Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
I am looking into getting a 12" kicker L7 solo-baric and it says its 1500 watts max and 750 rms. duel voice coil. My question is I have a alpine mrp-m500 amp. Will this amp do enough to make the sub sound good or should I get bigger? If so what would you suggest. Im gonna put it in a extended cab chevy 1500. Also would you suggest a ported or sealed box? uim just gonna set it on the back seat. Thanks, Kyle
    Sniper:
  • 57 Answers
That will push it but you could use more power. Like a kicker zx750.1 which is designed for the s12l7 and s15l5. As far as ported or enclosed all depends. If you want deep sounding base then ported. If you want to feel (rattle your chest and truck) the bass then enclosed. If you use the alpine amp then i would wire it parallel. If you get something more powerful (kicker zx750.1) I would wire it in a series to provide some protection for the speaker so you don't overload it even though it can handle that much power.
Posted on Jun 28, 2010
    Problem Solver:
  • 10 Answers
There are the best get the memphins
Posted on Apr 27, 2010
I have 2 12
To be on the safe side without further information I would hook the two subs up in series leaving you with an 8 ohm load.
Nov 12, 2012 | Kicker Solo-Baric L7 12'' Car Speaker
I have a Kicker Solo-Baric, L7, 12 inch subwoofer making a scratching noise. The cone is fine but the inside is not. Can i get this repaired? Kicker said no. This is a $250-300 sub. I hate to just throw it...
The bad news is that your voice coils could be fried up, basically mechanical failure. Might as well buy a new sub because replacing a voice coil means you got to rip the whole sub apart, very complicating.
Oct 15, 2010 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
I have 2 15 inch L5 solo baric subs and need a amp?
the 15" l5 is rated at 750 watts rms so i suggest you get an amp with atleast that much power because if you get a amp weaker than that you run the risk of clipping your subs and blowing them
Jul 15, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How to run the speaker wires to connect to the subwoofer? and does a sub woofer burn if you do not put the right ammount of watts to it for example having an kicker l7 connected to a three houndred watt...
i'm guessing you are having problems with the dual voice coil's so I will link you to the kicker wiring guide...
http://kicker.com/sites/default/files/SoloBaricL72006.pdf that has the wiring options, you will need a pdf reader **** as adobe or foxit..
Under powering your subs won't hurt them but running a 15 inch l7 at 300 watts is not going to let the sub perform at peak, I would go with a 800 to 1000 watt amp.
15 inch l7 watt's are as follow
rms = 1000
peak = 2000
Mar 16, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have my l7 solo baric on series mode they sund
Hello rigo11785,
The MTX Thunder 1501D is stable at 1ohm and outputs 1,500 watts RMS into that impedance. An L7 with 2ohm DVC's would present a 1ohm load if wired in parallel and would allow the amp to produce more power than into the 4ohm series load. The problem is that the L7's maximum power handling rating is only 1,000 watts RMS, so if you wire the coils in parallel, you'll very likely overdrive the sub and perhaps damage it. Now, if you bought another L7 and ran the voice coils in series and the subs in parallel, that would be a 2ohm load and well within their power handling capability.
With that amp and sub, I'd recommend leaving the voice coils in series.
Hope this helps.
Jul 28, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Got a 12"kicker L74ohm sub and sony xm-D9001GTR mono amp
Hello juan_penaloz,
The Kicker L7 has an RMS power range of from 50-750 watts and a maximum power handling capability of 1,500 watts so your Sony amp will power it OK. A more powerful monoblock like the Alpine MRP-M1000 or the Kicker 08ZX750.1 would provide even more power and could operate safely at 2ohms.
You have the voice coils wired properly for the Sony amp. It's OK to have the sub impedance higher, but you definitely do not want it lower than the 4ohms the amp is rated at in bridged mode.
Hope this helps.
May 26, 2009 | Sony XM-1252GTR Car Audio Amplifier
What amp need to use for Kicker (2) S12L7 12in Solo Baric
you should use an amp with approx half the power of the speakers max output (i.e 1000 watt speaker use no more than 600 watt amp)
May 12, 2009 | Kicker (2) S12L7 12in Solo-Baric L7 + (1)...
What Amp would i need to push three Kicker L7 12's?
It depends on the specific subs and exactly what you want out of them. You have practically unlimited choices for amps.
The 10" L7 has a power range of from 30-600 watts RMS, the 12" from 50-750 watts, and the 15" from 100-1000 watts.
So if you have the 10's, you would want an amp that puts out at least 90 watts RMS and not more that 1,800. Unless you are really into SPL and have an unlimited budget, it's probably best to go somewhere in between.
Keep in mind that these Kickers need to be in a proper enclosure. They like a little more volume to work as compared to RF's or MTX's and some others.
Mar 30, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
How to order
The L7 I have is brand new in the box (not a speaker box just the retail packaging box) and the rms is 750 watts RMS and 1500 watts peak, but you are correct they blow easy when you push rated power to them, the hifonics subs will take 1200 watts rms all day long and over 3500 peak for burping at competitions, i run mine at 2000 watts everyday in a daily driver. if you hook 1 dual 4 ohm sub to a zx1000.1 it will be 2 ohm load on the amp so you will get 1000 watts to the sub so if you want to run it slightly underpowered to keep it from blowing use the 750.1 per sub, i can do those at about 250 each shipped
the price is 150 plus 10$ flat rate USPS shipping and yes I accept paypal Wyattconnolly@msn.com .
the warranty starts the day you buy it for 12 months but kicker will not cover burned or blown voice coils, that is why i recommended the hifonics (which is what i use to compete with now) because they put out better quality sound and alot more of it and they will take alot of abuse, if you want boxed speakers ready to go in kicker brand ported boxes I can have them drop shipped right to your door as well, the only reason i am selling the 1 L7 i have so cheap is because a customer ordered it then never paid for it so I am selling it at cost. be careful if you are buying on ebay as you have no warranty at all and you cant force the seller to give you 1 even if they say it has 1. because authorized dealers are not allowed to do internet sales at all so kicker and most other companies will not honor the warranties.
also you dont need 2 amps you can use 1 bigger amp and still run 2 subs just by changing how you wire the subs at the amp. 1 large amp costs less than 2 smaller 1's usually just not with kicker brand
Sep 15, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
12" kicker solo baric L7
WHAT DOES DRAGGING MEAN?
I USE TO BE AN CAR AUDIO INSTALLER ,WHATS YOUR QUESTION?I NEED MAKES AND MODELS AND HOW ITS SETUP AND WITH WHAT..IF THE WOFFER IS MAKING A STUDERING SOUND WHEN A VOICWEE IS BE PLAYED ITS BECAUSE YPUR NOT SENDING LOW FREQ> SOIUND TO SUB ONLY,.
Jan 25, 2008 | Kicker Solo-Baric L7 12'' Car Speaker
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
136 people viewed this question
Top Kicker Car Audio & Video Experts
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
