Question about ASUS NVIDIA nForce Chipset A7N266-VM (A7N266-VM W/L) Motherboard
Chassis opened or tampered before
I have just got a ASUS A7N266-VN motherboard. I have fixed a AMD 2400+ processor in it. Now when ever I am switching it on it is going directly to the BIOS setup and writing Chassis Opened or tampered before.
I am unable to update the bios because of this.Can you please help?
  • 53 Answers
In asus motherboards jumpers there for the chasis opened or closed, this jumper is nearer to Front pannel connections in motherboard
IF u have the manual book for ur motherboard pl look in to that.
Otherwise u tried in asus.com for mnual
Pl  try it
Regards
Was this soultion helpful?show ur appericiation by rating it
Posted on Mar 24, 2008
SOURCE:
I want to upgrade my RAm from 256 to 1 gb DDR 1 , Dose A7N266-VM Rev -1.05 mother board supports it ?
amd processor? yes you can upgrade it and do not install the 256mb ram together with the 1 gb memory that you want to upgrade, better use the 1GB alone,
Aug 04, 2011 | ASUS A7N266-VM Motherboard
Support processor for upgrade to higher processor
This are the comptible processor that you can use for this motherboard if you plan to do a upgrade on it. AMD Athlon 64, AMD Sempron, AMD Athlon 64 FX, AMD Athlon 64 X2
Here is a link that contain all the details about this motherboard.
http://www.dealtime.com/xPF-ASUS-Asus-M2N-MX
Aug 04, 2010 | ASUS M2N-MX Motherboard
P4B ASUS motherboard when switched on reports "system intruded chassis opened or tampered" everything seems a-ok so I am at a loss. I can not run a CD to install XP
in your system there is small black push to on switch is there in cabinet press that or close the cabinet properly check cabinet switch connection also
Jun 21, 2010 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
Asus motherboard( A7N266-VM)
FOr reset motherbord settings to defaults you can reset with 2 methods.
(1)Pull cmos cell from motherbord for 10 minutes so all settings defaults.
(2) Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put jumper in 2-3 position and thne power up then again put pin in 1-2 position thne all settings defaults.
Refix RAM memory.Clean dust from all parts.
Open processor and processor fan.
Remove pci cards from motherbord then check.
Make sure motherbord not ground with cabinet.
Let me know if you need further assistance.
Nov 11, 2009 | ASUS A7N266-VM Motherboard
Need assistance for download ASUS driver cds
Hi vivek_anand2,
Asus no longer sells the CD for your motherboard. You'll have to download the drivers from Asus & burn the drivers to a CD/DVD disk.
Click on this Asus link;
http://support.asus.com/download/download.aspx?SLanguage=en-us
Once loaded type, A7N266-VM into the search window in the upper right hand corner of the page & click on the white arrow. Asus will load another site. The first one listed, A7N266-VM related files for download . Click on it. Another link will load & here you'll have to click the dropdown menu & click the operating system you are using or going to use. Than click, the search button.
All the drivers for the motherboard, A7N266-VM are listed there. Click the + sign to open each set of drivers.
If you need further help just post back here.
Good luck vivek_anand2!
Thank you for using FixYa.
Mike
Mar 22, 2009 | ASUS A7N266-VM Motherboard
How to upgrade processor on ASUS A7A266 motherboard?
looking at this old motherboard the 2400 is unlikely to work, the motherboard has a cpu fsb support of 133mhz and supports the duron processors.
offhand, 2400 wont work.
Mar 18, 2009 | Computers & Internet
Problem at boot
There is a mechanical switch connector available to determine if someone has opened the chassis.
You can bypass this through the BIOS by entering the BIOS on bootup (DEL? message at bootup? F1?) then look for the system chassis intruder alarm and DISABLE
Another option is to find the pins that the switch is supposed to be connected to (documentation on the ASUS P4B motherboard) and jumper them.
Jul 03, 2008 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Tower change
1. Restart your machine
2. Enter BIOS by pressing F2
3. Scroll down to 'System Security'
4. Press Enter
5. Scroll down to Chassis Detection
6. Arrow over to 'Disabled'
7. Press Escape
8. Save changes and exit.
In some bios is in bios in the section BOOT and BOOT SETTING CONFIGURATION and disable CASE CHASSIS WARNING.
Your bios may be slightly different from the above. check inside the settings and find the case chassis warning option.
Regards
Mar 29, 2008 | ASUS NVIDIA nForce Chipset A7N266-VM...
Motherboard
There is normally a system tamper reset within the bios settings somewhere. Alternatively try to reset by the JBAT1 terminal by putting jumper from pins 1-2 to pins 2-3 then back again and restart pc. You will have to set the time again and make sure the HDD is detected in standard bios settings and re start.
Jan 16, 2007 | ASUS A7N266-VM Motherboard
Open Questions:
See all ASUS NVIDIA nForce Chipset A7N266-VM (A7N266-VM Questions
ASUS NVIDIA nForce Chipset A7N266-VM (A7N266-VM W/L) Motherboard Logo
248 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
