Question about Frigidaire Dryers
Dryer Model No. FEQ221CAS2. Drum thumps hard
Dryer Model No. FEQ221CAS2. Drum thumps hard every half turn. Also thumps when turned manually in off position. Belt is good
  • ted2322 Apr 27, 2010
    Woould really appreciate a link to any manual that shows a good way to access the rollers and pics that stipulate the right disassembly and reassembly recommendations.
    The link won't bring anything up. It says it can't find http. Would you forward the link again
  • Frigidaire Master
  • 3,361 Answers
The manual referenced below should help you.
Your rear drum support or belt tension roller will be your problem.
http://frigidaireservicetips.com/pdfs/363_5.75cuftGasElectricDryerGoodandBetterModels.pdf
Posted on Apr 27, 2010
  • steve
    steve Apr 27, 2010
    Try this. If that does not work you will have to copy and paste the link.
    The link does work for me.
    Let me know.
  • steve
    steve May 06, 2010
    Copy and paste the link I provided for your dryer repair.
    The information given by emmissiowiz does not apply to your dryer.
    Your dryer has a drum bushing/bearing support.
    It does not have drum rollers.
    Top Expert:
  • Frigidaire Master
  • 80,637 Answers
THE DRYER RUNS IN SUPPORT ROLLERS, U NEED TO REPLACE THEM.
Posted on Apr 26, 2010
  • 2 more comments
  • yadayada
    yadayada Apr 27, 2010
    HAVE U PULLED THIS APART AND CHECKED THE DRUM ROLLERS?
  • yadayada
    HERE IS A WEB SITE LINK WITH DIAGRAMS TO THE REPLACEMENT PROCEDURE OF DRUM ROLLER, IT WORKS FOR ANY STAND ALONE DRYER, IT IS CORRECT FOR YOUR MODEL. IF I HAVE BEEN HELPFUL AND ANSWERED ALL YOUR QUESTIONS PLEASE REWARD THIS EXPERT WITH A "HELPFUL" RATING. THANKS
    http://www.the-appliance-clinic.com/drmr...
  • yadayada
    I AM SORRY BUT THESE INSTRUCTIONS ARE BETTER SUITED TO YOUR DRYER, THE DRUM MUST COME OUT TO SERVICE THE ROLLERS, SO THIS IS LIKELY THE BETTER PROCEDURE, BOTH WILL HELP GET THE JOB DONE, THE APRTS ARE CHEAP ABOUT $30 ON LINE.
    GO TO THE LINK.
    http://repair2000.com/wpoolbelt.htm
  • yadayada
    both links work, had my wife confrim that at her work computer, here is it again
How do I stop light thumping noise?
For the fun of it I would pull the drum out of it and examin the bearing the drum rides on. Now some of these have a regular type wheel bearing type, and others have these wide plastic that the drum just rides on. But they are not that hard to take apart and put back together. Just need some practice.
Mar 07, 2016 | Amana ALG443RAW Gas Dryer
It is makeing a lot of noise
Hello. You didn't provide a brand/model number or the type of noise the unit is making. If the dryer is making a screeching noise, it's probably the idler pulley(spring-loaded tensioner pulley that keeps the drum belt tight so the electric motor can turn the drum properly) being worn out or binding up due to lint build-up in the dryer. However, if the dryer is "thumping" loudly, most likely it's a worn out support roller either on the front or rear bulkhead. They're made of hard rubber and can become malformed due to wear/age causing a rough movement of the drum as it spins.
Aug 18, 2015 | Dryers
LG electric dryer model DLEO332W or DLE0332W
Sounds like the belt broke..."loud thump"
Sep 21, 2013 | Dryers
Inglis dryer making thumping sound when drying
is the unit level, open the dryer try moving the drum around, see if the drum loose, there mite something in the machine that got caught on the drum some how and when it goes around it bangs,
you mite try spinning the dryer without turning it on and listen to the drum and see if you can hear any thing hitting the drum or what is make those load sounds. if you cannot turn the drum manually you mite bribe a guy or friend to check it out for a beer or glass of wine, and if they down drink bake some cookies.
good luck rod
Dec 04, 2012 | Whirlpool Inglis IP8200 Dryer
Dryer Model # LER4634EQ1 As the drum turn's the
What the most probable things thats causing that noise is the rear drum support rollers.
This youtube video will show ya how to take apart the dryer and replace those rollers
http://www.youtube.com/watch?v=wBf_vwvlFGM
The part number for the rollers is 349241T that part number is a kit for both of the rollers in one kit plus the plastic triangle clips that hold them to the shaft they fit on.
That part can be purchased at your local appliance parts store or also online at;
searspartsdirect.com
apdepot.com
partselect.com
apwagner.com
repairclinic.com
GENE
Sep 12, 2011 | Whirlpool Dryers
Our electric dryer sounds like it csme off trsck...drum turns freely and dries good,but when drum goed round it's like thump,thump,thump,thump... Rick THANK YOU
Hello Rich,
What your describing sounds exactly like one of the drum support rollers has a flat spot on it. Depending on your brand and model number dryer drumm rollers vary somewhat by are pretty much similar. Reply with your brand and model number and ill be able to give you specific info about your dryer
Sep 10, 2011 | Dryers
Heard a thumping noise everytime we turned dryer on...lasted a week or so.....drying a blanket last night cycle stopped half way thru.....still getting hot, just not turning. Thinking this is some type of...
The thumping noise comes when the drum is rubbing against the body surface. This could be due to the suspenders/support which is holding the drier drum are not steadfast. May be one has given the way. To know exactly if it is the belt or the coupling with motor or the support for drum , you have to open the back cover which you can do it by removing the screws at the back and then inspecting the machine.
Nov 02, 2010 | Frigidaire Electric Dryer
Frigidaire dryer feq221cas2 the startswitch will not stay on
The switch is bad and need to be replaced. Holding the switch in the on position may cause it to burn, thus causing a fire so please do not hold it in manually.
Jul 22, 2009 | Dryers
LG DLE3777W dryer thumps when running . It sounds like there are tennis shoes in the drum.
Probable cause is the bearing on the wheel that turns the drum is worn out. They are easy to replace and should cost less than $25. for the part.
Remove the front of the dryer and turn the drum by hand, you should be able to tell which side is worn.
Be sure and unplug first.
Mar 16, 2009 | LG DLE3777 Electric Dryer
Dryers Logo
129 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
