Question about Pioneer 2 Handle Satin Nickel 6" Rain Head Shower Faucet+Valve....
The water pressure in my bathroom is to fast - Pioneer 2 Handle Satin Nickel 6" Rain Head Shower Faucet+Valve....
  • 349 Answers
Check you areators on your sink faucet that screw on the end of them someone may have remove a dime sized plate with a hole in it to restrict flow to water saving about 1.5 gals a min. sound slike they are removed if not you may need to check pressure reducing valve it would affect all your faucets if valve was set high or going bad.
Posted on May 05, 2010
How do I adjust the volume or pressure on the hot water in my moen bathroom faucet?
Is it single lever ? If so you can try adjusting ant scald stop under handle. Always shut off water before working on plumbing.
May 02, 2014 | Kitchen Ranges
The rinnai 20 Infinity is perfect but have recently noted a problem. I found the basin hot water tap in the bathroom begin dripping only when the kitchen hot water tap is turned on. I don't know how...
Some taps are designed to release excess pressure but it could just be a dodgy tap washer that leaks when the pressure of hot water in pipe work builds. Change the tap washer in your tap, see if it fixes it, if not it's just the design.
Jul 02, 2011 | Water Heaters
I have 2 bathrooms with a common wall. We hear a constant low tap of the pipes in the wall between the bathrooms. We have checked toilets, sinks, faucets, etc for leaks. Sounds as if there is pressure or...
You have water hammer effect it is caused by a fast closing valve,it can be solved by installing a water hammer arestor in the plumbing line or maybe the water pressure is too high and a pressure reducing valve can be installed in the main water line.(the pipes in the wall are not secured properly that's why they vibrate)
May 19, 2011 | Plumbing
Have a Rannai R75LS and getting hot water everywhere except my sink in the bathroom. System doesn't come on with only bathroom sink running.
I think these have a water pressure s/w or water movement s/w id replace the aerator 1st to a non water saver one or if possible remove water flow reducer looks like a metal washer .. if this not help you may need to replace the pressure s/w...in tank..
May 01, 2011 | Rinnai Water Heaters
My Rinnai 24 will only start when I use the the hot water in the kitchen (which is closer to the heater). If I open any of the hot water taps in the bathroom it doesn't work.. I have to start the hot water...
Looks like your recirculation pump might be bad. If your opening a valve close enough to the heater and it comes on, It sounds like it's giving your pressure switch a false reading and allowing it to come one while the farther away you get, it is not enough line pressure to overcome the safety's of the heater.
Sep 28, 2010 | Heating & Cooling
LOW WATER PRESSURE IN downstairs bathroom sink
If it has a filter on the tip remove it and retry.
Feb 25, 2010 | Delta Plumbing
Severely reduced water pressure from lavatory faucet
Take the strainer off the spout and check to see if there is any dirt or rust buildup in the strainer. This happens when repairs have been done. It usually collects at the first place the water comes out of.
Nov 07, 2009 | Elements Of Design Chicago Polished Brass...
Very low pressure when turn on the hot water faucet in sink
Shut off the water supply and open your faucets, and apply air pressure (min. 30psi) to dislodge any blockage in the pipes.
Oct 23, 2009 | Plumbing
Water Leaking around Ceiling Vent in Kitchen
it is likely a small leak i'd get a plumber money well spent you don't need the expense of a flood or search with a very brite flash light.Tom
Jun 18, 2009 | Heating & Cooling
Pioneer 2 Handle Satin Nickel 6" Rain Head Shower Faucet+Valve.... Logo
77 people viewed this question
Top Pioneer Plumbing Experts
Donni Steen
Tom Chichester
Are you a Pioneer Plumbing Expert? Answer questions, earn points and help others
