Question about Samsung HL-R6167W 61" HDTV
Picture comes on initially then the screen goes blank. the lamp was replaced about 1 1/2 years ago. could this be caused by the lamp going bad again?
Did you fix this problem? I have the similar problem. I just replaced my lamp thinking that was the problem but after about 30 minutes (if my TV has not been on for a while) the TV turns black and all 3 lights in the front of TV start flashing. Any information on fixing this would be helpful.
Posted on May 25, 2010
  • 336 Answers
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php The part # is "BP47-00027A" When you replaced the lamp did you replaced it with an Original Philips,if you did those lamps average 6000-8000 hrs 2-4 yrs.But if you didn't get a Philips but an aftermarket or Osram they average only 4000 hrs 1-2 yrs.Have a bless one!
Posted on Apr 27, 2010
Screen keeps going black
It is possible but the only way to know is to try that.
Lamps have about a 2000 hour life span which works out to about 2 years for the average user.
Usually in this model just before the lamp fails the picture either comes on somewhat darker than usual or gets dark just before the picture goes out.
The set will detect lamp is not bright enough etc and blank the screen.
The lamp light (I have seen this) sometimes will not come on even if the lamp has a total failure----no picture at all.
You might also check with a local shop or someone with the same model so you can swap lamps to see what the problem is.
Let me know what happens.
Dec 17, 2011 | Sony KDS-50A2000 50" HDTV
I have a Sony WEGA KDF-E60A20 for 4-5 years. A few mintues after i turned it on, the screen goes blank with no sound. It comes back after 1-2 minutes. It goes blank again after 2-3 mintues. It just keeps...
It's the lamp. I do have an article on this in my Tips & Tricks regarding lamps, but replacing the lamp is a sure fix. I hope this was helpful, best wishes.
Apr 29, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Screen goes blank for seconds
bad connection, soldering goes old .using soldering iron, locate bad connection and redo them agin
Sep 14, 2009 | Samsung DLP HL-P5663W 56" TV
Lamp will not ignite
Two possible causes. First. The Color Wheel is going bad. Second. The Digital bd is going bad. Color Wheel part# is BP96-96-00674a and the Digital bd is a BP94-02065a.
Jul 09, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
The monitor goes blank after just a few seconds or sometimes works for hours.
Two possible causes are bad capacitors or a bad light inside the LCD panel.
Open the unit and check to see if any of the capacitors in the power supplyor other boards look domed or vented on the top.
Replace any capacitors accordingly. Monitor should work fine after that.
If not try checking the surface-mount transistors on the inverter board that run the lights. Some times these transistora go bad. Also, you may have a bad light inside the panel. This is tough to test without a spare light to use for troubleshooting the panel lights.
You can take the panel apart and inspect the lamps but it is very tedious. It's tough enough to get them apart and back together again never mind keeping the layers clean. You have to try not to get any dust between the layers or you will see it in the picture.
There's usually two light fixtures each of which holds two lamps. One fixture at the top and one at the bottom. Remove them one at a time and inspect the lamps to see if any are broken or very dark on the ends. If one looks out of place, it could be bad.
You'll have to find replacement lights on the net. It's not easy to replace them, but if you've gone this far, good luck. You should be able to get generic instructions off of the site that sells the lamps.
Feb 13, 2008 | ViewSonic VX924 19" LCD Monitor
No Picture/Sound
can you go to the error menu?
im assuming it's the lamp however the error menu will tell me more
If the standby light blinks five times repeatedly, that's indication of a "Lamp driver error". The probable cause listed is, "lamp driver faulty". Its also possible that the internal antenna used to detect the presence of high voltage has become mis-positioned. The lamp driver provides the high voltage. If no high voltage is detected, it is assumed that the lamp driver is faulty.
Otherwise, it is assumed that the lamp is bad and the LAMP LED lights
the part number for the lamp is XL2000U. Its available for $200 at http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do. Use the Part or Accessory Number to locate the part.
Jan 17, 2008 | Televison & Video
Monitor only stays on for 3 seconds
There is probably a bad capacitor within the monitor that will not allow the picture to "hold" in the on configuration. This will need to be replaced. You can send it back to Phillips, or 17" monitors are pretty cheap these days. I would suggest a Samsung or BenQ. They both carry 3yr warranties.
Aug 17, 2007 | Philips 170S4FB 17" LCD Monitor
Samsung HL-R6167W 61" HDTV Logo
131 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
