Question about GPS
When I open navigation tool I get a Fatal Application Error
When I open the navigation tool on my Nextar Q4-06 I receive the following error message:
Fatal Application Error Application Adeona.OdysseyCore has performed an illegal operation and will be shut down. If the problem persists, contact the program vendor.
Program: Adeona.OdysseyCore Exception: 0x80000002 Address: 00017C04
What do I do to fix this problem?
  • 508 Answers
One check the sd card for the unit and maker sure it is not locked (yes they do have a lock on them), it will be a small white? tab on the side that will slide up and down. That's the lock.
If this is good and it is not locked, then i would suggest that you check and see if you have an install cd for your unit. If you do and once you verify that you have the maps, I would suggest that you either get a new 2gb sd disk to use in the gps or reformat the original and install the software again.
These types of errors are generally caused when the operating system tries to access a file and for whatever the reason, that file or simply a byte of information has gone missing or is corrupt. The unit can't find the software and spits out a pretty much useless code for the average user.
Hope this helps.
Posted on Apr 26, 2010
When i try to use the navigator it comes up with a gray box that says fatal application error application adeona.odysseycore has performed an illegal operation and will be shut down. if the problem...
This indicates that the unit suffered internal hard drive failure. Unfortunately support is not available at this time as both the nextar website www.nextargps.com is down and their customer service phone number does not work as well. You will need to get a new GPS unit,
Sep 24, 2011 | Nextar 43NT GPS Receiver
My Evesham nav-cam 7000 model ps1025 is showing
My Evesham nav-cam 7000 model ps1025 is showing the following:-fatal application error Application Mobile Navigator.exe has performed an illegal operation and will shut down.If the problem persists contact the program vendor.Program 0xc0000005 Address 000d026c.What can i do to remedy and get a cd disc for it?
Oct 12, 2009 | Navigator Evesham Nav-Cam 7000 GPS...
Fatal application error
pplication adeona. oddysseyCore has performed an illegal operation and will be shut down. if the problem persists , contact the program vendor. program: adeona.odysseycore exception: 0xC0000005 address: OO1FOAEO
Aug 26, 2009 | Nextar X3 GPS Receiver
Gps freezes , wont load up,and fatal application error comes up
Your getting fatal error's ? Your going to need to have this services if it freezes! There is not a easy fix for this one..
May 24, 2009 | Nextar X3B GPS Navigation System
Nextar S3 Application error in Navigate
You need the contents of the \ResidentFlash directory. You'll need to rename the MobileNavigator folder and the four gpspara files (0,1,2 and 3) then load the new folder and files from a device that is working. You will then copy your old \ResidentFlash\MobileNavigator\UserData folder from your backup to the new folder to regain any favorites you might have created. You should then be good to go. I use ActiveSync to talk to the S3. I'm not sure how else you might attach to it.
I have the ResidentFlash files but I have no place to post them. The files zip to about 5.3 MB.
Feb 27, 2009 | Nextar S3 Car GPS Receiver
I have poblem with my gps
i have a nextar w3g, and this gps is running with windows CE, is possible the problem to be a virus or some othe errors you can find in every other windows sistems.
Aug 30, 2008 | Nextar X3B GPS Navigation System
Intellinav.exe application error
Did you try the switch on the back of the GPS? Turn off on the front, turn the switch on the back off, then on. This has worked for me numerous times.
Jan 06, 2008 | Nextar Q3 GPS Receiver
HELP!! I keep getting Fatal Application Error. Application entellinav.exe has performed an illegal operation and will be shut down. If this problem persists, contact the program vendor. Program: Intellinav.exe
Exception: OxC0000005
Address: 00125D64
Oct 11, 2007 | Nextar Q3 GPS Receiver
GPS Logo
444 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
