Question about SK 3 Pc Fine Tooth Palm Control Ratchet Set
I need to get a ratchet replaced. It doesn't ratchet at all. Locked up. It is sk brand.
    President:
  • 1,206 Answers
I don't know you location but many hardware stores around the country carry that brand and will replace them for free they are lifetime just like sears and snap on tools also call you local auto parts find out what brand they carry many carry sk as well
Posted on Apr 26, 2010
The spring in my butterfly air ratchet is not working
This can be repaired . not sure what brand you have but you can look up your tool for the replacement spring on ereplacement.com or the toolbarn. both of the sites offer a lot of different tool brand parts and breakdowns,
Feb 20, 2014 | Air Tools & Compressors
Freewheel fails intermittently
I assume you means that it slips sometimes. This is usually due to the ratchet mechanism just needing a bit of lube. If you have a thread-on type freewheel (see image below) then you can usually just squirt some WD40 into the little holes near the center of the freewheel. Those holes would be facing the table in the threaded freewheel pictured below. If that doesn't work for you, it's not all that difficult or expensive to just replace the whole freewheel. However, if you have the splined type pictured on the right, the ratchet mechanism is in the wheel's hub, making replacement more of a big deal. WD-40 would probably do the trick on this type too, but I never had one some I'm not certain how easy it is to get the lube where you need it. Good luck!11_8_2012_3_08_02_pm.jpg
Nov 07, 2012 | K2 Cycling
Replace Belts
I have found a answers that maybe can help you. There is at least one pulley the the belt runs around that is not part of any device. Put your ratchet on the center nut for that pulley in the on position. When you put pressure on the ratchet the whole pulley should move like it's on a spring. if it doesn't try the other pulley. there should be a diagram under the hood showing where the belt goes. put the belt over all the pulleys but one. put pressure on the ratchet until the pulley moves enough to slip the belt over the last pulley. you're done!
______________
obd2 airbag reset tool
Oct 02, 2012 | 1997 Nissan Pickup
Replace the timing belt and the car will not crank
Always crank motor over by hand with a ratchet or breaker bar before attempting to start with key. You can very well ruin or lock up your motor if the timing is incorrect before you try to start with key. If its locked up, unhook battery. Place ratchet and socket on crank pully. rotate in reverse and then try to rotate forward. If there is anything holding the motor from turning by hand, pull timing belt and make sure everything is aligned correctly and try to crank by hand again 2 or 3 revolutions. If tight or locked, then motor needs inspected for bent, jammed valves, broken pistons.
Aug 30, 2012 | 1996 Dodge Intrepid
How do you tell if the moter is locked up in jeep grand cherokee it has a 5.2
Remove the ground cable from the battery, remove all spark plugs, try to turn over the engine by hand or with the starter, should turn over really easy if not the timing belt is may be broken.
Aug 13, 2009 | 1995 Jeep Grand Cherokee
Need 419 mb space wen i brought console new
Maybe it wasn't brand new after all.
You can clear up the old user data by deleting it from the GAME menu. Check Game Data Folder.
If there are games that you've never played before or games that you aren't going to play anymore go ahead and delete the files.
Best of luck!
Jun 19, 2009 | Sony Ratchet & Clank Future: Tools of...
SK 3 Pc Fine Tooth Palm Control Ratchet Set Logo
Top SK Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a SK Hand Tool Expert? Answer questions, earn points and help others
