Question about Bugaboo Cameleon Stroller
Handle adjustment on bugaboo chameleon
Adjustable white wing screw to extend handle keeps turning and not locking.
    Champion:
  • 274 Answers
THERE IS A COMPANY CALL BUGGY PITSTOP AND THEY DO REAIRS AND SERVICING ON BUGABOOS THEIR WEB SITE IS www.buggypitstop.co.uk
Posted on Apr 27, 2010
    Guru:
  • 541 Answers
I just love all that advice about www,buggypitstop.co.UK makes me want to emigrate back to good old Blighty I'm from Twickenham (NOT) Problem is I'm in New Zealand and p21tds in almost certainly in the good old USA. Where 99% of eBay sellers ship USA only 8-( So lets get practical. Sound like you stripped the thread. You are going to have to find a local small engineering firm or machine shop. They can fix it in half an hour for around $50 with an amazing thing called a "helicoil". That's cheaper then USPS or Royal Mail charges.Handle adjustment on bugaboo chameleon - macnutz_12.jpg
Posted on Nov 03, 2010
  • Stephen Faulkner
    Stephen Faulkner Nov 03, 2010
    PS Only take the frame those places can be a bit to dirty for a Sand Coloured Bugaboo!
First gen bugaboo bee handle locks
Hi Nadia
We cannot assist as this product is not manufactured by us. If Bugaboo can no longer provide help it is unlikely anyone else would be able to as the manufacturer they are the only company who would be able to source spare parts and carry out inspection and repair work required.
Dec 01, 2013 | Bugaboo Bee Baby Gear
When bumping up stairs handle bar extends, and feels loose (handle bar is very wobbley)
The Bugaboo is not the ideal stroller for bumping up and down stairs, The reason being it's core design. Most stroller handles have two or more mounting points to the frame but most strollers have baby facing forward and facing the big bad world and not Mummy. The Bugaboo is very clever, the handle can be locked ether way and the seat face either way but the handle has only one point where it attaches to the frame and that point has to rotate and lock. To give you an idea of the forces involved a crow bar the length of the Bugaboo handle can pull six inch nails out of hard wood!
Unfortunately Bugaboo have not used the best material solutions in this critical handle lock. They use a plastic disk to move aluminum locking pins and they fail if you bump down to many stairs. This happened to our Bugaboo in New Zealand. I repaired ours and now I help others by making or sourcing the better quality parts to repair them. I use aluminum for the disk and stainless steel for the pins.
If you are lucky another to have a Bugaboo less then two years old and still have proof of purchase documents Bugaboo will replace the frame for you. If it's older you can buy a new frame for around $400 but this will also increase you resale value by around $200 when you sell it. Lastly you can repair it for around $100 a side depending on parts required, Click on my name and you'll find many posts on how to repair both the Handle lock and the Handle extension lever or wing-nut. macnutz_23.jpg
Nov 26, 2010 | Bugaboo Cameleon Jogger
My cameleon has become very loose, the frame flexes when pushed on a slope. It seems particularly loose at the main pivot point on the frame.
This is a far to common fault with Bugaboo's If it's less then two years old Bugaboo will replace it. If older you can buy a new one around $400 if yours is the older wing nut version you will improve your resale value with the newer lever version. Or you can fix it for around $100 a side. Depends on what parts are broken.
How to fix a Bugaboo Handle
If you are not a handy-person type, take these instructions to you local Bicycle Mechanic or Small engineering shop.
The bugaboo handle fault is caused either by two small plastic pins shearing of a plastic disk that actuates two metal locking rods. Why bugaboo uses a plastic disk for this critical component is beyond me! Or a broken locking rod
1/. Remove the capped star lock washer. This is the hardest part of the job. Most people try to leaver this off in the hope of re using. First problem with this is you will mark or damage the surrounding plastic second is star locks are not intended for reuse and will never hold as well as when first used, so best find a new replacement. A hardware store should be able to source some for you. Quickest way to remove a capped washer is to carefully cut a slot in the dome with an angle grinder and then use a large screwdriver to carefully prize one side up so you can fit a screwdriver. Note the walls of the aluminum hub axel are thin and easily distorted, make sure you only lever the capped star lock and not hub axel. Use one screwdriver as a support and another to lift off the capped star lock.
Note it is best to open and repair one side at a time, so your moving and flexing one side of the handle does not dislodge parts in the other side. The hub and disks are mirrors of each other and not interchangeable. The side with the brake lever is left The Bugaboo parts will have an "L" after their serial numbers.
2/. The lock mechanism is very simple; a wire rod rotates a plastic disk. Check the hubs for ware. If too badly worn or damaged you will have too much movement in the locked position. The Frog and Chameleon use the same plastic hub find another frame to salvage hubs from. They are held in by a single aluminum rivet.
The disk has two plastic pins that move the locking rods in and out of the inner hub into and out of the outer hub. You need to either repair the disk by drilling out the pin stumps and finding a replacement metal screw you can fit / glue in. Or (my preferred choice) have a new metal disk fabricated that will last a lifetime.
