Question about Fisher and Paykel Dishwashers
Hi, I have a 3 year old Nemo F&P dishwasher which turns itself on and off for about 3 seconds each on/off continually.Eventually it does get enough water to wash but never goes into the wash cycle properly, ie the water just sits at the bottom. We dont think it's water pressure and it was working fine until recently.Could it be an electrical problem with the signal to fill properly not getting through? Thanks
  • fritzanddian Apr 27, 2010
    Hi again. How do I test the heater, do I take it apart? I have a volt meter. How do i test/isolate the timer. Thanks again for your help
    Thanks for that, thats great. Can i let you know that if you open and shut the door, it will do a little more and eventually, very slowly get through the cycle, as in hours later. Also, how do i test the heater and timer? Do i taske it apart? I have a volt meter and am not averse to pulling things apart. Thanks
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Apr 26, 2010
I am locked out of cycle with clean light blinking green and cannot find my manual, dishwasher is about 1 year old. Is there a sequence to break this cycle? I turned off power for 60 seconds to no avail.
Hi
I have not seen this model in Australia, but normally if you hold down "Start/Stop" button for 3 to 5 seconds, that should clear the cycle.
Otherwise if you have a Clear button press that for 3-5 seconds.
Ash
Sep 06, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
When the dishwasher not in use, it filled the water up by itself. And after it was full, the water leaked out to the floor. Even after I turned off power, it cannot stop. I have to shut the valve under the...
If you have a problem with your washeror dishwasher continuing to fillwith water after the valve has closed, then you this tip will help youunderstand why that is happening.
Here is a tip that will help you...
Washer orDishwasher Fills with Water when off
heatman101
May 10, 2011 | Frigidaire Professional Series 24 in....
Cleaning Light flashes 7 times then repeats 7 flashes again. Cant find model #.... About 6 years old.. Thank you
342f192.jpg techbuster
  • Rank: Guru dishwashers_small.png
  • Rating: 92%, 2877 Votes
  1. Crack open door
  2. Within 3 seconds push Hi-Temp Scrub, Heat Dry, Hi-Temp Scrub, Heat Dry
  3. Close and latch door
  4. Press Cance
Try the above steps and also check the video in link given below to know detailed explantion on what the light means
http://www.youtube.com/watch?v=Hv7xOaucH7I
Jan 19, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
Bought a 3 year old unit for my son in law, picked it up at a storage unit. Unit panel will only turn on when the door is open. When we close the door the lights go off and it won't start. HELP
Hi
Thanks for using FixYa. This issue can be either due to a faulty door latch or door lock switch which is not engaging itself. And, if the door latch will not engage the dishwasher will sense it as open door and will not start. You'll need to check & replace the part that has gone bad with a new one. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 23, 2010 | Bosch Integra® 500 SHX46A0 Dishwasher
Fisher n paykel nemo dishwasher won't go. Sounds
Check to see that the outlet pump (underneath) isn,t stuck eg sumething stopping the pump from turning.Also check that the outlet is clear where it connects to the sink outlet.Hope this helps.
Dec 13, 2009 | Fisher Dishwashers
1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Dishwasher problem
i had the same problem with a fisher paykel nemo dishwasher beeping at end of cycle, as im a mechanic i was curious to pull it apart and see how it works, i pulled the main control board out and unscrewed the three screws holding it all together and inspected the circuit board, and what did i see, a dry solder on the blue relay box or something, resoldered it, reassembled it and now works a treat, hope that helps
Feb 01, 2009 | Dishwashers
Kenmore dishwasher
Mine eventually "fixed itself". I think some debris got caught and eventually (5 cycles or so) got ground up and sent through the drain. The noise changed each time it got closer "flushing out"
Apr 01, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Problems with Fisher & Paykel Nemo model DW681.
is there somthing stuck in the wash motor,can you hear a humming noise ? if yes remove motor and see if you can turn it by hand.hopr this helps.
Mar 14, 2008 | Dishwashers
Dishwashers Logo
48 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
