Question about Cobra Electronics microTALK® CXR700 Two Way Radio
I have two radios which worked fine for about a month, now one radio will only receive and cannot talk back the the other one
4 Suggested Answers
Bat1956
  • 585 Answers
SOURCE: Galaxy DX959 CB radio reception and broadcast
Agreed, it has to be antenna. If the new truck has shock-mounted mirrors there may be no bond to ground if that is where the antenna mounts. the coax needs to bond to metal at the mount or the SWR will be way out. SWR affects receive just as much as transmit.
Posted on Jan 24, 2009
  • 773 Answers
SOURCE: Have cobra 29wxnwst radio. Truck sat for 3 months
Turn up the RF gain all the way and leave it.
RF gain is basically how open your receive is. There is really no reason ever to have it down unless you are trying to hear only close stations to you.
If you RF gain is up, your mic pins my be oxidized, or mic bad.
Try a different mic, and or clean the contacts in the connectors.
Posted on Oct 01, 2009
Benimur
  • 6966 Answers
SOURCE: cobra 142 gtl no audio on receive
Hi and welcome to FixYa,
Initially, the speaker of course has been checked?
Offhand, would partial schematic of the mic and speaker section help?
Good luck and thank you for asking FixYa.
Posted on Dec 20, 2009
My pro talk tk-3402u16p dosnt work
Be sure the "Channel" and "Code" settings are the same on all radios.
May 09, 2014 | Kenwood Radio Communications
Galaxy dx959 will not receive. Speaker is working. S meter is showing incoming signal.
the over power doides may be blown. you should start there .they should be marked D-1 and D-2. you may want to replace them with diodes of a higher rating.
Jun 26, 2012 | Galaxy Radios DX 959 SSB CB Radio
Radio transmits fine but the receive volume is way down. Can hardly hear it with volume turned up full.
If you have talk back in this radio.( you hear your self through the radio when you transmit) then its a good bet that the RX wire in the mic plug has broken off.
The mic switch is responsible for putting the radio into receive mode when you release the key. If the RX wire is broken, the radio will not go into receive.
Normally when this happens you have no receive at all no matter what, but you will have very low sound if you have talk back installed in the radio.
Because of this, if you have talk back in your radio, and the volume is faint even at full blast, its a good bet that its a broken RX wire in the mic cord or plug.
You can attempt to see if the break is at the mic plug. if it is, you can re solder it and it will solve your problem. If you have no clue, then you can just go buy new 4 pin mic.
Nov 14, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
Cb is Keying Down instead of keying up when trying to talk
if you are transmitting fine Don't worry about the meter. Get an external SWR meter, they are better anyway.
Also, make sure the the switch next to the meter is all the way up on s/rf setting. thats for signal power and receive strength.
Aug 30, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
We have 6 sx600's we use in our store. 4 of the 6 when you push the talk button just makes a beep sound and you cant talk or anything! Why?
Beeping when pressing the PTT can be a sign of low or bad batteries. To check to see if this is the problem, move a battery from one of the working radios over into one of the problem radios and see if it solves the problem. It takes more energy to Transmit than to receive, so your radio may receive transmissions, but not be able to transmit. If this is the problem, replace your rechargeable NiMH battery packs. Charge the radio completely (always with the radio shut off. Batteries have an 18-24 month life expectancy.
If this does not solve the problem, check your chargers. Clean the battery contacts and charger contacts with a pencil eraser. Replace any non-working chargers.
Here is a copy of the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/SX600%2012-21-07.pdf
Aug 02, 2009 | Motorola Radio Communications
I had the same problem. worked fine then...
They should allow you to trade your radio in for a used rebuilt unit if you call Delphi directly.
Jun 17, 2009 | Delphi Roady XT XM Radio Receiver
One radio makes loud tone when other radio transmits
You may have a defective radio that has a bad push to talk switch which doesn't mute the receiver and feeds back audio to itself or this could be a bad solder connection or a broken wire inside.
Not much you can do except replace it or have a tech look at it.
May 11, 2009 | GE SmartHome (58173) 2-Way Radio
MyFi remote control has stopped working
ok take the battery out of the radio then put it back in and it should work mine did the same thing to me
Nov 24, 2007 | Delphi MyFi SA10113 XM Radio Receiver with...
Cobra Electronics microTALK® CXR700  Two Way Radio Logo
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
