Question about Microwave Ovens
When turned on sparks fly - Microwave Ovens
  • 999 Answers
There is bare metal inside and if it is empty (un-loaded) the sparking can occur.
Posted on Apr 27, 2010
Sparks Flying
Microwave ovens are covered with a special durable paint and that helps reduce sparking. The problem is the area that you are seeing this at has become dirty with food debris. You need to clean it very well and if the paint has come off, repaint it with special paint. The paint can be found on amazon dot com and the cleaning has to be done without getting any moisture in the wave guide (which is behind the thing you called the vent.)
Nov 25, 2013 | Microwave Ovens
GE JES1290SK microwave magnetron is arcing
I don't know about a recall, but if your unit is under warranty parts and labour are included in most cases.
Sep 03, 2012 | GE Microwave Ovens
My Goldstar MV-1310W microwave has sparks flying from the metal plate that's inside on the top.
Microwave ovens do not work well with exposed metal. IF you place uncoated metal in the oven, sparks will occur.
IF the interior of the oven has the metal exposed, it will cause sparking to occur.
There must be NO exposed metal inside a Microwave oven!
Aug 15, 2011 | Goldstar MV-1310W/B Microwave Oven
GE JE2160 31/2 years when it is turned on sparks fly from the cover plate located on the right inner wall. If it can be repaired is there an estimate of cost. Thanks gm.eiland@gmail.com
All you need is a new WaveGuide Cover. It is fitted with usually a screw or plastic clip and is fitted from inside of the cavity, where you place your food to be cooked. No taking anything to bits, just the cover.
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Jan 05, 2011 | GE JE2160 Microwave Oven
Making popcorn - sparks flying and making loud noise
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 29, 2010 | Microwave Ovens
Everytime i turn it on sparks fly
If they is any exposed metal in the cooking bay of the oven or grease it will cause it to spark and catch fire. If it is please clean the oven throughly. If it is sparking from the back the magnetron is bad and need to be replaced.
Aug 27, 2010 | Emerson 025806092806 Microwave Oven
I have a GE microwave that is barely a year old. Recently, my husband was heating up some melting chocolate and white sparks started flying within the microwave. When we opened it, all we saw was that some...
Very difficult to explain briefly as microwaves are truly complex.
You will almost certainly have 2 problems. 1)You need to carefully sandpaper the area where the paint is peeling off and "only paint with appliance paint as this does not have lead in it and 2)The sparks are due to a variety of things, but the most obvious, replace your main capacitor and HV diode. This combination is the normal culprit for arching. If it continues after that, the Magnatron needs replacement as well (Unfortunately, for first time diagnosis, electrical testing equiptment is needed.)
Jul 30, 2010 | Microwave Ovens
Sparks fly
This is not good. Get the unit serviced by a professional before you use it again.
Apr 19, 2010 | Maytag UMC5200AAS Microwave Oven
Sparks ae flying in my microwave
GE in essence says it is unrepareable and insafe. I suggest that would be saying it is trash.I don't know what that carboard is, possibly indulation? Ot may have /be a a oiece oce of laminated metal like some paper plates have..Not replaceable is a poor answer. Call them back and make a fuss. If it's not too far over warranty, they may work with you to shut you up.. oops, sorry, to pacify you.
:-) Good luck.
May 28, 2009 | General Electric Microwave Oven
Microwave problem
That panel is probably mics, not netla, though it may look like metal. The job of the waveguide cover is to protect the waveguide (opening) and the magnetron from buildup of food particles and grease. When the grease and food particles build up on and behind the cover, they will carbonize and arc - and maybe even flame up! The solution is to clean it and keep it clean - but if it's too dirty or is burned, it must be replaced. Sometimes it's necessary to remove the cover to clean both sides of it, and to clean the edges of the opening it covers. It is sometimes held in place with a small plastic rivet (or screw) and once that is removed, the cover will slide over a little then drop down. Be VERY careful not to get cut on the potentially sharp edges of the opening, and do not spray anything into the opening. Apply an alcohol-based cleaner (such as the purple kind) and /or gentle scouring powder to a cloth or paper towel and carefully wipe it out, then when it's dry, reinstall the cover and the rivet. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics.
Apr 23, 2007 | DeLonghi MW 535 Microwave Oven
Microwave Ovens Logo
150 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
