Question about Universal Kreepy Krauly In-Ground Pool Cleaner
It only stays one side of the pool and does not pick up well
  • 640 Answers
First, make sure that your flapper is clean and clear of debris that could cause the pool cleaner to not change position properly. Next, check the return line water flow and redirect it as necessary. Your clean should have come with an "eyeball diverter" to help you regulate the water flow. If you don't have this, you can buy a "wire diverter" from your local pool store (pretty inexpensive). This might seem obvious, but make sure that you have enougth hose to stretch to every end of your pool. Finally, make sure that your cleaner has a proper hose balance.
Posted on May 19, 2010
Dirt Devil Rampage Robotic Pool Vacuum wont climb side and stays in deep end all the time?
If a pool vac is not climbing the side of the pool this is one of several things main things . a blockage in the pipe (try inserting garden hose to flush it. or insufficient vacuum at the skimmer box (Test with your hand) or a break inside the unit - if the third, you probably need to take it in for repair.
May 17, 2014 | Dirt Devil Rampage Robotic Pool Cleaner...
Polaris 3900 is not picking up debris
open unit see if belts and hoses ok and if ballast ball has water replace it
May 18, 2012 | Polaris 3900 Sport Pool Cleaner ()
Hey i find when im vacuming the dirt i pick up from the bottom of the pool just goes threw the filter and back into the pool, what should i do?
The multi-port valve should be in the WASTE position when vacuuming. Make sure there is enough water in the pool to stay above the skimmer when vacuuming .
Jun 06, 2011 | Hayward SAND FILTER, PRO SERIES
My Polaris 3900 Sport is on it's side. I turn it back up on all 3 wheels and it hits the side of the pool and goes back on it's side again...going in circles.
With these automatic pool cleaners, if they are not staying firmly on the bottom of the pool, it is most likely that there is air in the appliance casing.Try submerging your cleaner. Keep the cleaner vertical while you are putting it in slowly to let the air out. Ensure the unit sinks to the bottom of the pool.
May 20, 2011 | Polaris 3900 Sport Pool Cleaner ()
G4 keeps heading for and climbing the sides of the pool, always making a long run along the side walls of the pool. The bottom is not being cleaned. Have adequate lenght of hose. Diaphram has no holes....
If these pool cleaners are staying on the edge on the pool, there are two things that you can do to correct the problem. First, reduce the flow through the cleaner to the low side of the ideal range. Second, add a hose weight about 3 feet from the cleaner's head. That should correct the issue.
Apr 15, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Just bought a used legend and it seems to be In good shape. It needed a new bag. Bought one today and began using it. It picks up fine but after a little while it ends up o it's side and stays there. Any...
their should be a ballist weight inside the unit in the bottom. Be sure that is in place. Then check all the floats and be sure they don't have any water in them. Also make sure your hose leingth are correct.
Sep 07, 2010 | Pentair White/Gray Legend Platinum...
Fine particles going thru the bag
Check the bag of your pool cleaner to make sure that it doesn't have any holes or tears that should not be there. Some fine particles will not be picked up by pool cleaners, no matter how effective. If your filter is not catching the debris, you might need to manually brush the bottom and sides in order stir the dirt up into the filter.
Aug 05, 2010 | Polaris 3900 Sport Pool Cleaner ()
Navigator Pool Cleaner: the right wing of my navigator is not moving nearl...
It sounds like it might be a problem with your return pressure. Make sure that you are getting even pressure released on both sides of your automatic pool cleaner. Pick it up while it is on and see if you are getting more pressure on one side. If you are, adjust your valve. If you seem to be getting even pressure, it could be that you did not install the shoes or wings correctly. Check to be sure that both sides are installed properly and evenly.
May 17, 2010 | Hayward Navigator Pool Cleaner
New baracuda automatic pool cleaner.
If these pool cleaners are staying on one side of the pool, there are several things that you will want to check. First, check the return line water flow and redirect it if necessary with an eyeball diverter. Make sure that your new hose has proper balance. You might have to apply hose weights to achieve balance. Also, make sure that the new hose is long enough to reach all corners of the pool.
Apr 16, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Universal Kreepy Krauly  In-Ground Pool Cleaner Logo
685 people viewed this question
Top Universal Pool & Spa Experts
Bill Jordan
Are you an Universal Pool and Spa Expert? Answer questions, earn points and help others
