Question about Tomtom GO 910 GPS Receiver
Touch screen is off center. when i touch letter A it clicks letter I. it's like the whole screen is shifted up by a little bit
HOw do I turn off touch screen on a Sony VAIO Tap 20 Touchscreen All-in-One Desktop Computer, Intel Dual-Core i5-2430M 2.4GHz, 8GB RAM, 750GB 5400 RPM HDD, Windows 7 Home Premium 64-bit
1.Press the Windows logo key + X.
2.Select Device Manager from the list.
3.Click the little arrow next to Human Interface Devices to expand the list.
4.Click the touch screen driver (in my case, NextWindow Voltron Touch Screen).
5.Right-click, and select Disable from the list.
6.Click Yes on the dialog box that asks if you are sure you want to disable the touch screen driver.
7.Restart your computer
When you want your touch screen to work again, follow the process above, EXCEPT when right-clicking the touch screen driver, select Enable
See the website
Turn off VAIO all in one touchscreen function disable annoying system...
Mar 07, 2015 | Sony VAIO VPCL23CFX/B All-In-One PC - 2nd...
S5233 touch not working
If you can use the screen even a little bit for dialing, dial *#0*# and go to touch test to identify if the screen is faulty or its a firmware problem. If the screen is useless and cant use it then go to a service center or get it changed locally. the service centers in India will charge you around Rs 1200 while local shops will do it for around Rs 500-700.. Good Luck.
Jul 25, 2012 | Samsung Star GT-S5233 Cell Phone
Samsung ST550 Camera Touch Screen Unresponsive Had the camera for 18 months and over the last 3 months the left hand side of the touch screen has stopped working. The camera's lived in a protective...
I had this problem about my touch screen same with you. The touch screen on left hand has stopped working. I had it for 20 months. I live in Thailand. I think that it is the big problem for ST550. I've brought it to Samsung Customer Center. and they've introduced me to change the new touch screen. It is about USD50.00. I am bored. I used it a little bit.
Jul 16, 2011 | Samsung DualView TL225 / ST550 Digital...
Samsung SGH A897 mobile touch screen not responding to touch Incoming calls are operable
Did you try restarting the phone...??? If it didn't work try resetting everything. And even if that is not working then I would say it's probably a hardware error. You would have replace your touch panel. Could cost you a little bit. Rush to nearest samsung service center and get it done.
And also bear to put a screen gaurd always. I would not advise you to use touchscreen phones without screen gaurds.
Good luck
Jun 23, 2011 | Cell Phones
93 honda accord the automatic trans wont shift auto but works great shifting manually, how do I fix it
your having a transmission problem,common problem are the shift solenoids get dirty and won't let it shift,have them taken off and cleaned,they have little screens on bottom of them.change the fluid at same time. clicking noise is normal when you step on brake when in park this click is from the interlock solenoid under center console.
May 25, 2011 | 1993 Honda Accord
Touch screen giving troubl...wherre i touch is not being highlighted somewhere else is being highlighted
the touch digitizer is faulty,and needs to be replaced from a professional service center, or you can purchase the whole lcd and digitizer and replace it your self with little caution.
Dec 30, 2010 | RIM BlackBerry Storm 9530 Smartphone
Samsung star touch screen mobile GT-S5233 touch screen is not responding pls guide me to resolve this issue.
Jul 13, 2010 | Cell Phones
Hello, i have an iphone 3g, 16gb. and the glass screen smashed. so i bought a new glass screen for the iphone and reconnected and it works, how the buttons dont coresspond with the area you touch. ex. i...
Chances are that like most touchpad screens it has to be "calibrated" similar to calibrating Palm Pilot screens.
Finding this procedure may be a problem, however it is likely in one of the setup screens. You MAY have to re-initialize the whole thing.
Apr 20, 2010 | Apple iPhone 3G Black Smartphone
It wont print wireless
We have to connect the printer to the network first, If it is not connected, please follow the below steps.
  1. Touch Setup (c01629002.gif ) on the touch screen.
  2. Scroll down in the Setup menu, and then touch Network .
  3. Scroll down in the Network menu, and then touch Wireless Setup Wizard . The Wireless Setup Wizard searches for networks, and then displays them in a list.
  4. Touch the name of your network.
  5. If the list does not contain your network name, follow these steps to enter it manually:
  6. Touch Enter New Network Name (SSID) .
  7. On the on-screen keyboard, touch the appropriate letters and numbers to enter the network name (SSID). NOTE: Make sure that you enter the uppercase (capital) and lowercase (small) letters exactly. Otherwise, the wireless connection fails.
  8. When you finish entering the new network name, touch Done , and then touch OK .
  9. Touch Infrastructure , and then touch WEP encryption or WPA encryption. If you do not want to use encryption (a security password), touch No, my network does not use encryption , and then go to step 6.
  10. If prompted, enter the WEP or WPA key:
    1. Touch the appropriate letters or numbers on the on-screen keyboard.
    NOTE: You must enter the exact uppercase and lowercase letters. Otherwise, the wireless connection fails.
  11. When you are finished entering the WEP key or WPA key, touch Done and then touch OK to confirm. The product attempts to connect to the network.
Once it is connected to the network or if it is alreday connected, please follow the below steps on the printer.
  2. Touch Network , touch View Network Settings , and then touch Print Network Configuration Page .
After that, please note the ip address of the printer from this printed page and follow the below steps.
Please click on Start------Control Panel---Printers Folder.
Right-click on the printer icon 8500 series---- click " Properties" , and then click the Ports tab
Click Add Port .
Click TCP/IP port and put (ip address of the printer)
, and then click New Port . The Add Port wizard starts.
Click Next ,
Follow the on-screen instructions to finish adding the port.
The issue will be fixed.
Apr 19, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Problems with keyboard, I want to press an "A" and an "H" comes u
I don't have a Nuvi 2xx with me at the moment but on a 3xx & 6xx series, press the wrench symbol and then the display icon and select recalibrate screen and go through the process and touch the dots as it tells you to do. This will recalibrate the touch screen.
- Jim
SHARCNET-USA
Dec 21, 2008 | Garmin nuvi 350 GPS Receiver
Tomtom GO 910 GPS Receiver Logo
156 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
