Question about Master Lock 5400d: Portable Select Access Key Storage Lock
Reset the combination on a masterlock 4605D - Master Lock 5400d: Portable Select Access Key Storage Lock
2 Suggested Answers
  • 403 Answers
SOURCE: I found my old masterlock combination lock it has
had your looking for a combo, throw it out. no way to find the combo for it. serial only refers to the model of the lock. its like asking for a part for " my ford truck " not enough info.
Posted on Mar 12, 2011
I got the master lock speed dial combination lock but forgot my combination and it won't open. can somebody please tell me if i can reset the password?
1. Contact Masterlock.com and fill out the form, get it notarized and send it in for the combination to unlock it based on the S/N which is on the lock.(http://www.masterlock.com/faq/LostCombinations/). Good luck on this since Masterlock will end up finding something that will prevent them from giving you the combination. Its quite frustrating and NOT worth the trouble.
2. Go to home depot. Buy a 24in bolt cutter ($22) cut the stem of the lock. and replace with a new lock that you can buy from home depot for $ 29.00. If you have a key that is inside the lock box that you really need, You will now need to drill out the combinations piece by piece and the door will pop open or send the lock back to Masterlock. They will retrieve the key for you and send it back.
Aug 27, 2012 | Master Lock 5400d: Portable Select Access...
My master lock is locked and i don't know the combination to it
If this is an older masterlock with a serial number, you can fill out the form located here http://www.masterlock.com/pdfs/lost_combo_form.pdf
Read the below from masterlocks website: Due to increased security concerns nationwide, Master Lock recognizes the heightened need for additional safety measures. We no longer provide lock combinations in response to phone, fax, or email requests. Please follow the procedure outlined below to obtain the combination to your lock and submit your request to:
Master Lock Warehouse
1600 W. La Quinta Rd
Suite/WHSE # 1
Nogales, AZ 85621Procedure:
  • Print out the Lost Combination Form from a printer friendly page, or download the PDF file.
  • Have your Lost Combination Form notarized by a Notary Public to prove that you are the owner of the lock (you can include up to 6 combinations on one notarized form).
    • Note: Inmates at a correctional facility - in addition to the lost combination form, you must submit your request on official prison letterhead. In lieu of notarization, the form must be signed by a prison official.
  • Photocopy the serial number on the back case of your combination lock. This copy MUST clearly show that the lock is not attached to anything. Be sure to hand write the serial number on the photocopy.
  • Mail the original completed, notarized Lost Combination Form and the photocopy of the back of your lock to the address above.
Note: It will take approximately 4 to 6 weeks to process your request for a combination.
Note: If the form is not fully completed and notarized with a raised seal or rubber stamped seal, or if the serial number is not legible on the photocopy, your request will not be honored. Master Lock does not reimburse for any Notary fees.
Aug 27, 2011 | Garden
Bike lock enters half way and then jams, possibly reset by accident, how do you start over and reset?
Go to masterlock.com and they should have your answer. You can recover you combination etc, so I am sure that they can help you
Sep 08, 2010 | Master Lock Bicycle Lock
Master Lock 5400D Key Storage Combination Lock box i reset it combination a couple of days ago and it worked fine until today. Now it won't open with the new combination. How can I get in to it without...
Two solutions: (if the box is closed and it is attached to something)
Jun 25, 2010 | Master Lock 5400d: Portable Select Access...
I want to change my Master Lock combination
open the shackle twist 180 degrees...shut it as if u were closing it into the locking device..hold it down, put in what ur new combination is..pull the shackle up and shut it into locking device, and test it out.
Jan 25, 2009 | Master Lock 5400d: Portable Select Access...
Resetting the combination
The reset works when the current correct combination is set on the front. If you forgot the combination, you can go to the www.masterlock.com and download a PDF to request a combination from the factory to open it. It requires a notarized form & takes 6+ weeks. In the end, it is probably easier to buy a new one. When resetting the combo, I accidently scrambled it as I flipped it over. And did not know the combo. The reset button would not work. I did some guess work around the setting and got it to release again.
Jan 08, 2008 | Master Lock 5400d: Portable Select Access...
Master Lock 5400d: Portable Select Access Key Storage Lock Logo
119 people viewed this question
Top Master Lock Locks & Locksmithing Experts
Lawrence Oravetz
Are you a Master Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
