Question about Lands Phones
My K810i suddenly became very hot. It wasn't near a hot surface or in ant direct heat. I took out the battery, which was very hot. After a while it had cooled down. On replacing the battery and trying to charge it, nothing happened.
  • Jimmy Matthews
    Jimmy Matthews Mar 24, 2008
    Thanks. What would cause the battery to fry
    President:
  • 1,944 Answers
Chances are that your battery has fried. But before you buy a new one try leaving the battery out of the phone overnight. Then put it back in the phone and plug the charger in. Even if nothing seems to be happening leave it plugged in for a few hours. Sometimes, it takes a bit of time till the charging begins (I have seen this happen on rare occasions). Worth trying before you buy a bew battery.
Posted on Mar 24, 2008
My lumia 535 phone gets hot when i use it ,,, what might b the solution for that problem
cut back on usage batteries generate heat when used --test battery for a possible fault
Jul 28, 2016 | Cell Phones
After blending cake batter the blender became hot and it's not working what shall I do
You have burnt up the machine. It will no longer function and would be unsafe to try further. Replace it.
Jun 03, 2017 | Philips HR1350 SingleSpeed Handheld...
The red lead wire on the back of the alternator has pulled away from somewhere and I need to know where it attaches to. This is on a 1997 Chevy Cavalier 2.4 engine. When I took the bolt off of the red lead...
That heavy gauge red wire (called a B+ wire) runs from the positive side of the battery directly to the back of the alternator. On yours, if it goes to the starter, the starter main battery terminal would essentially do the same thing. (both connections are always hot and always come directly from the battery). If you meant that it became disconnected when you said "pulled away", you need to find the wire it disconnected from and re-connect it. If it just came out of a loop that was securing it, you don't necessarily need to find the loop but can secure it with a tie wrap, making sure it stays away from the manifold.
You could actually make a new wire and connect it between the battery (+) terminal and the alternator, using the same gauge wire, but I'd be concerned that the loose end coming from the starter could possibly touch something and cause a direct short. At the least, you should find the loose end and cap it off. The battery cannot charge with the wire disconnected.
Anything I've just written that you don't understand, just ask and I'll clarify it for you.
Jun 22, 2011 | 1997 Chevrolet Cavalier
How to format the phone
For soft reset type *#7780# For hard reset type *#7370# and if it ask passcode enter the passcode as 12345 as default.Please backup all your data if you performing hard reset because hard reset deletes all data on your phone like contacts,messages,music,videos and photos
Feb 22, 2010 | Sony Ericsson K810i Blue Smartphone
0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
Thanks
Vic
May 17, 2009 | Kitchen Ranges
HELP NO HEAT
sounds like a gas valve issue. if the hot surface ignitor is glowing red then the next step is for the gas valve to open, if it doesn't then it sounds like the valve, if it does open but only for a few seconds then it is your main burner flame senser.
Nov 19, 2008 | Honeywell Programmable Thermostat Heater
My K810I froze up.
Now you should take the phone and ahve it reflash ....also you can try online at www.topsony.com
Jul 04, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Handset dead
Upma I have experienced this before and if the phone has been damp by body heat or other moisture then it does do this. try drying it out with a hairdrier on a cool setting. then leave it to dry properly for a couple of days in a warm NOT HOT place. the keypad will start to work and the battery will settle as well. let me know how this goes. t1m0thy
Jun 27, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Kenmore All in One?Dryer Heat Minimal?Excessive Dry time
be sure vent to outside is not plugged or partially block be sure vet tube in back is not compressed flat or folded basically be sure you have good air flow to outside to take the moisture to the outside away from the clothes
Jun 06, 2008 | Kenmore 45081 Front Load Washer / Dryer
My K810I froze up.
My friend had experienced the same problem with her SEK810i. We both bought the K810i last year. Mine is working perfectly fine. but hers suddenly froze, and she cannot even see the phone menu. we tried to go to a service center but they couldn't fix it. So she just bought a new phone. also fro the SE phone collections.
Mar 26, 2008 | Sony Ericsson K810i Blue Smartphone
Lands Phones Logo
355 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
