Question about Hobart Handler 140 Mig Welder
Have a hobart 140 mig welder, the wire feed otor does not turn on, gas solenoid does
  • 23 Answers
I have a 120 and when that happened to it the bridge rectifier was bad on it. Not sure if your 140 has that or not but just something to look into. It only cost me about 8 or 10 bucks to fix mine.
Posted on May 18, 2010
L bought a hobart 140 two days ago, welded about 10 feet of wire with it .now it only feed wire on three out of the five settings
Check the selector switch with an ohm meter. Unplug the unit, ground to chassis and probe the contacts while turning the switch on and off.
Dec 17, 2012 | Hobart Handler 140 Mig Welder
The gas won't shut off once I release the trigger, sometimes the wire continues as well.
Hi:The solenoid valve gets the current once the switch is activated (pressed) therefore my opinion is that you have a sticky trigger. or one of the terminals of the cables it's shorting out.Change the trigger or better yet check that the terminals are clear and not touching other parts of the handle.
Dec 06, 2011 | Hobart Handler 140 Mig Welder
I HAVE A HANDLER 140 I PURCHASED NEW RECENTLY, THE WELDER FEEDS WELL BUT THE WELD WIRE ONCE APPLIED IS NOTHING BUT **** AND FALLS OFF THE METAL WHEN STRUCK WITH A HAMMER. i AM USING SOLID WIRE AND THE...
Newer welders as hobart and miller are set up from factory to use innershield wire therefore polarity is set up as inverse. Check inside your machine and check that ground cable is on negative side. Your gas must be mix argon/CO2 or pure CO2 (not recommended).
Other potential problem is wire not being a mild steel one. Check you have gas flow out of your nozzle.
That's all I can think of.
Jan 26, 2011 | Hobart Handler 140 Mig Welder
Hobart 140 voltage drop when welding in all setting using 30 wire and uni mix gas will start out welding good then will not ?????
Check your input line voltage. 115 volt Mig welders / plasma cutters need stable voltage / current. Test to see if the voltage drops to below 100 volts when welding. If so, find a more stable power supply.
Mar 05, 2010 | Hobart Welders 500505 Handler 140 MIG &...
Hobart handler 140 wire feeds properly, will not weld
If it is new i would not play around with the welder Just take it back to where you bought it get them to replace it under warranty
Jun 10, 2009 | Hobart Handler 140 Mig Welder
Handler 140 wire jerky when welding
make sure rollers are clean and slots not wore out check alignment
do not over tighten wire feed so it smashes the wire
flux wire is hard to get a good setting
make sure if you can set it for gas welding it is not on this setting
Apr 06, 2009 | Hobart Welders 500505 Handler 140 MIG &...
Hobart handler 140 will not feed wire
A schematic would certainly help, give Hobart a call and ask for a wiring diagram. or manual. Hobart are very helpful and may even give you guidance, you may have to pay the postage, they usually fax these documents so it will not cost you anything.
Feb 13, 2009 | Hobart Handler 140 Mig Welder
Wire feeds too quickly
Some welders control wire speed with the amps control, some control amps with the wire speed control. You might try turning things up until it runs smoothly without pushing back. If you're new at welding, it does take some practice until it feels right.
Jan 15, 2009 | Hobart Handler 140 Mig Welder
Hobart Handler 140 Mig Welder Logo
354 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Troy
Troy
Level 1 Expert
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
