How to boot from usb port to install 2003 server
How
  • 871 Answers
WELL, easy...go to bios and look it up in booting sequence. but not all motherboards supports this feature. if your mobo has this. then you lucky.
Posted on Mar 25, 2008
SOURCE:
Driver irql not less or equal while server is working in win 2003 std server os this error will come on blue screen and after that we have restart the server. i have updated the bios and installed all the...
Use a utility like Nirsoft BlueScreenView to find the stop code from the crash dump. This may also allow you to identify the driver causing the issue.
If your USB ports are malfunctioning, this may indicate a hardware issue with either the ports, motherboard, or PSU. Check for obstructions, broken connectors or other such problems.
Please reply with more information such as the server model information, stop code, driver name, etc. for more help.
Oct 24, 2013 | IBM Computers & Internet
How do i install windows 2003 standard, to my new Acer AT110 F2? on Acer smart cd there's no option for 2003 server :(
I just checked the specs and it supports Windows Server 2003 so it must be possible. They probably did not make a setup wizard for it so you will have to do it the "old fashioned" way. Load the Windows Server 2003 disk in the CD/DVD drive and boot to it as you would any Windows install. If it reaches the screen where it displays the hard disk(s) you are good to go. While the installation is running go to Acer's website on another computer and download the 2003 drivers to a USB drive. When the installation completes, install the 2003 drivers and you are ready to customize it to your needs.
If it doesn't find the hard disks, you probably purchased the optional PCIe 4-port SAS RAID card and Windows 2003 doesn't have a built-in driver for it. You will need to press F6 after Windows install starts so it will prompt you later for a driver for your disk controller. This will allow you to manually install the driver which you should be able to find on Acer's website. (F6 Info: http://en.wikipedia.org/wiki/F6_disk)
I hope this helps!
Nov 30, 2012 | Acer At110 F2-E3-1220 E3 1220 1P
Cant install new operating systems from USB or CD and have RAM Issues.
And you changed and saved new boot order in BIOS?
You may have a bad DIMM. Test one card, one slot at a time till you identify the bad one.
Nov 27, 2012 | IBM eServer xSeries 206
How to install server 2003, hard disk not detected
This usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Aug 21, 2011 | IBM x3200 M2 Server
I cannot get my EX495 to recognize my bootable USB drive in the bottom port on the back (or any other port). I have wiped the 1.5 TB drive and formatted it. I have a KVM connected to the MSS and have...
KVM are known to be very very unreliable. some work a bit
or only partly , or are intermittent. (i can talk all day on this horror)
the usb drive, is booted by BIOS and nothing else.
so if BIOS can boot to it, ever think that is not a feature on this old PC server>
the PC came with 3 OS options
XP,,windows home server or windows server 2003
what OS???? you posted with NO OS STATED.
id test that USB port (or all of them) to see what it can do and cant do Boot-wise. ? can it boot a USB stick? with say linux, live?
if not, then its not a feature of your BIOS. !
has 4 x USB 2.0v ports (old type)
USB 2 only has 0.5amps of power (weak) and will not run HDD unless its in a case with its own 1amp or more power pack.
that is a fact. so buy a real case for it and a real power pack
HDD suck lots of power, for sure startup. !!! (has motor)
the hardware ex495 is old, it has NO HP support now.
seems 2009 year. did hp drop support early? seems so..
no books, to read about its BIOS limits. , why use this old PC?
that link you put up is old, and no activity there.
first get rid of the stinking KVM, when all works alter do KVM horrors far later.
then go here.
why not ask HP,???
https://h30434.www3.hp.com/
old PC did not boot to external drivers.
this we know. at what year this started, not sure.
my guess.
no external HDD stated, or its maker or model nor if it has a power pack, that I must have, for USB2,
BIOS may not like to book hdd. external...
your inputs are lacking,,
like , internal driver boots and works perfect? be a key fact.
Jun 27, 2017 | HP Computers & Internet
HI I Trying to restore my ASUS EEE PC 900. It has no CD drive. I tried doing the F9 option but it does not seem to work. It keeps bringing me to the black screen where it says safe mode, start windows...
Method 1 :
  Installed Operating system with an external usb CD or DVD Rom drive.Set your laptop to boot from USB CD ROM in your BIOS.
Method 2 :
  Yoou need an PC with windows server 2000/2003 with RIS (Remote Installation server Set up plus DHCP (Dynamic Host configuration protocol) server ).Change your laptop BIOS Boot setting to boot from Network and installed as if you are installing through  normal procedure.
For more information on setting up RIS Server and DHCP.
here is the link
http://support.microsoft.com/kb/298750
http://www.windowsnetworking.com/articles_tutorials/Setting-Up-DHCP-Server-Organization.html
Dec 20, 2009 | ASUS Eee PC 900 Notebook
Boot from CD is not recognizing the Windows 2003 Server CD
hv u tried booting from other CDs .
if u can boot from other CDs , then this 2003 CD is botched , change it.
Jan 05, 2009 | Dell PowerEdge 1600SC Server
USB booting of external hard disk in HP laptop
You cannot boot Server 2003 from an external USB Hard Drive, it will have to be installed on an internal hard drive.
Dec 05, 2008 | Computers & Internet
Hello , i have Windows Vista home premium edition installed in my HP laptop , i tried to connect USB external hard disk (containing Windows Server 20003 ) to my laptop USB port . means i want USB...
I do not believe that server 2003 is able to be ran from a USB device, I may be wrong, but I doubt it. To see what the error message is, you can be ready when it pops up and push your Pause/Break button on your keyboard, this should freeze the screen so you can see exactly what it says.
How did you install the server o/s to the external drive?
Open Questions:
Computers & Internet Logo
123 people viewed this question
Ekse
Alun Cox
