Question about Cirrus Toys
Trans stays in limp mode and speedometer doesn't work, tach does not work all the time
  • dwilson16 Apr 26, 2010
    I am not getting a answer
    the speed sensor has been replaced
  • 326 Answers
As for the trans staying in limp mode it will if it sees no input or output signal from speed sensors may have bad speed sensor and with intermittent tach operation you may have a body module causing some or all of this problem
Posted on Apr 26, 2010
    Top Expert:
  • Cirrus Master
  • 80,407 Answers
WHAT IS THIS?
  • 2 more comments
  • yadayada
    yadayada Apr 26, 2010
    I don't know what i am working with here, please provide make model and year.
  • yadayada
    need the make the model and year to help you, come on now. these problems are NOT GENERIC
  • yadayada
    WHAT FUALT CODES ARE PRESENT IN MEMORY, AND WHAT IS IT WITH THE FAILURE TO PROVIDE INFORMATION, ARE U PLAYING SOME KIND OF GAME HERE??
  • yadayada
    WHY DON'T U JUST CALL IF U CAN'T TYPE OUT THE INFO. 925-577-7157
My 2001 dodge startus transmission wont shift, speedometer works, engine light is on. Need help?
Transmission is in limp mode. This enables you to drive the car to service. Anytime there is a transmission code in the computer even if nothing is wrong it will stay in limp mode until the code is erased. Most retail auto parts stores will run an obd2 diagnostic scan to determine the problem and erase existing codes, no charge (Auto Zone, Advance and others)
May 14, 2014 | 2001 Dodge Stratus
TANSMISSION
My 1997 Z71 did this twice last Summer. PRNDL indicator didn't work, Tach, Speedometer, didn't work. Only 1st & 3rd in auto Trans worked. Fuse for all this wasn't getting any power. Replaced ignition switch. Fixed problem.
Feb 06, 2014 | 1997 Chevrolet K1500
My 1997 Dodge Stratus is stuck in limp mode, second gear forward or reverse. It doesn't have a speedometer display or the tachometer most of the time. I replaced the output speed sensor and the Tr
Its not likely the transmission is causing the problem if both the speedo and tach are out. The tach does not involve the transmission.
Sounds more like a problem with the instrument cluster or the body computer.
You may have to get a used shop manual to get the wiring diagrams and testing procedures.
Apr 08, 2013 | 1997 Dodge Stratus
I have a 1999 Chrysler 300M. Simultaneously, the Check Engine light came on, the speedometer stopped working, and the car doesn't shift out of 2nd gear. What's the likely problem?
these vehicles have alot of problems with the tcm( tranmission control module) internal failures of trans speed sensors. your car is currently in "limp in mode" to protect your trasmission!!!
Sep 02, 2012 | 1999 Chrysler 300M
Trans stays in limp mode, speed sensor has been changed,speedometer does not work, if speedometer head was bad or unhooked,would that cause mw problem? It is a 1995 chrysler cirrus
Your engine management and maybe even your transmission is controlled by the ECU. As such, many ECU units are fitted with a 'limp home mode'. When it detects that something semi-serious is wrong, it enters the limp mode, which means that the engine won't rev beyond a pre-programmed speed, you can't accelerate very fast, or you may indeed be speed-restricted to 40 mph or similar. The transmission may even stay in one or two gears. The alternative would be to either let you drive at regular speeds, with the danger of letting you trash your car or stopping you from going anywhere .
You should have a Check Engine light. Go to a major chain auto parts store and they should read the ‘code’ for free, then go to rdtiburon.com and ask what the code actually indicating or is really bad to your car. They will advise you what you ought to do.
Because you replaced the speed sensor and are still experiencing the problem, we suspect that you have a faulty speedometer cluster.
Please check this link and go through the article to have an indepth knowledge to your problem....
http://geekswithblogs.net/lorint/archive/2005/12/21/63765.aspx
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Apr 27, 2010 | Chrysler Cirrus Cars & Trucks
The tail lights have started staying in brake mode, turn signals not working properly. Some times when you hit a bad spot in the road the tach and speedometer stop working as well as the head lights. I...
Could be bad brake light switch but turn signals involved so? Has to be bad ground.Light sockets corroded bad wiring thru fender mounting bolts in tail light assembly broke but corroded in place,not a good ground.Has to be simple cause bike runs.
Mar 09, 2010 | 2001 Harley Davidson FLHR - FLHRCI Road...
My GMC has 311632 miles on it. I just changed the 4L60E transmission a few months ago and now it wont shift out of first unless I manually put it in second gear. all the gears from park rev. nuetral works...
The transmission may be in Limp mode. The transmission is on the same fuse as the MAF, O2 sensors and at least one other sensor - if an O2 shorts out, it will blow the fuse and the trans will go into limp-home mode. Be sure the trans has power and the fuse is not blown before doing anything else.
What is "limp-home mode" ? This is a fault mode in which the transmission either loses electrical power or the PCM deactivates all of the electronics. The transmission will default to max line pressure. The driver will have Reverse and 3rd, with manual 2nd available by putting the gearshift in 2 or 1 (doesn't matter). 1st, 4th, and TCC lockup will not be available. It will not hurt the car to drive it like this for short periods, but use manual 2nd to get the car moving, and be aware that the trans will generate more heat than normal while operating in limp-home mode due to increased torque converter slippage during 2nd gear starts and no lockup in 3rd gear.
Trans does not upshift out of first, speedometer reads zero at all times: VSS failure. Easy fix on rear of transmission, but xmember must come out to access VSS.
Car goes into gear but feels very sluggish like the brakes are dragging, but it will roll easily (starts out in 4th gear), you manually shift to 2 to get it moving, once it's moving you put it back in OD and the car shifts 3rd to 4th on its own and locks the converter at the appropriate time: ShiftB solenoid failed: Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
No 1st or 4th available; trans shifts 2nd to 3rd by itself in D or OD and locks the converter : ShiftA solenoid failed. Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
Transmission does not shift automatically, only manually. Swap in a known-good PCM, check wiring, check other sensors such as VSS and TPS.
3rd gear starts, can manually shift through all gears. When car has been turned off for a bit, then back on it will run normally.: VSS dropoff w/ Hi-stall converter. The rpms are too high, but VSS is showing no movement. Happens after a tire burning take-off. Doesn't store a code, will not throw a CEL (I've heard that it will store a code if it happens 3 or more times). Cure: Reprogram PCM for VSS dropoff -- PCMforLess knows about it.
Here are just some of the common things you have described with the issues your transmission has. Good luck and keep me posted.
Dec 22, 2009 | 1994 GMC Sierra
NO GAUGES & WON'T SHIFT TRANSMISSION
I would have the high and low shift sensors replaced first. If it continues to not shift it is staying in limp mode and you need to take it to trans shop to have diagnostic
Jun 29, 2009 | 1994 Chrysler Concorde
Toys Logo
53 people viewed this question
Top Cirrus Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Cirrus Toy Expert? Answer questions, earn points and help others
