Question about Garden
Need a bar and chain for slihl 012 av rollomatic
    President:
  • 2,220 Answers
Right column, about 2" down "Bar Selector", just fill in the blanks.
http://www.baileysonline.com/
Only you can determine your level of expertise and how much danger of kickback you are comfortable with. Stihl brand bars and chain are only available through a local Stihl dealer.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 26, 2010
Can I run a Stihl rollomatic es 25in 84 drive link .50 on a Makita dcs6401
Probably not. The Makita is normally an Oregon bar of the Husqvana type and is likely to have the oil holes in a different position to the Still rollomatic bar.
Nov 06, 2016 | Stihl Garden
Need repair and service manual for Stihl 012 chain saw engine
google the stihl web site and if there are manuals available ,you will find them there.
May 27, 2015 | Stihl 021 023 025 Ms210 Ms230 Ms250...
3003 008 8921 will start but the chain will not spin.
1. Check that the sprocket on the bar tip actually turnas and is free from obstruction.
2. Check chain tension is not too tight.
3. Check that you have taken the chain brake off. (pull the front hand guard back until it clicks)
4. If you have checked all the above, check the clutch.
May 05, 2013 | Stihl 3003 008 8921 Rollomatic E Laminated...
I have a Stihl 16" 012 AVT chainsaw. I cannot get
First thing I would try is wash out the oil tank with a little bit of diesel fuel then run some thinner oil thru it to see if it gets better . I usually leave bar and chain off when I do this.. or if it is oiling but not going down the bar check the bar oil holes.
May 10, 2017 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
I have a ms 290 farm boss with an 18" want to
Yes! So here are some links:
STIHL Ematic guide bars are engineered and manufactured to STIHL's strict quality control standards and are produced in STlHL's own factories. STIHL offers a full line of guide bars for all types of use from 10" for specialized wood carving applications with small saws through 59" for extreme felling operations. Explore our products to find the STIHL guide bar that's right for you. Locate your local STIHL dealer.
arrow_orange.gif STIHL ROLLOMATIC® ES Super arrow_orange.gif STIHL ROLLOMATIC® E Light
arrow_orange.gif STIHL ROLLOMATIC® E Standard arrow_orange.gif STIHL ROLLOMATIC® Mini
arrow_orange.gif STIHL DUROMATIC® E arrow_orange.gif Carving Guide Bar
Thumbs back!
Nov 07, 2010 | Stihl MS 290 Chain Saw include 20" 50cm...
The starter rope doesnt pull, and when the saw is
sounds abit like it ,but remove the spark plug and you should be able to rock the flywheel back and forth. sounds a bit like no oil in the gas or at least insuficient oil and may have grabbed, (i assume you have the chain and bar off the powerhead,if not then remove them ,and then try ) it could also be the centrifgal clutch jammed up.
Dec 29, 2009 | RTO Spur Sprocket For Stihl 017, 021...
I have a McColloch 16 in chain saw MS 1635 AV.
remove side cover,bar & chain.above bar mounting studs find a oblong channel that lines up w/ the small holes in the bar.clean everything,sawdust gets packed in the holes.if it leaks oil out the bottom,you need to replace the oil feed line fom the tank.
Sep 21, 2009 | McCulloch Garden
Weak spark on 55 rancher chain saw/ airgap on magneto
the air gap is .010 to .012 inches,hope this helps, if not contact me and i'll help you with anything i can
Mar 12, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
90 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
