Question about Texas Instruments TI-86 Calculator
I just changed the batteries and the screen is black when i turn it on if its in direct light i can see what i am typing..
  • kakima May 11, 2010
    Turn the calculator on. Press and release the 2ND key. Press and hold the down-arrow key for a few seconds and see if teh screen lightens. Does it?
I had the same problem as this. This is because when you might have changed the contrast on your calculator when your old batteries were running low and you need to reset the contrast. Here is what you do:
press the orange "2nd" button, then press the "down arrow" button, then the orange "2nd" button, then the "down arrow". do not press the buttons at the same time only one after the other and KEEP GOING. The screen will eventually lighten up and you are all set.
Posted on Jun 14, 2010
Thats what mine is doing! and no its not teh contrast someone help me!
Posted on Jun 04, 2010
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
    An expert that gotĀ 20 achievements.
  • Texas Instru... Master
  • 102,366 Answers
Having gone over a month without a response, I assume this is no longer a problem.
Posted on May 28, 2010
Turn on - flashes logo - then black screen with audio and channel changing capability
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Nov 22, 2015 | LG 47LN5700 47" 1080p Smart TV 120Hz Dual...
Why laptop screen goes black after plugging battery charger?
Try another charger and then see or it might be a power options issue
Try this
SOLUTION: If you have a second computer, use Remote Desktop by choosing 'Run', type 'mstsc', type the name of the computer with a black screen, and connect. After logging in, open 'Control Panel', and choose 'Power Options'. On the left panel choose 'Choose when to turn off the display'. On the row labeled 'Adjust plan brightness', under the 'Plugged in' column, turn up the brightness slider.
Aug 10, 2014 | Sony SVE15135CXS - VAIO E Series...
Cellphone screen black out
Have you tried resetting it? To do so, turn off the phone, take off the back cover, take out the battery & leave it for a minute or so. Put the battery back inside, cover back on and power it back on. See if this corrects the issue. If it doesn't, then I would advise speaking with your carrier and/or Samsung directly to pursue alternative options.
Oct 25, 2013 | Samsung Galaxy Precedent (Straight Talk)
Y compaq pressario v2000 goes from black screen to intermittent normal screen. The black screen is on the computer 80% of the time and then the pics fade in and out
The screen on your laptop goes black after every few seconds.
It resumes after a mouse-click or after a key-press.
Solution
Click on Start --> In search bar, type power options and press Enter.
"Select a power plan" window will be opened.
Click on "Change plan settings" next to "Balanced (recommended)".
In "Turn off the display", select "Never" from the drop-down menu under both the options "On battery" and "Plugged in".
Now click on "Save changes" button.
hope this helps
Nov 20, 2012 | Computers & Internet
What do i do when my laptop won't turn on
Is the power light glowing ?
Do u find any error messages in the screen.
Do u find a blue or black screen ?
Remove the battery from behind the laptop and connect directly through main.
If it works, replace ur battery.
Oct 04, 2010 | Computers & Internet
Press power button and all you get is blinking red light. nothing comes on just black screen
Have you check the battery you are using or better still remove the battery at th back and plug it directly to the power supply and check if it turn on well . if it is positive then change the battery , the battery is at fault.but you can still add the battery when you see that after removing battery and plug it straight it power on then after like twenty minutes you can slot in the battery as well so as for it to be re-boost by the power and get charge up.
May 24, 2010 | Gateway MX6438 Notebook
Black screen when camera is turned on
hi.. I also had this problem with canon ixus 75. i took it to the service center and they just knocked its lens(lightly) when it was on ON mode, then suddenly the screen started working.
But he said that u should use it on regular basis for few days and if the problem occurs again. then we will have to change the sensor, I think he said sensor or something like that.
Aug 11, 2008 | Cameras
Typewriter screen has gone black
The black display is either a bad display or board. If you can get it to us we can fix it. We are in Cleveland, Ohio.
DickyO
Apr 22, 2008 | IBM Wheelwriter 30 Typewriter
Black screen
you probably just pressed the DISP button on accident (its on the lower right hand corner of the screen) to turn the screen back on, push the DISP button. if that doesnt work, i would get it looked at by people at Canon.
May 03, 2007 | Canon PowerShot A520 Digital Camera
Texas Instruments TI-86 Calculator Logo
252 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
