Question about Samsung HL-S4266W 42" HDTV
Unhooking speakers Can I remove the front speaker cover? I unscrewed the four screws on the back but it appears to be attached in the middle somewhere. I ask because I have sound issues - a cap is fried on the board and it causes crackling noises when it warms up, even with internal mute on. We use a surround system for sound, so I just want to detach the speakers. I see no need to buy a $400 sound board when I have never used the TV speakers.
SOURCE: Surround Sound Not Playing For TV Programs
In the display window, do you see the letters ASC? If so,press the ASC button on the remote to turn it off. You should now have the TV sound thru the rear speakers. Enjoy...
Posted on Jan 28, 2009
dsacco86
  • 1077 Answers
SOURCE: Continuous crackling from TV speakers
I'm sure you have figured this one out. TV itself is causing the problems.
The circuit board that produces the audio signal seems to be the problem.
Before you call the repairman, go to the web site Shopjimmy.com just to get an idea of what the parts will cost. That way he doesn't rip you off.
I hope I answered your question correctly. Please rate me. :)
Posted on Feb 26, 2009
  • 304 Answers
SOURCE: 46" Samsung LCD, no sound output whatsoever
First try hooking up a different source such as a DVD player or Cable box and see if you have audio. If you do then check the audio output from the computer. If you do not have audio then make sure the tv audio is up half way and turn off the set. When you do this you should hear the down chime provided you have the chime turned "on". If you do not hear the down or up chime then the sudio circuits on the Main bd are bad and the Main bd will have to be replaced. A quick way to check to see if the audio circuits are working is to listen for the up or down chime when turning on of off the set coming from the tv speakers speakers.
Posted on Jul 16, 2009
yuvamibar
  • 170 Answers
SOURCE: picture fine no sound at all,on screen says
in the menu option, check that you didn't select to use external speakers.
Posted on Jul 26, 2009
SOURCE: I have just purchased a
Your advice has solved my problem and I am advising the store from which I purchased my TV so that future customers may be better informed,
Please convey my thanks to roek (Eric) Don
Posted on Sep 22, 2009
Blown Polk LSi9 bookshelf speaker
You can open it and check if the cord somehow disconnected from the base of the small speaker inside. , if it is burned out then you will need new ones.
I Have these at home and have had no problems:
Amazon com Acoustic Audio AA5170 Home Theater 5 1 Bluetooth Speaker System...
Aug 23, 2016 | Audio Players & Recorders
How do I open the philips bt3500 bluetooth speaker to repair/replace the charging port?
I opened mine by pulling off the back cover, it is clicked in. then I removed the six screws that appear. Then you can press out the front
Oct 05, 2014 | Audio Players & Recorders
How to open a425 subwoofer
pull off front plastic grill to access four screws on the speaker itself. Unscrew 10 screws on back to pull out the power board. The transformer is screwed to the bottom (4 screws).
Oct 01, 2011 | Dell A425 Computer Speakers
How can I replace a tweeter for a 10 year old Cambridge Soundworks tower 2 speaker?
Its pretty simple actually.
If you already have the same size new tweeter. You take off of course the large felt cover so speakers are exposed on front. Just like your picture is in this post. Then you should see some screws, most likely it is going to be Phillips. Then unscrew all the screws, the whole front should slide out with of course speakers still attached, don't pull out to fast or far, to make sure the internal wires are long enough to take whole front out and set aside speaker box, the on back of speaker should be two wires going to it, maybe three if is tapped in conjunction with a ground. Anyway on back of speaker unplug the wire from speaker and then, take out screws which is normally on back of speaker, pull speaker out, put new one in and repeat steps in reverse order. Hope this helps. Mike
Jul 07, 2011 | Cambridge Soundworks Tower II Speaker
Hi , there is problem with my phone volume. I can
First of all, a temporary solution is for you to use a earpiece. You plug it on your phone and you will be able to hear the callers clearly.
If your phones main speaker is working, then it is the earpiece speaker that is bad. All you have to do is to replace the speaker with a new one. There are two speakers on this phone, one in front, which is the part where you get to listen to your callers from, then another speaker that plays your audio files and receive your calls on speaker mode.
To disassemble the phone, follow the steps below:
  1. Remove your back cover, battery, sim and memory card. Six screws need to be removed,
  2. Run something like a credit card around the join of the battery compartment to release it from the rest of the phone.
  3. Now remove the two screws and you'll be able to lift away the metal plate with the identification sticker on.
  4. A ribbon connector needs to be detached. This attaches like a plug and socket. Just lever it up to unplug. You can now lift the circuit board away from the rest of the phone.
  5. Remove the eight screws you can see. These screws hold the slide part in place.
  6. You can now lift the slide part away from the rest of the phone. Four screws now need to be removed. The two on the left are covered with black stickers which can be easily removed.
  7. Now run your plastic tool all the way round the join of the front cover in order to release it.
  8. Three ribbons need to be disconnected. The two left and right attach like a plug and socket. Just lever each up to unplug. The ribbon in the middle has a different connection. To release it just flick the black latch up and pull the ribbon cable away from its socket. You can now lever the LCD screen out of the front cover.
  9. Then you see the earpiece and where it is connected to, just disconnect it, replace it with a new one, then you reverse the process to reassemble the phone back together.
Take care and good luck.
NB: When making a call, do not put it on speaker yet, then you increase the volume from the side of the phone where you have the volume button. If you do not hear the person calling you, then you replace the earpiece with the steps above.
Dec 20, 2010 | Samsung B3310 Cell Phone
I bought replacement drivers for Mission 780 speakers...how do I replace them...no visible screws...does the cover plate come off?
Screws are hidden under the plastic plugs where the covers slot in. remove cover, then maybe use a pencil and fingers to prize out the rubber "holes". Once all four removed, unscrew the four screws visible. Carefully lift off baffle, note that tweeter will be attached to the baffle. You then have easy access to the driver, again another four screws holding that in. You may find erosion on the terminals.
Jan 10, 2010 | Mission 780 Main / Stereo Speaker
Sony bravia 50 in lcd rear projection tv picture dark most of the time
take out screws ob back side around the edges not bottom. the grill that covers the speakers comes off by taking out screws on back in the middle of round knobs after screw is removed unscrew knob. then remove screws next to speakers then remove front of tv clean mirror in back. if that dosent work replace bulb.
Nov 20, 2008 | Televison & Video
Removing Driver from Sealed Cab
1. Remove the front cover.
2. Remove the four bushes that held it in place. Beneath them are crosshead screws.
3. Remove these screws, and the surround board they hold.
4. You can now see the bass speaker retaining screws. remove them and withdraw the speaker *carefully*. (A knife under the edge helps to get it going.) The wires are at the back mixed up with the damping wool.
5. The tweeter has its retaining screws under the rubber gasket stuck to it.
6. The connectors shoud slide off the lugs, but mine are pretty stiff. Careful with the tweeter's: mine pulled out the termnal completely, and I've had to replace the unit!
Nov 21, 2007 | Mission 780 Main / Stereo Speaker
Logitech Z-5500 Speaker stand problem
The stand was held on with a nut on the inside. There is not longer a nut on the inside of the hole, so there is now nothing for the stand screw to attach to. The nut is now stuck to the magnet on the speaker. You will need to disassemble the speaker housing to remove the nut from the speaker magnet and reattach then stand. peace. Paul.
Dec 31, 2006 | Logitech Z-5500 Computer Speakers
Samsung HL-S4266W 42" HDTV Logo
Henry  Thomas
Henry Thomas