3/. Reassemble handle locking hub and check operation. If wire rods seem to be in the incorrect position, loosen the top plastic fittings where the handle extends from by removing the small self-tapping screws and wiggle things into alignment. (I use a small amount of the grease used for taps to give a smooth action) If all is working well fit the new capped star lock on the hub shaft and tap home. To protect the dome finish I use a large socket from my socket set and an old rubber washer from a toilet cistern. Repeat operation on the other side
I have parts available laser cut metal disks with stainless steel pins, replacement locking rods in stainless steel and capped star lock washers you can contact me at macnutz@xnet.co.nz
Regards
Steve
Nov 22, 2010 | Bugaboo Baby Gear
I have a bugaboo wlth the white colour brake and have just found out that the white colour ones are out of date. my question is does anybody know if i can get it changed over to the red one and how much...
Bugaboo don't sell parts as such but they sell the chassis. It will coat you around a third of the price of a new Bugaboo. The new Red brake lever chassis has the lever extension handle locks instead of the wing-nuts and rocker style buttons for the handle release. Your old frame will be quite sort after on eBay. I like the rocker handle release and the extension levers are quick to use and look better but I must warn you the old wing-nut system held the handle better and if you bump down a lot of stairs the new lever system is more prone to slipping, macnutz_16.jpg
Nov 21, 2010 | Bugaboo Cameleon Jogger
Is there a store or person who can repair a Bugaboo Cameleon chassis in the Boston, MA area? I'm having trouble with the handle bar. The small white tab on the right side is stuck and so the handle bar...
If you are not a handyperson type, take these instructions to you local Bicycle Mechanic or Small engineering shop.
The bugaboo handle fault is caused by two small plastic pins shearing of a plastic disk that actuates two metal locking rods. Why bugaboo uses a plastic disk for this critical component is beyond me!
1/. Remove the domed star lock washer. This is the hardest part of the job. Most people try to leaver this off in the hope of re using. First problem with this is you will mark or damage the surrounding plastic second is star locks are not intended for reuse and will never hold as well as when first used, so best find a new replacement. A hardware store should be able to source some for you. Quickest way to remove a dome washer is to carefully cut a slot in the dome with an angle grinder and then use a large screwdriver to carefully prize one side up so you can fit a screwdriver. Note the walls of the aluminum hub axel are thin and easily distorted, make sure you only lever the Domed Star Lock and not hub axel. Use one screwdriver as a support and another to lift off the Domed Star lock.
3/. Reassemble handle locking hub and check operation. If wire rods seem to be in the incorrect position, loosen the top plastic fittings where the handle extends from by removing the small self-tapping screws and wiggle things into alignment. (I use a small amount of the grease used for taps to give a smooth action) If all is working well fit the new star dome on the hub shaft and tap home. To protect the dome finish I use a large socket from my socket set and an old rubber washer from a toilet cistern. Repeat operation on the other side
I have available kits with two (left & right) laser cut metal disks with stainless steel pins fitted and two new star dome washers. Cost is $150 New Zealand plus shipping. If you like a set, you can contact me macnutz@xnet.co.nz
Regards
Oct 15, 2010 | Bugaboo Cameleon Jogger
Bugaboo chameleon frame not locking into place
www.buggypitstop.co.uk are the only company that repair bugaboo handles.Highly recommended they will fix it at a faction of the price of a replacement handle
Feb 24, 2010 | Bugaboo Cameleon Jogger
Chameleon: brake not secure and extendable handle lock jammed
This has been solved elsewhere on this site - do a search, but spell Cameleon without the H in it and you'll find it
Aug 31, 2009 | Bugaboo Cameleon Jogger
Bugaboo Parts - where can I buy a replacement handle bar / carry handle?
You should purchase your accessories direct from www.Bugaboo.com
email: serviceus@bugaboo.com or call 1-800-460-2922. This way you can make sure that you don't void your warranty.
Good Luck! from Moms Just Know
Oct 20, 2008 | Bugaboo Cameleon - Tailored Fabric...
The lock on the brakes of my bugaboo cameleon doesn't work.
I just repaired my Bugaboo Chameleon brake. If the white brake lever doesn't "lock" i.e stays in its forward position, locking the brake you need to disassemble the brake handle housing. Open the black plastic cover by unscrewing the two screws. The handle should come off with a little tweaking. Remove the brake wire. The "button" where you are supposed to release the brake is actually a sort of cogwheel that stops the lever from springing back. Sometimes the cogwheel gets too pushed in the handle. You can tell if it has done so by observing the 8 small grooves that are out of place. Simply take a small flat object like a flat screwdriver and pry the button out. It should pop out as it is spring loaded. Now put it back in its position but TURN IT so it fit in the grooves. Put it back in the black handle, by reversing the disassembly process. Easy!
Best Regards,Fred, Stockholm, Sweden(Sorry about the English, hope you understand)
Aug 17, 2008 | Bugaboo Cameleon Jogger
Bugaboo Cameleon Stroller Logo
160 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
