Question about Koss KS3112 DVD Player
Progressive scan i accidentley pressed the pscan button and i have no picture what do i do
    Genius:
  • Koss Master
  • 1,550 Answers
Algunas veces funciona sacando el disco del dvd y cerranda la charola presiona por 5 o 10 segundos la tecla stop,ojala te sirva.
Posted on Mar 25, 2008
We see a yellow anouncement that says PSCAN and it splits the image
Hello
PSCAN; means Progressive Scan. To get the splitted picture together you have to change the scan system of your tV to progressive scan. Now it runs on Interlace Scan. If your TV has Progressive Scan function; refer to its user manual; set it to progressive scan. An other way is to change the scan system with DVD. Try either. OK.
Jun 20, 2011 | Memorex MVD-2045 DVD Player
PSCAN
try unplugging it overnight.
Thanks,
Lee
Jun 24, 2008 | Aspire Digital AD-8091 DVD Recorder
It says in an orange background 'Pscan' what does this mean
It could mean that the player is in progressive scan mode - if you are not getting a picture from it, but sound, try turning progressive output off (without a disc inserted, press and hold STOP button on the front of the unit for 10 seconds - not the remote - then release. This should revert progressive output of the player back to normal interlace).
Apr 12, 2011 | Televison & Video
I pushed the pscaan button by mistake n now I can hear the movie but no picture
This is probably the 'progressive scan' feature for your DVD player.
If you haven't had any other problems with the player, try pushing the button again (a second time). This feature is likely a 'toggle-on, toggle-off, so a second 'push' should turn-off the progressive scan.
If this doesn't correct it, power the unit off, then power-on again. It it doesn't automatically power-up without the progressive scan, try pushing the pscan button again. Hopefully this will turn-off your undesired progressive scan. Good luck!
Feb 05, 2011 | Oritron DVD600 DVD Player
My samsung dvd-sh855m has no picture, only sound. there is no picture at all so I cannot even set the machine up. When I put a dvd in I can hear it but the screen stays black
Press the 'pscan' button on the front of the recorder 3 times and the picture will come back. This is a little sod as you only need to catch the pscan button once - if your TV doesn't support a progressive scan your picture has gone....
May 04, 2010 | Samsung DVD-HR720 DVD Recorder
Picture is split -- says P-SCAN. It's stuck
that means it is stuck on progressive scan.  If your tv is not able to handle progressive scan, you need to change it back or reset the player.
The DVD player may be set to Progressive Scan Mode. You will need to change it to Video Mode by using the remote control. Point the remote control directly at the DVD player, and then press the PSCAN button 2-3 times. If you are still encountering problems with the DVD player, reset the unit back to the default setting.
To Reset,
Make sure you do not have a disk in the tray. Using the DVD player remote control: 1) Press the “Setup” button. 2) On the “Down” arrow, press it three times. 3) On the “Right’ arrow, press it once. 4) On the “Down” arrow, press it three times. 5) On the “Right” arrow, press it once, then press “Enter”. 6) Press the Setup button. *The default setting will take affect as soon as you press the setup button (step 6).
Hope it helps..please rate!
Mar 07, 2009 | Coby DVD-224 DVD Player
Pscan mode
I had the same problem. Here's what I did to reset the progressive mishap...
  1. Turn on the player (without a disc inserted)
  2. Wait for the "no disc" message
  3. Press 1, 6, 7, 1, 9 slowly
  4. A menu comes up
  5. Select "Configuraton"
  6. Select region (0 = codefree)
Feb 26, 2008 | Oritron DAV3101 PROGRESSIVE SCAN DVD
Pushed the pscan button by mistake
Should be as easy as pushing the pscan button again. You might need to unplug the dvd player for a while till it goes back to factory. The P is for progressive scan and your tv must not support P. Once you get it turned off it will work again. There also might be a button on the remote to turn it off.
Feb 06, 2008 | Starlite NP625 DVD Player
Per manual, with DVD selected and stopped, press and hold p/scan button on remote for 5 seconds to switch between pscan and interlace mode.
Nov 10, 2007 | GoVideo Go Video DVD/VCR Combo
Memorex dvd player pscan split screen
Memorex MVD2042 - The only switch on the back of the unit had gotten bumped when something fell behind the unit, thus causing the same issue mentioned here. Looking at the front of the unit, the switch is straight back from the disc tray on the left. (of course, if you're looking at the back, it's on the right side) This switch is for "Progressive Scan" either "on" or "off" Thanks, Wizard_Yo
Jul 03, 2006 | Memorex MVD2022 DVD Player
Koss KS3112 DVD Player Logo
Top Koss Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Koss Televison and Video Expert? Answer questions, earn points and help others
