Question about Craftsman Garden
Governor shaft positioning on 6.5 Tecumseh lawn mower engine
The engine is in the family of VTP195UIGISA with model mumber 143.986504. I need to know the position of the governor shaft and the proper connection of both spring and solid attachments to the shaft from carburator. I have a Tecumseh disk of Service and Repair manuals but it does not include this particular engine. Thank you for any help you are able to give me.
  • 57 Answers
SOURCE: Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
Posted on May 19, 2009
  • 279 Answers
SOURCE: i need to know how to adjust the carbureator on an
If it has a float type carb, open it 1.5 turns. If it has a diaphram open it one turn. If it has a Walbro carb, there is no adjustment. Once you get the engine started you may adjust the carb to fine tune. Open until it begins to lose RPM's then close until it starts to lose RPM's. Return to a point between the two. Good luck...Lee
Posted on Sep 05, 2009
  • 25 Answers
SOURCE: I removed the carburator from my Murray 22
Have a look at this page - it has diagrams and instructions for getting the linkages right:
http://www.angelfire.com/mb2/visitme/mower/tecumseh.html
Posted on Dec 03, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Lawn mower sounds like it is running fast and vibrating.
Sounds like a bent shaft, or bent blade.
Also sounds like the part that holds the blade to the shaft is sheared, and allowing the motor to run faster than it would if it is turning the blade properly.
Hope this helped,
Please rate me
Posted on May 26, 2010
Testimonial: "Your response was very helpful. Is there a repair manual or instructions online that I could get to describe the process to repair the mower? Again thanks for your response. "
rycgl
  • 1545 Answers
SOURCE: i need the correct way to connect the governor
this may not apply exactly to your particular model, but it is for Tecumsehs and may get you on the right track:
Posted on Jul 13, 2010
How do correct RPM surge on a LH 195 Tecumseh engine
Hi you're governor gears inside the motor could b the problem ...good luck
Aug 11, 2015 | Tecumseh Garden
Model 31G777 Need to know what the timing position is for this engine please ,As stated earlier I have it at 3 o clock it wont start . ideas please
Don't waht your trying to with the 3 o'clock position but crank and cam timing marks align with each other.
Instructions from service manual:
Install Crankshaft and Camshaft
1. Lubricate the cylinder bearing/oil seal with engine oil.
2. Install intake and exhaust valve tappets.
3. Support both ends of the crankshaft, and carefully install into the cylinder.
NOTE: The counterbalance system, if equipped, must be assembled to the crankshaft before installing into the cylinder.
4. Assemble connecting rod assembly to crankshaft.
5. Install the timing gear to the crankshaft with timing mark out. The flange of the gear must face the counterweight link, if equipped.
6. Install camshaft, making sure tappets clear cam lobes. Timing marks (A, Figures 6, 7, 8) must align.
7. On horizontal crankshaft engines, make sure the paddle on the governor shaft (B, Figure 6) is rotated in line with the governor cup inside the crankcase cover.
8. On vertical crankshaft engines, assemble governor gear/oil slinger (B, Figures 7 and 8) to camshaft. Make sure the paddle on
the governor shaft is contacting the governor cup (C).
Apr 07, 2015 | Garden
13 hp tecumseh riding mower engine surges when mower is not engaged. It runs well when mower is engaged
"Govenor hunting" caused by a lean condition ,carb is starving for fuel ! Dirt in carb or water,or out of adjustment ,or leaking throttle shaft ....usually it is a plugged low idle passage,that causes this condition,and is almost impossible to remedy,but a good cleaning might help .....does it only governor hunt at low idle ? If so thats the issue !
Jun 05, 2014 | Tecumseh Garden
I need to know how to adjust the governor on my MTD model 31A-62EE729 snowblower with a 179cc motor
lossen the nut on the governor shaft, and move the arm toward the carb while holding the arm in this position turn the shaft counter clock wise and tighten the nut. and you are done. GOOD LUCK
Sep 03, 2013 | Tecumseh Snowblower Snow Blower Starter...
Speed of the lawn mower governor is missadjusted
The engine revs are turned down to make the machine noise compliant, increasing the revs will greatly increase the noise, the engine revs shouold not realy be increased, however a dealer with a suitable engine taco may do it for you, it is very important not too over speed the engine or it will self destruct,
Apr 11, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
I have a 10 hs tecumseh motor on a riding mower i need an explode view of carb and linkage when start-up engine it goes wide open
Hi and welcome to FixYa, I am Kelly. I understand you have a 10 HP Tecumseh engine. There are service manuals available on line for your engine but without your engine model number it is difficult to pass you the correct one: Here is the link for the service manuals:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals
Somewhere in the list is your manual.
This is my best guess without your engine model number:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals/TECUMSEH_SERVICE%20_REPAIR_MANUAL_OHH50-65_OHHSK50-130_OHV11-OHV17_OVM120_OVRM40-675_OVRM120_OVXLC120_OVXL120_OVXL125_695244A.pdf
^-Make sure you read about Adjustments in section 1 also.
Running wide open causes:
1. Broken throttle control plate spring
2. Governor spring problem
3. Internal Governor flyweight has departed the governor gear.
4. Throttle plate (butterfly) attached to the throttle shaft in the carb throat has come off the throttle shaft.
5. Broken / missing linkage
6. Someone loosened the governor shaft bolt at the base of the governor arm and allowed the governor to get out of adjstment.
Thanks for choosing FixYa,
Kelly
Aug 12, 2011 | Tecumseh Garden
I mixed up one spring and the mower idles low on craftsman eager-1 5.0 22 inch cut
I think that model may use the Tecumseh engine and carburetor application. Here is a diagram of what your machine (carb/choke and governor) should look like.
May 14, 2011 | Craftsman Garden
I have a lawnmower with a tecumseh 173 cc engine that has experienced a sudden loss of power what could be causing this and how do i fix it
Ok, on the left side of the engine at the rear part of the block is a speed governor on Tecumseh vertical shaft engines. there is a spring that connects the governor to the throttle, if that spring is somehow broken or disconnected it can cause the problem you are experiencing. Check for that spring...if necessary, you can order a replacement through your user manual...cheers!
Sep 07, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
268 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
