Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
The pull cord does not rewind properly - Yard Machines 158cc Push Lawn Mower #11a 034f200
  • 54 Answers
A lot of times the rewind will get crud in it. Try removing the engine cover and spray a good silicone spray behind the rewind pulley and pull the cord many times while doing this to work the lubricant in. Usually works.
Posted on Apr 28, 2010
How do I replace a pull cord for pm 605 mcculloch chainsaw?
First remove the pull starter housing.
The next part is tricky. You'll have to release and unwind the spring that rewinds the pull starter cord. Remember how you do this because after replacing the cord, you'll have to rewind the cord and spring before inserting it back in the housing.
re-attach the pull cord housing to the chain saw.
Hope this helps.
Oct 19, 2014 | McCulloch Pro Mac 605 610 645 650 655...
Pull start cord won't rewind model no RLT30CET curved shaft electric start
There is a spring there you don't need to buy one use the old one.. If you need one go online give them model number have in two days.... Good luck..
Sep 15, 2012 | Garden
Toro pull cord won't rewind
You have to open up the starter and reattach the spring that works with the pull cord. A royal PIA.
Sep 16, 2017 | Toro Personal Pace CARB Walk Power Mower
The pull rope will not rewind. How do I reset it?
The cord should be removed from the spool entirely, then wind the spool spring CCW for a number of turns making sure the spool can be turned for about 6 turns more (during start). Wedge the spool so that it can't unwind the spring again. If the old cord was about worn out, replace it with fresh. Melt the cord end somewhat so that the knot won't pull out, then tie an overhand knot in the cord end. Feed it into the inner retainer on the spool, then thread the cord around the spool 5 or 6 times in a CCW direction. Once wound, feed the loose end out of the cord port, slide the pull handle on, melt the cord end, and tie an overhand knot on it. Stuff the knot into the handle and release the wedge from the spool so that spring tension pulls the cord tight. Pull the cord out several times to make sure nothing interferes with cord and mechanism, then install on the saw and check the start operation. The spring should never bind-up when the cord is fully extended. Hope this helps!
Jul 25, 2010 | McCulloch Garden
Starter rewinder repair How do I rewind the starter rewinder?
If both ends of the spring are still attached, then turn the spool CCW (remove the cord first) until it is fairly wound, but still be able to turn 5 or 6 turns more to allow for the movement required when starting. The spring must not bind-up during starting. Wedge the spool so that it can't unwind again, and fix the cord to the spool inner attachment (melt the cord end before tying the overhand knot). Thread the cord CCW until the spool is nearly full, then feed it out of the cord port and slide the handle on. Melt the end and tie an overhand knot to retain the pull handle. Release the spool wedge and try the cord action--it should come out about 3' or so without binding and return smoothly. Remount the entire assembly and make sure the engine is being properly turned. Hope this helps!
Jul 12, 2010 | Poulan Pro Chain Saw 46cc 20"
Pull cord broke on my craftsman gas push edger. I replaced cord but when I pull cord..It wont rewind but I can hear it trying to start
It sounds like you did not properly rewind the spring that is behind the spool that the cord would around, that spring is what rewinds the cord after pulling the cord.
May 05, 2010 | Craftsman Garden
Rob poulan leaf blower how to rewind pull string
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool.
Both methods require about 2 turns of pretension to rewind the cord when pulled. HTH
Lou
Sep 05, 2009 | Poulan Garden
The pull cord has come off the spindle, how do I get it back on properly or install a new one and reset the spring tension
Remove the starter cover, rewind or wind a new cord onto the spool. Turn the spool about 2 turns against the spring, thread the pull cord through the starter cover and reinstall the pull handle.
Lou
Sep 05, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
The pull start needs rewinding, the pull start came lose and goudged a groove in the fly wheel.
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Jul 14, 2009 | Garden
My pull cord will not spring back properly
pull the cord cover off and check to see there is not to much slack in the cord when fully wound...if there is you can rewind the slack onto the spool...the spring may be broken and needs to be replaced
Mar 08, 2009 | 2005 Honda CG 150 Titan KS
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
250 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
