Question about Craftsman 25cc Gas Line Trimmer
Need gas line sketch for craftsman brush wacker 32.cc
    Sniper:
  • 52 Answers
Most 2 cycle engines are basically the same. The primer button has two lines coming from it. Gas is actually s.ucked thru the carb and not pushed thru when you prime it. Take a look at the sketch I provided and hopefully you will get yours running again.need gas line sketch for craftsman brush wacker - 58fe8f0.jpg
Posted on Apr 26, 2010
  • djcarmon Apr 30, 2010
    I had the same problem. I hooked it up the way you mentioned. It causes a siphon reaction. Fuel flowed out of mine when I stopped it also. Have you replaced the diaphram in the carb? If not, that could be the reason it won't start when hooked up the way shown.
  • Erick Grier Jul 07, 2015
    I hooked my craftsman weeder up according to the above diagram after trying everything else and now she works like a charm.. Thank You.. :)
I have a Craftsman 31cc trimmer. If I connect as shown in the drawing with fuel inlet on the bottom of carb (opposite needle valves) and return on top (needle valve side), I cannot get it started. If I reverse the two hoses on the carb, the trimmer starts and runs OK. The problem with this configuration is when I shut it off gas drips from the air intake on the carb. Any thoughts?
Posted on Apr 27, 2010
Craftsman weedwacker model 316711970
If you go to searsparts.com and put in your model number it will show you a drawing of your weed wacker. Not sure of what you are looking for. Hope this helps.
Jul 09, 2015 | Craftsman 29cc 4Cycle Straight Shaft...
17" 32cc gas weed wacker
Hi pmbaugardne...
Please take time to rate me
Sep 19, 2011 | Craftsman Garden
Need to fine gas tank replacement part for craftsman weed wacker model number 04182N501231
Hi mperez40
Go to the following webpage and you will be able to locate what you need and be able to order it also.
It is the Sears Parts webpage with will also have phone and email support in case you canhnot locate the part by yourself.
Please rate me
http://www.searspartsdirect.com/partsdirect/product-types/Grass-trimmer-weed-wacker-Parts
Jun 25, 2011 | Craftsman 25cc Gas Line Trimmer
I have a 32cc Craftman Brush wacker trimmer and the fuel line fell apart I need to know how to install the new ones.
This problem seems to be the biggest and most popular one by far in these forums and has been answered several times. Try and post your problem using the search feature on this site. Don't use too many words. Craftsman Weedeater Fuel Lines should be sufficient. If you can't get it, then post back here again please.
Aug 07, 2010 | Craftsman 25cc Gas Line Trimmer
I need a replacement head for my 25cc crafstman weedwacker gas line trimmer. I need the whole piece that screws into the bottom of the weed wacker. It is the whole part that spins when the wacker is...
You can find a complete trimmer head replacement at Hyperparts.com. Go into the Lookup By Application section and select the make and model of your trimmer to see a list of the heads they offer.
Jun 28, 2010 | Craftsman 25cc Gas Line Trimmer
32 cc craftsman trimmer starts but will not run at full rpm
Air fuel mixture problem,,,you need to have the filter pulled out and cleaned. Check fuel system for debris and clean, that includes all the fuel lines and possibly disassemble carb and clean and reassemble.
Apr 27, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman weed wacker trimmer head won't turn
it could still have the broken peice from the old one inside the seat.take it apart and look inside and inspect the seat where the drive cable enters.
Apr 13, 2010 | Craftsman 25cc Gas Line Trimmer
Hve a Craftsman Weed Wacker 24 cc Need to find out how to put new nilon cord in the weed wacker its been some time since i've done this.
http://www.craftsmanlawn.com/WeedWacker_Weed-Trimmer/358.795310/
Go to VIEW MANUAL. Then the process you seek is on PAGE 10.
Jul 08, 2009 | Craftsman Garden
My craftsman 32 cc 2 cycle line trimmer doesn't
Check the line head and cable, there may be grass or something like twine twisted between the shaft and housing. If nothing is found there take the spark plug out and see if it will turn over, possibly liquid gasoline has gotten into the cylinder somehow.
Jul 05, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32 cc
Your gas cap is probably clogged with dirt. The next time you run the trimmer and it begins to stall out, loosen the gas cap, it should start to run good again. Gas cap must be able to breathe in order for gas to flow properly.
Jim
Jun 04, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
1,929 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
