Question about Bond Helman KPM-508 Popcorn Maker
The glass door of our popper cracked during popping - is it possible to get a replacement door???
  • 5,603 Answers
It may be less expensive to contact a local glass supplier and inquire what TEMPERED glass would cost.
Have exact measurements and thickness when contacting them.
Posted on Apr 26, 2010
Is it possible to replace glass door for Kenmore Elite H5 dryer?
Hello Yuri;
My name is Peter. I am a retired field service appliance technician.
I am giving you a link for replacing a door handle. In this video you will see how to remove the dryer door glass.
I am also sending you a link to Sears parts where you input your dryer model number to find the part that you need. Put this part number into a web search and save about 40% on the cost. Water Filters Lawn Garden Appliance Parts Door Hinge Replacement part 8183202 Duet HE3 Washer Repair
Dec 30, 2014 | Kenmore Dryers
The unit only pops half of the popcorn
The symptoms of only pops half the popcorn is a hard one to trouble shoot.
1.Check your popcorn, old popcorn dries out. As it loses moisture its ability to pop is reduced. Popcorn only lasts about 90 days after opening the air tight packaging.
2. If it is a oil popper, make sure the stirring rod is turning during the popping cycle. They sometimes can stir, but once the popping starts the pressure of the corn can stall a motor. This results in the first half popping, and the second half burning on the bottom.
3. Popper is too cold. This has symptoms of a long, long popping cycle, and half the corn popping the other half just turning brown. Some machines had adjustable thermostats inclosed, most home units do not. Letting it pre-heat longer does not help, the temperature is controlled by a thermo-stat.
Mar 07, 2013 | Kitchen Appliances - Others
Paragon Popcorn Popper Thrifty Pop 4 OZ Parts
I run a part-time hot dog stand in Nashville, TN. I've bought parts from Fine Entertaining . I'm better sure they sell popcorn popper. Paragon Popcorn Popper Thrifty Pop - the manual is under the resource section.
May 25, 2012 | Paragon Theater Pop 4 Popcorn Maker
How do i remove rear inner door panel on my Peugeot 407.Child sun shade jammed inbetween glass and rubber seal
should be screws behind rear door handle u have to take cover of screws will be behind u also need to remove the winder 4 window if manual and not electric the panel itself will be held on with poppers just grab bottom of panel and pull hard then work yuor way up sides once you have unclicked poppers from bottom and side of panel grab panel and push upwards as most weather strips are attached to the panel .
Jul 26, 2010 | 2006 Peugeot 405
Glass in oven door cracked
The door glass can be replaced.
I would advise you not to use the oven until you get the glass replaced, as it can quite suddenly and without warning shatter into small pieces. thus causing further problems, and possibly injury.
Hope this helps.
Jan 31, 2010 | Whirlpool Ovens
Replace a window regulator in a 1994 ford explorer
wow, a lot of work to do.
Window Regulator, Front Door, Explorer Removal
srk~us~en~file=ani_caut.gif~gen~ref.gif WARNING: IF THE REGULATOR COUNTERBALANCE SPRING MUST BE REMOVED OR REPLACED FOR ANY REASON, MAKE SURE THAT THE REGULATOR ARMS ARE IN A FIXED POSITION PRIOR TO REMOVAL TO PREVENT POSSIBLE INJURY DURING C-SPRING UNWIND.
  1. Remove front door trim panel and front door trim shield . Refer to Section 01-05B .
  1. Remove inside door belt weatherstrip and glass stabilizer.
  1. Remove front door window glass as described in this section.
  1. Remove two nut and washer assemblies attaching the equalizer bracket.
  1. Remove three rivets (manual) or four rivets (power) attaching the regulator base plate to front door trim panel finish panel (23712) .
  1. Remove window regulator electric drive and front door window channel bracket from vehicle.
  1. Working on a bench, carefully bend tab flat to remove arm slides from front door window channel bracket .
  1. Install new window regulator electric drive arm plastic guides into front door window channel bracket and bend tab back to 90 degrees. Use care not to break tab; if tab is cracked or broken, replace front door window channel bracket . Make sure rubber bumper is installed properly on new front door window channel bracket , if replacement is made.
Installation
NOTE: The front door window channel bracket and window regulator electric drive are installed into the vehicle as one assembly. The front door window channel bracket may be disassembled from the window regulator electric drive as described in Steps 7 and 8 of Window Regulator, Removal.
  1. Install front door trim panel finish panel with preassembled glass bracket into vehicle. Set the regulator base plate to window regulator electric drive using base plate locator tab as a guide.
  1. Install three (manual) or four (power) rivets (385189-S100) to attach regulator to front door trim panel finish panel . Two 1/4-20 x 1-inch bolts and two 1/4-20 nut and washer assemblies may be used as alternates for glass retention. However, torque must not exceed 4-7 Nm (3-5 ft-lb). Equivalent metric retainers may be used.
  1. Install equalizer bracket.
  1. Install inside door belt weatherstrip and glass stabilizer.
  1. Lower regulator arms to access holes in front door trim panel finish panel . Install front door window glass as outlined.
  1. Adjust glass to ensure proper alignment with glass run. Cycle glass for smooth operation.
  1. Install front door trim panel and front door trim shield . Refer to Section 01-05B .
Apr 11, 2009 | 1994 Ford Explorer Limited
Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
you should be able to just replace the glass
Jan 12, 2009 | Ovens
Self cleaning caused interior glass to crack
hi there,
this is called thermal breakage. basically, when the mfg. makes the glass, they either don't cook it long enough or let it harden long enough during manufacturing. remember, the glass is supposed to withstand over 1200 degrees, which is temperature during self cleaning. have a technician replace the door glass, as warranty should cover this.
thanks
Sep 26, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Interior Range Window cracked - How to Replace
It is simple enough not to need a manual.
1- open the door, then pull outwards. The door mounts slide right out.
2- lay flat on a towel on the floor. Remove screws on the inside of the door.
3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
4- replace broken inner glass panel
5- put each piece back together, install screws
6- slide door (mounts) back into their homes on the front of the range
It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
Apr 06, 2008 | KitchenAid KGRT607 Gas Kitchen Range
Bond Helman KPM-508 Popcorn Maker Logo
90 people viewed this question
Top Bond Helman Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Bond Helman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
