Question about Tech Solution TS-4500 Shredder
TS3300 PAPER SHREDDER. I NEED THE SWITCH CABLE COMBINATION
Where can i buy a gear for my paper shredder model ts 3300
Posted on Apr 04, 2011
When turned on shredder runs, dose not stop when items are finished, but must be turned off manually. is there anything I can do to fix this?
stuck ,faulty reader switch or debris is blocking or covering the sensor unplug unit and carefully look and try to clean any paper or debris in shredder
Aug 11, 2016 | Shredder Office Equipment & Supplies
My paper shredder will not shred or grab the paper?
If the motor is spinning, it's probable broken teeth on the drive gear. The drive gears are usually the first thing to break on a shredder.
If the motor doesn't spin. The paper may be clogged in the grinder claws. You may have to turn the shredder over (after you remove the power cable from the wall outlet). Then remove the papers from underneath.
Hope this helps.
Feb 28, 2015 | Shredder Office Equipment & Supplies
Paper shredder doesn't move due to too much adhesive paper - how to fix it
Before trying anything I suggest, make sure your shredder isn't plugged in.
You will need to remove the adhesive from the rollers. You will need to use a glue solvent on the shredder rollers,something like Goo Be Gone. Personally, I still use Ronsonol Lighter Fluid In the image below I've outlined the supplies you'll need to, hopefully, clear your jam.
25346531-f3timxio4jyou4u0bydnlgfi-2-0.jpg Without disassembling your shredder, the best way to clear your jam is to use Rosonol Lighter Fluid (3), tweezers (4), and dental picks (5).
  1. Make sure you are working in a well ventilated area. Separate the shredder from its shredded paper collection tub.
  2. Turn the shredder head upside down so that the paper output is facing up.
  3. Pour Rosonol lighter fluid on both sides of the rollers near where they come together.
  4. Use dental picks and tweezers to dislodge stuck paper pieces
  5. Turn Shredder head over and repeat steps 3 and 4
  6. Move power switch to the "Off" position
  7. Plug power cable back in
  8. Move power switch to "Rev" (reverse) position, if still stuck move power switch to the "Fwd" position, repeat twice
  9. Repeat steps 1 - 8 until the rollers move freely
Once the rollers are moving smoothly you need to oil the rollers.
Dec 30, 2014 | Shredder Office Equipment & Supplies
Infoguard sx100m
I don't own this shredder, but most are built with similarities. Usually there is a micro-switch that's used to detect a piece of paper being inserted. Should this switch get jambed, it will continue to "sense" paper being inserted and continue to run.
As I said, I don't know this shredder, but it would be reasonable to assume that someone will need to open the shredder and clean (or replace) the switch.
As a possibility, I think I would try using one of those 3M Dust Remover can's of compressed air and see it you can dislodge any paper or paper dust around the switch by blowing through the paper entry opening. (Will need to look into the opening to see where the switch is located. Usually near the center.)
Otherwise need to have a technician come out.
Aug 28, 2014 | Industrial Paper Shredders Office...
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Can you take apart a fellowes PS-12C
FELLOWES SHREDDER
May 23, 2014 | Fellowes Office Equipment & Supplies
Envelope stuck in the middle of a shredder
Try using the reverse function if the shredder has one. If not run a couple of sheets of paper through. if need be find the switch and hold a piece of paper in the shredder just enoguh to trip the switch.
Mar 09, 2011 | Office Equipment & Supplies
Light is on. Reverse works, paper fed won't trigger the shredder
If you are pushing a button to make the shredder run something doesn't sound right.
See if this makes sense, Generally shredders will use a photo switch or a micro switch to detect the paper. If you are pushing a button it sounds like you have a micro switch. The switch should have an arm that would extend into the throat of the shredder and the paper would hit the arm activating the switch. From your description it sounds like the arm is missing or bent out of the way of the paper. If you can see the paper actually hitting an arm that would activate the button then the arm may just need to be bent a little so it moves farther to operate the button
Hope this makes sense and helps
Mar 14, 2009 | Office Equipment & Supplies
Shredder
If your unit has a mechanical paper feed sensor located in the center of the paper feed area there may be paper behind it causing switch not to activate. If it is an electronic sensor you probally have a burned out sensor, switch or a bad pc board. You will need to contact manufacturer for info on part replacement.
Mar 13, 2008 | Achiever CCS5000 Shredder
Paper shredder
The only solution with respect to safety is to order a new switch from the companuy that manufactures/sells this shredder, and mount it according to the manufacturer/sales company's instructions.
If you want to bypass the safety of the machine, just keep the cables (should be 2, + eventually a ground cable) open, or shorted, depending of the machine's configuration. Remember that this is on your or your collegaues own risk!! A shredder can easily bite your finger off!
May 19, 2007 | Tech Solution TS-4500 Shredder
Tech Solution TS-4500 Shredder Logo
237 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
Jim Keysor
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
