Question about Jazz DV-179 Digital Camera
I llive in Santa Fe New Mexico. Where can I get a
I llive in Santa Fe New Mexico. Where can I get a SD-HC memory 8gb card for my Jazz camcorder?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Jazz Master
  • 102,366 Answers
You should be able to buy one at just about any office supply store (Office Depot, Office Max, Staples) or department store (Best Buy, Target, Wal-Mart), or electronics store (Radio Shack). Best price depends on the phase of the moon, relative humidity, and other conditions.
Posted on Apr 26, 2010
Testimonial: "Thank you. I will check for prices...."
When can I purchase a memory card for the Jazz DVX50?
You can purchase an SD card any time you want, the DVX50 supports SDHC cards but will not support any card over 8GB. I suggest you take the camcorder to Best Buy so you can make sure you are getting the right SD card.
Aug 22, 2011 | Jazz DV152 Camcorder
I bought an sd micro chip for my jazz dv151 camcorder, but everytime i put the chp in it reads memory full. The chips work in anything else but wont work in the camcorder. How do I fix this?
Whats the size of your SD Micro chip? Is it 4GB or larger?
You probably bought a SD-HC chip (wich includes 4GB and larger chips). Any SD card that is bigger than 2GB is in this HC-format and will only work if the device supports it.
As you can see here in the description, your device does infact only support SD cards up to 2GB. http://www.amazon.com/Jazz-DV151-Digital-Video-Camera/dp/B001F7MXJS
I guess you will need to use smaller ones in order to make them work with your camcorder.
Best regards from Germany :)
May 02, 2011 | Video Cameras
I have a Jazz HDV180 digital camcorder and it takes a 8GB memory card. I put a 8GB HP memory card in and it says no card. I have formatted the memory card.
Try checking your manuel for specifically named memory card, sometimes certain cameras can only take certain memory card formats.
Hope this helps.
--- JD
Jan 11, 2011 | Jazz HDV-188 Camcorder
When i try to format the SDHC 8GB memory card the recording screen display's (Waiting....) for about 1 to 2 second's, then goe's to the normal recording screen and when i push the record button it...
Hi, look here's what to do, get yourself, or access to, A Computer, and a USB SD card reader, now, insert your 8GB SD card into the reader/writer, It will show up as a HDD in My Computer, and then, Format it FAT32. Now return it to the Camcorder, when turned on again, the Camera NOW should "See" the SD card. You may even be asked if you wish to Format,again,say YES, and do so, if NOT asked that;s OK too. as, you should now be able to, in either case, be able to have access to the SD card, and can change your phone settings accordingly, the extra storage will simply be "Picked Up" by the Camcorders software.
If this doesn't happen, then there maybe a problem with THAT SD card or the Camcorder? try another SD card before thinking the camcorder has a problem though.
Aug 29, 2010 | Jazz Cameras
Sd card not recognizable
I read the following spec for your camera: Recording Media Internal Flash Memory 64MB Video/Image
SD/SDHC Up To 32GB Video/Image
So, I think that an 8 GB SD card should work.
Try another capacity and brand to make it work.
Jul 12, 2010 | Kingston 4GB Secure Digital High Capacity...
Why can't you use 8GB memory card in Z710
I have a kodak z710 camera with a 2 gig card in it. I was wanting to get a 4 gig sdhc and i wasn't sure if the HC would work with this camera. HC stands for high capacity which means it allows the camera to load files on to the card faster. this may be the problem the kodak may not be HC compatable. but as i have said i have a 2 gig and it works fine with that. and i have a friend that has a 4 gig in thiers but once again i don't think it is HC so i would exchange the card if you can for just a regular SD/MMC card or SD card
Jan 20, 2010 | Cameras
When I turn on my Jazz DV 152/ T20 it displays "Read card..." and then nothing happens...I have a 4GB SDHC card by SanDisk...both camera and card are new....is this a faulty camera or am I doing something...
Usually the first thing you need to do with any SD card and Camera is to go into the settings of the your camera and Format the SD card. This has to be done for each memory card you use with that camera. i.e. a SD card formatted on a Panasonic HD camcorder won't work in your Jazz Camcorder. The formatting is different between the two camcorders. New SD cards don't come formatted.
SO try inserting the SD card into your Jazz Cam and rummage through the setting until you find your memory settings. From there find the Format Memory Card function, format the SD Card and you should be good to go.
Jan 04, 2010 | Jazz DV152 Camcorder
Jazz digital camcorder dv151 will not work
make sure its using the sd memory not cameras internal memory
Nov 30, 2009 | Jazz DV151 Camcorder
Access data on 8Gb SD card
Some older card readers will not read the newer HC-SD cards all memory cards larger that 4gb are HC-SD. You need to get a new card reader that states HC-SD compatible. Office Depot sells them as well as many online sites. Then just plug the new reader into a USB port and go.
I Hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 23, 2009 | Electronics - Others
Jazz DV-179 Digital Camera Logo
146 people viewed this question
Top Jazz Cameras Experts
Corey Fields
Corey Fields
Level 1 Expert
Are you a Jazz Camera Expert? Answer questions, earn points and help others
