not open and close properly
Can we just buy the whole front of this part of the door( such as where the ice and water comes out.) perhaps just inter change out this part. We have taken off the front or maybe like the face of the ice dispenser. We just removed a couple of screws. We can see that there are more screws that could come out. Do you think that is can be done by a home ower- on there own. Hence no repairman. Sometimes after we use the ice maker the round trap door wants to stay open. So we use our hands to close it the best we can.
  • 878 Answers
SOURCE: Ice and water on bottom of freezer
sjlobo, sounds like your defrost drain pan is frozen over or has some gunk in it. When the unit goes into defrost the water is running onto the freezer floor and out the front. Remove the lower bin and check the drain hole. You may have to remove the freezer back panel. If you can, just use some very hot water and some sort of baster to unfreeze the drain. Check this first, back.
Posted on May 06, 2007
  • 331 Answers
SOURCE: ice and water dispenser not working but light on constantly
CM, there are 2 things that'd cause this. One is inexpensive, the other is not. First, check the cheap one... That rectangular rubber piece in back of your dispenser area is only a cover for a cantilever device. When you push in on this with a cup, the cantilever swivels back toward you and makes contact with a micro-switch. This switch sends power to the integrated circuit board which, in turn, performs the function you requested (cubed, crushed, water). OK... unplug your fridge. Then use your ears to diagnose this. Push the actuator pad several times in and out and listen for the tell-tale "click click" of the micro-switch. If you hear it clicking, it's good. Plug your fridge back in. Now for the expensive part. If your micro-switch clicks, your dispenser control board is fried and needs to be replaced. (I'm afraid that this is the case because the board controls the light as well as all the other functions.) UNPLUG YOUR FRIDGE BEFORE REPAIRING! To gain access the board, use a small flat blade screwdriver and remove the fascia panel starting at the bottom first. Just begin prying it gently off. Then remove the screws that are holding the board assy in place and gently pull it out. Take note of all of the wiring so you can re-install it correctly. The board number you need is #61005274. Unfortunately, it lists for about $100. A professional repairman would charge you over $200 for the repair, so you're actually saving money here! BTW, we recommend using a Belkin Surge protector for all appliances that utilize electronic controls. (you wouldn't plug you computer directly into a wall outlet, would you?) We regularly use these...
Posted on Aug 01, 2007
the dr
  • 447 Answers
SOURCE: ice and water dispenser for Maytag H20 not working
You need a new high voltage control board. Ive had at least 10 do this.
Posted on Oct 05, 2007
Sea Breeze
  • 4655 Answers
SOURCE: Ice maker is not working anymore. Water doesn't fill the tub. Water dispenser out of the door is still working
I need you to double check the model number. Maytag has a service library at this link.
By placing the first 3 letters in the search feature it will take you to models like yours. Chose the correct model that you have and enter the number in the search. I believe that the water control valve on back of your refrigerator is the problem. Maytag is very good about helping their customers. Let me know if you have problems gettting the information you need, Thanks, Sea Breeze
Posted on May 26, 2009
SOURCE: ice maker will not dispense water or ice.
sounds like maybe the switch that is press to release water not working so it doesnt sent the signel to let water out dispenser
Posted on Sep 29, 2009
Fridge freezer door won'tstay closed
Faulty door seal.The seal that holds the door has a grip and a magnet on other side.May be that needs to be replaced.Or any fringe section tray is not completely fitted,to its end causing these.
Replacement parts can be purchased at any of the following web sites:
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
Both refrigerator and freezer not cooling properly in refrigerator?
The ice maker not working: ---
Compressor not running on refrigerator?
Water dispenser not working on refrigerator?
Ice maker stopped making ice?
Water Overflows in Ice maker and freezes inside?
How to replace Ice maker assembly?
These will help.
Dec 24, 2012 | Frigidaire Refrigerators
1. Disconnect the unit from the electrical supply.2. To remove the ice maker:a)Open the freezer door.
b)Close the spring-loaded emitter doorand open the ice maker door. c) Push the ice maker door to the left sothat the right pin disengages from thepivot arm, then lift the pin out of thepivot, and remove the left pin. Thanks.
Jan 29, 2011 | Whirlpool ED2FHEXN Side by Side...
My ice maker keeps freezing up and then it won't make ice cubes, water comes out, but no ice. We have taken a hair dryer and melted the ice but it came back. Why does it keep freezing up? It is a side by...
If your talking about the ice dispenser freezing up, check that the doop flap is closing properly. Sometimes a plastic eyelet will break and the flap will sit ackward. They make a kit to fix that even though they say you have to buy the whole door.
Oct 28, 2010 | KitchenAid Refrigerators
Ice maker not ejecting ice and then tries to fill tray and leaks
The Ice Maker Tray had a small plastic piece break off. This piece aids the tray in bending to dislodge the ice from the tray. Bosch does not just sell the tray, you will have to buy the whole ice maker assembly. You will need to order Part # 0422 from Bosch. I was not very happy about having to spend $112.00 for this whole assembly when all I really needed was a simple ice cube tray.
Save the $112 and remove the ice maker. Buy Ice at the grocery store.
Mar 31, 2009 | Bosch Evolution 500 B20CS50SNS
Ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Maker Stopped working
Hello, I don't know if this will help because the model I have is a 106.565(32)400. I have had my ice maker stop working many times because the fill tube was iced up. After about the 8th or 9th time that it did this I decided that I had to find a solution. What I came up with was that the door in front of the ice maker was keeping the tube too cold and making it freeze up. I removed the door to see if was correct. It never froze up again but the ice would fall out sometimes if you had the door open and it was in the dumping cycle. Then I drilled several 1/2" holes in the ice maker door and reinstalled it. I have had no more problems for over a year.
CYA, Gator241
Jan 05, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Ice maker
Apr 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker Isn't Working Anymore
yes the door dispenser and the ice maker have separate valves it could be the ice maker valve isn't working properly could be the motor module is bad on the icemaker its self get a 10 gauge piece of wire about three inches long strip about 3/8 to1/2 in off each end pull the front off the icemaker and you will se a bunch of little holes they will have letters on them put the wires in the holes marked t and h kind of wiggle it side to side and watch the ice maker if it does nothing then replace the motor module on the front of the icemaker (you don't have to buy the whole icemaker you can buy the module separate ) if the ejector blades move then when they get to the bottom pull the wire out wit for it to complete its cycle see if it fills if it doesn't then change now if your ice bucket is in the door that can be a whole different animal reply to me and let me know what you find and if you have the icemaker in the door dont buy anything till we check it out as a mater of fact if you pull the bottom kickplate off there should be a tech sheet in it or in a plastic bag under the fridge
Feb 20, 2008 | KitchenAid KSRP22FNSS Side by Side...
Icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Nov 10, 2007 | Refrigerators
Ice-maker noise/vibration
That noise is coming from the icemaker motor module.  It is behind the the white square plastic cover which will pop off.  However it may be that the ice maker thermostat isn't opening and closing at the right time which would turn off the heater and put stress on the module to make it noisy.  Your best bet is to replace the whole ice maker for that is the easiest solution instead of buying parts which may add up to the cost a whole unit.  If you need help finding parts give me your entire model # from the sticker inside the fridge section.  You can look it up yourself at to get the part #.  I have seen great "buy it now" prices on ebay.  If you don't think this solves your problem let me know before you rate the solution please.
Oct 12, 2007 | Admiral 26 cu. ft. Side-By-Side...
Maytag MSD2432G Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
