Question about Hitron HRA-2900B 1400W 2 CH Amplifier Car Audio Amplifier
My ground terminal broke off...can i reroute it/
  • 175 Answers
Yes but it has to be a good earth preferbably ring terminal and screwed to the chassis
Posted on Apr 27, 2010
Female coax connector broke on vizio smart t.v.can i buy an adapter or reroute out of cable box to t.v.
If the cable box has an HDMI or video output, use one of them to connect to the TV instead. The female coax connector is not easily repaired and you can't reroute or adapt anything to fix it. You will need to replace the TV main board if the HDMI/video connection is not an option.
May 05, 2017 | Vizio Televison & Video
Long story
more likely that you didn't wire the plug correctly
take it in to a repair shop for check
May 08, 2017 | Frigidaire Dryers
Had the dealer swap out the 20A fuse for the lighter, but they broke the fuse box slot in the process (didn't realize it right away). We've had it "fixed" several times, which means bending the...
If the dealer broke the slot take it back to them as they are responsible for the repair. Other than that if you can get the fuse box loose and have enough room to get in behind it it shouldn't be difficult to reroute the wires to an empty slot.
Mar 05, 2011 | 2004 Ford Focus
The ground terminal that goes to the battery has this little ground coming out the side that is suppose to go to the body some where it broke off and i cant find where it goes i have a 96 chevy blazer
Put a new ring terminal on the end of the wire and then refasten it to the body where ever it will reach.You might have to remove a fender bolt or fasten it to the rad support,make sure where ever you chose is free of paint by sanding or scrapping it first.The wire that broke off is a body ground,so fasten it to a clean part of the body,not the engine.
Mar 25, 2010 | Chevrolet Blazer Cars & Trucks
Belt broke and disconected green wire near motor not sure wher it attaches to
if it was on the line cord then its a safety ground wire and theres a ring terminal somewhere on the metal chassis it was torn from by this broken belt,you can put it on anywhere theres a metal part of the washer for a safety ground if you can't find the original termination
Mar 21, 2010 | Washing Machines
Sub buzzed and goes in and out
your signal wires (LCH, RCH) could be crossing either grounding terminal wires or even power wires. I used to have the same problem. I rerouted the wires and it cleared up the issue.
Feb 22, 2010 | Dual Car Audio & Video
Key switch on, push ignition button & nothing happens
Check your ground wire to the frame. Clean and refasten....and find a new mechanic, no excuse for inferior workmanship...Sure sound like a ground problem !......Good Luck to you friend....Tim
May 09, 2009 | 1994 Honda VF 750 C Magna
Panasonic TC-32LX70 buzzing sound from speakers
Double check the coax cable, make sure you have a good cable.
Are you only getting the noise from watching Cable?
Apr 22, 2009 | Panasonic TC-32LX70 Television
Car Audio & Video Logo
Top Hitron Car Audio & Video Experts
xxxxxx xxx
Are you a Hitron Car Audio and Video Expert? Answer questions, earn points and help others
