Question about GE Profile PDW8400J Built-in Dishwasher
How can I remove the bottom screen from a GE PDW8211 DW
I would like to remove the stainless steel screen from the bottom of a GE Profile PDW8211 dishwasher, but the drain well at the back has to come out and I can't figure out how to do that.
4 Suggested Answers
SOURCE: GE Profile Dishwasher with water in bottom, won't drain
I have the same dishwasher and encountered the same problem last year. What I had to do was call a plumber out. But all he did was clean out a plastic compartment in the bottom of the dishwasher then turned on the garbage disposal for a few minutes. There was some larger debris under the plastic compartment and the problem was solved. I am however now experiening a different problem w it. Good luck!
Sandi S
Lexington KY
Posted on Sep 21, 2008
  • 246 Answers
SOURCE: Replacement Door Panel for GE Profile Dishwasher
Are you trying to replace the microwave door or the GE dishwasher. Either way, www.applianceart.com (under the stainless steel section) has this roll of stainless material that you apply to your appliances. I saw it on the "Today Show." Its basically faux stainless. We put it on our refrigerator and it looks and even feels like real stainless steel. Its really cool. I think its called stainless foil or something like that. Also if you're looking for a stainless panel for your dishwasher they sell actual stianless panels there too.
Posted on Feb 25, 2010
SOURCE: GE Profile Dishwasher does not drain. model #
I had a similar problem with a GE GSD5811 model. The hoses were clear, and the auxiliary pump worked fine. It turns out that it was the "piston" assembly that had basically disintegrated over time. This part diverts water to the pump during the drain cycle.
To check it, remove the mesh filter at the rear of the inside of the machine, by carefully unclipping the heater element from the back of the machine and removing the 4 hex-head screws securing the filter panel.) Unscrew the piston assembly from the tub, and pull it out. If the sealing plunger has deteriorated or is jammed, replace it. The part number for the "piston and nut assembly" for my machine (and probably numerous others) is WD24X10018. It should cost anywhere between $10 and 16, depending on where you shop.
Another possibility is a bad drain solenoid. (This is what actually triggers the piston assembly during the drain cycles.)
Posted on Apr 08, 2010
I try to start my GE Profile Dishwasher and nothing happens after I press start except for a click. Is my water pump busted? The dishwasher powers on ok.
Here is a list to trouble shoot your DW. Cross off each item as you go. If this is a new DW..... less than a year old..... it may be under installers warrantee and definitely is under a manufacturers warrantee. Keep that in mind as you go.
Look also at your owners manual for troubleshooting help.
Jan 11, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
What's your problem? Can I Use vinegar for hard water in my stainless steel dw?
better to use 3 oz of citric acid on a monthly basis, As an alternative you can use AFFRESH available at home depot or lowes, or GLISTEN available online but hard to find locally. if you use citric acid, make sure you have hot water at your sink, measure 3 oz and put into dispenser and remainder in the bottom. start washer on normal . NO DISHES,
Jan 07, 2012 | GE 24 in. Profile PDW9880JSS Built-in...
Ge profile artica refrigerator door will not close
clip on bottom of hinge is worn or broken had mine replaced. magnetic seals are not strong enough to hold the door closed on their own. Original problem was the magnets were too strong so the clip on the bottom hinge was added.
Sep 26, 2010 | GE Profile PSW26P Stainless Steel Side by...
My GE profile side by side is not freezing on the
TAKE THE BACK PANEL OFF INSIDE THE FREEZER AND REMOVE ALL OF THE FROST WITH A HAIR DRYER. THE GLASS HEATEER AT THE BOTTOM OF THE ALUMINUM EVAPORATOR MAY NEED REPLACED. DEFROSTING THIS AREA WILL ALLLOW IT TO WORK FOR ANOTHER 10-14 DAYS.
Apr 24, 2010 | GE Profile PSW26P Stainless Steel Side by...
Is the film on a stainless steel refrig supposed to be removed
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Apr 09, 2010 | GE Profile PSW26P Stainless Steel Side by...
Can I get a replacement door for my GE Profile Refrigerator
Warners Stellian in Minneapolis can help.
For cleaning DeBruce Polish is the answer.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Feb 01, 2010 | GE Profile PSW26P Stainless Steel Side by...
Blocked defroster drain GE profile tfx25pr, tft25pr
Remove the freezer bins and shelves.
Remove the rear freezer panel.
The drain is on the bottom center of the freezer after the rear panel is removed.
May 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water marks on stainless profiles
I have used Bon Ami or Bar tenders Stainless steel cleaner (found in the section of Ajax or Comet Cleaner). Put some of the powder on soft cloth, wet it a little & scrub mark lightly; use clean rag w/water to clean off powder. Then use stainless steal spray cleaner (like the one found at Bath & Beyond) and rub in with soft cloth. I have found that the pull-out stainless steel cleaner wipes are too wet & just smear. Good luck
Dec 29, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PDW8400J Built-in Dishwasher Logo
268 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
