I have a Dell Inspiron 700m that had a hard drive failure. I have put in 2 good hard drives but niether show up in the Dells BIOS. Any ideas to solve this issue?
  • 1 more comment
  • msheared Apr 27, 2010
    Ok let me be more specific. This is a laptop. The drives that I have tried have been formatted with both NTFS and FAT and niether show up in the bios. That has nothing to do with Windows.
  • msheared Apr 29, 2010
    I did think of that but when I put the original hard drive back in it won't boot into windows but it does show up in the BIOS. Wierd. I also put all 3 drives into a external USB shell and can extract information. I am going to look for a BIOS update and or do a battery reset on the BIOS. If you think of anything let me know and thatks for the help.
  • msheared May 01, 2010
    I will try.
  • 13,433 Answers
Hello
What are the sizes of the drives that you have tried? The IDE type of drive interface has a size limit, if you put a higher drive of that into a old machine like this it will not show up.
Posted on Apr 29, 2010
  • 661 Answers
Assuming that you put in same type hard drives then it points to a controller failure. Your "failed" hard drive may actually be good or its failure caused the controller to also fail.
Posted on Apr 27, 2010
  • 12,061 Answers
Ok, before a "Drive" will "Show Up" it First needs to be Jumperd as Master & Slave, (NB: Not ALL Drives work together) Also the Drive MUST be Partitioned and Formatted, NTFS, before "Windows" will "See" the HDD. The HDD, Master, usually will be drive C:, and the other HDD, will be E: Usually, A Drive:, usually the "Floppy" then the "HDD", will be C:, then, the "CD/DVD" will be D:, the next "HDD", will be E: If you have access to another PC, and you have a USB/HDD "Dongle". Then you could use this to Initialize, Partition and Format. For use with Windows, the best format is NTFS, using all default settings. Now after you have partitioned and formatted your HDD's, you must then go into the BIOS, and set your PC, to "Boot" from the DVD. Then you can Install Windows, by "Booting" of a Windows, Install DVD.
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/parts.htm
above is an original Dell, "How To"
http://support.dell.com/support/edocs/systems/ins700m/en/sm/index.htm
Above is a "Service & repair" manual. This is just a "Must Have" when doing anything with your PC.
Posted on Apr 26, 2010
Hello, My laptop shows the following message when I turn it on- Realtek PCIe FE Family controller Series v1.19(08/10/09) PXE-EGI-Media test failure,check cable PXE-MOF-Exiting PXE ROM Reboot an
It can't locate a working boot disc. Most likely lost communications with hard drive. Look in BIOS again to see it recognizes the drive. If not try re-seating / reconnecting drive.
Feb 16, 2013 | Dell Inspiron N5010 Black
Dell inspiron 700m break the password
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-700m-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Dec 01, 2011 | Dell Inspiron 700M Notebook
Error code0146-2000
Doing a little digging, it looks as though this is a hard drive failure code for some Dells including the Inspiron 6400. You will probably need to replace the hard drive. IF you need to get information off of the existing hard drive, I would try putting it an external enclosure. You may be able to retrieve some of the documents from there.
Jan 07, 2010 | Dell Inspiron 6400 Notebook
How to reformat the hard disk of my inspiron 700m
Easy enough To format your hard drive, insert the installation DVD(Vista) and go through the options until you get to choose which partition to install Vista on and just click the button at the bottom that says "Format".
Much the same in XP
Oct 03, 2009 | Dell Inspiron 700M Notebook
Trying to start computer up and I get a diskette drive 0 seek failure message SATO 0 ST3160815as 4.ada SATO 1 HL-DT-ST DVD+/RW GSA-HT3H B103 SATO 2 NONE SATO 3 NONE
Go into the bios of your Dell and ensure that the Sata HDD 0 is being seen by the bios and that it has not been switched with the DVD. Make sure that the sata cables on the main board are plugged in correctly the hard drive should be in sata port 0 and on some dells it's sata port 1. Make sure in the bios that the Sata HDD 0 is enabled.
Hope this helps.
Sep 24, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
Dell 700m wont boot with new hdd
Hi
Need to know how far it boots, eg past cmos screen, ??Win screen
Also some laptops will only accept hard drives up to certain sizes. Check in the Bios as to whether that size drive is actually supported.
Aug 12, 2009 | Dell Inspiron 700M Notebook
My Dell Inspiron 700 laptop with Windows XP suddenly will not boo
Remove the hard drive, then see if you can boot to the XP CD. If you can, then the Hard DIsk Drive has most likely failed. Reseat the HDD and try booting to CD again. If problem comes back, try a new hard drive.
Mar 31, 2009 | Dell Inspiron 700M Notebook
Dell inspiron 8200
Check your BIOS make sure your HDD and CD-ROMs are enable I did the same thing and found i had been laying to much in BIOS
Oct 13, 2007 | Sharp Dell Inspiron 8200 15.0 ASV UXGA -...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
